Long Travel Taco
Discussion in '2nd Gen. Builds (2005-2015)' started by sytfu510, Sep 8, 2011.
  1. Mar 13, 2018 at 3:50 PM
    #2301
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
  2. Mar 14, 2018 at 2:35 AM
    #2302
    sytfu510
    sytfu510 [OP] Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    Same here, only got cell phone pics so far, wanted some good ones so I could see the details, won't see the truck in person for a while still.. But here's a couple from @dirt designs of the rear swing out he did. can mount rotopax or other accessories to it if I remove the tailgate.
    Also you can see the panels they built to seal the shock area. Bed was Rhino Lined as well.
    SonnyBones, Crom, Truck Girl and 8 others like this.
  3. Mar 14, 2018 at 2:45 AM
    #2303
    smokey_yota
    smokey_yota #FNGFTMFL
    Travis
    Bakersfield
    99 tacoma
    Prinsu Roof Rack Trail Gear Front Bumper Raceline Wheels Toyo AT3 Tires Fiberwerx Fiberglass Fenders And +4" Bedsides HELLA HID Bumper/Ditch Lights Rago Fabrication Ditch Light Brackets Bilstien Front Suspension Energy Suspension Bushings/Sway Bar End Links
    you guys gotta hurry back so i can see the updates on the truck lol. all i see are snaps of the guys messing around. seems like all play and no work over there haha
    sytfu510[OP] likes this.
  4. Mar 14, 2018 at 2:54 AM
    #2304
    sytfu510
    Alex
    Bay Area
    haha nobody wants to snap the BS, its depressing lol
    smokey_yota[QUOTED] likes this.
  5. Mar 14, 2018 at 2:55 AM
    #2305
    smokey_yota
    Travis
    Bakersfield
    99 tacoma
    you've got a good point haha
  6. Mar 14, 2018 at 7:50 AM
    #2306
    Speedo
    Speedo Well-Known Member
    Sacramento, CA
    2006 dcsb 4x4
    Wrecked!
    I love that rack/cage. Thing looks awsome.
  7. Mar 16, 2018 at 9:39 AM
    #2307
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    @sytfu510 what does your bump stop setup look like up front? I think you mentioned having super bumps, but was wondering how many spacers you were running if any. I will be cycling my DD kit this weekend but just realized now that I have everything all nice and painted up front that I had to weld in the Total Chaos Spacers to work with their stock length arms. My gut is that I will be cutting those off the bump stop mount with the DD lt kit though.
  8. Mar 16, 2018 at 9:59 AM
    #2308
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Zach, you prob already know this but it warrants repeating just in case... when you cycle your kit do it with the coil over mounted and your axles in. Pull the springs off and you will be able to cycle it with a jack under the LCA. The reason for this is that a lot of kits will cycle a few more inches than the CO or axles will. My guess is that with the vertical uniballs on your kit it is very likely that your axles will be the limiting factor that you need to ensure your bumps and straps are properly protecting. My Solo kit for example will cycle 2” more than my axles are capable of.
    Edit - please post some pics when you get it done, I've got the itch to upgrade my +2 Solo kit and that kit looks like a super good value with the fab'd spindles...I'm just hesitant about the steering radius so very curious to hear your feedback.
    sytfu510[OP] and Hawk373 like this.
  9. Mar 16, 2018 at 11:10 AM
    #2309
    zscott
    Zach
    Utah
    Yeah, I know my axles will be the limit on down travel for sure. Up travel I think I will end up setting bumps to limit how much my tires eat into the inner fenders but I will see. I will post pics and info on my build thread over the weekend. Took apart my stock axles last night which went surprisingly well, so all I have to do is reassemble with the new axles tonight and I will be ready for re-installation of all the parts.
  10. Mar 16, 2018 at 2:44 PM
    #2310
    sytfu510
    Alex
    Bay Area
    Originally I had no spacers in, my limiting factor was the fenderwell itself. However DD did add a spacer in to keep the wheel from jamming against the fenderwell. However I haven't seen it as I'm still deployed. So not much help unfortunately. However I'd like to see how yours turn out. I still think in the future I'll cut out the fenderwells and go with airbumps and utilize more of the travel.
  11. Mar 16, 2018 at 2:49 PM
    #2311
    zscott
    Zach
    Utah
    Sounds about right. I would love to come up with something like this that fits the tacoma.
    https://dirtkingfabrication.com/products/oversized-front-wheel-wells-dk-631964
    Build it so a cage was incorporated that you could tie a air bump into.
    sytfu510[QUOTED][OP] and Jim Bob like this.
  12. Mar 16, 2018 at 6:55 PM
    #2312
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
  13. Mar 16, 2018 at 10:34 PM
    #2313
    zscott
    Zach
    Utah
    Not sure, with my setup I am not as worried about the firewall. Maybe going up to 37s but the lt kit pushes the wheel forward a little so the only spot it’s looking like I need more clearance is the top of the wheel well
    stairgod[QUOTED] likes this.
  14. Mar 17, 2018 at 9:15 AM
    #2314
    stairgod
    stairgod NOOB
    Jo n
    PA/NJ
    2011 MGM Trail Limo
    Locked Boosted 35s
    Which kit you looking at?
  15. Mar 17, 2018 at 9:17 AM
    #2315
    zscott
    Zach
    Utah
    Already have the dirt designs kit that the OP has. It moves the wheel forward 1”
  16. May 9, 2018 at 10:50 AM
    #2316
    sytfu510
    Alex
    Bay Area
    One updated pic!
    Next up:
    New sliders from @JLee DOM w/kickout and filler plates
    Then off to Audiomobile for the rear sub update.
  17. May 9, 2018 at 10:54 AM
    #2317
    R09ster
    R09ster Well-Known Member
    Josh
    OK
    06 SSM DCSB TRD Sport
    debadged, Bilstein 5100 all around (fronts at 1.75" sport coils), Skyjacker softride 1.5" AAL, Firestone Ride Right Airbags, 17X8.5 Method NVs, 285/70/r17 Falken Wildpeak AT3W, US Offroad hidden winch mount, grillcraft grill, Sypder Auto projector headlights, blackedout LED taillights, bed extender, bedrack w/CVT Mt Shasta tent,
    Looks great! Bet it rides even nicer.
  18. May 9, 2018 at 11:38 AM
    #2318
    DannyBFresco
    DannyBFresco King Taco
    Danny
    NorCal (Martinez) & LA
    06 Tacoma 4x4 TRD Sport SWB
    Baja Kits +2 LT, Kings, 35" Falken AT3s, SUA
    So dope
    BassAckwards and t.hornstra like this.
  19. May 9, 2018 at 11:41 AM
    #2319
    sytfu510
    Alex
    Bay Area
    Thanks, I hear that from my buddies that drove it. Be a while before I get home.
    Thanks!
    jberry813 likes this.
  20. May 9, 2018 at 11:44 AM
    #2320
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    You let someone else deflower her !?
    ian408 likes this.
