Long Travel Taco
Discussion in '2nd Gen. Builds (2005-2015)' started by sytfu510, Sep 8, 2011.
  1. Jun 7, 2013 at 9:41 PM
    #681
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I meant on the road haha :p
  2. Jun 8, 2013 at 6:47 AM
    #682
    sytfu510
    sytfu510 [OP] Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    it does a bit, not a whole lot since my light bar is behind the windshield. In the future I may add some black vinyl to the hood. I get glare from the sun light a lot during sunrise/sunset.
    ooohhh, haha, don't really notice is a whole lot. My roof rack blocks most of it. ( my real intention for having a roof rack was to act as a wind blocker ) I'll try to get a front profile shot later.
  3. Jun 8, 2013 at 6:51 AM
    #683
    Blackdawg
    Monte
    Wyoming/St. Louis
    Interesting..well cool
  4. Jun 8, 2013 at 7:06 AM
    #684
    sytfu510
    Alex
    Bay Area
    thanks, I thought it would be worse. Waiting to see the impact on MPG's.
  5. Jun 8, 2013 at 12:06 PM
    #685
    Geem750
    Geem750 Well-Known Member
    Brandon
    Okanagan, BC
    07 DCLB
    Grillcraft grill, ultimate toytek 3" lift, shorty antenna, blacked out badges, rear diff breather, Kenwood 6990 HU, wet okoles, weather techs, extra D-rings, Cruisin offroad bolt on sliders, Treklights 18" LED bar
  6. Jun 10, 2013 at 12:34 AM
    #686
    kalieaire
    kalieaire i didn't know they stacked sh*t that high.
    Santa Clara County
    '12 TRD Off-Road 4x4 AC V6 6MT
    Adventure Trailers Atlas, Demello Sliders, BAMF Skids, PelfreyBilt Bumpers, SCS Ray 10
    Hey Alex, for the shower, I'm reading that there's real concern with regard to coolant leaks if the heat exchanger ever cracks for any reason. One issue is how to bleed the water out of the system when not in use so that if it gets down to (or below) freezing temperature, there isn't a crack from ice that causes a coolant leak. However, for drainage to be effective, the heat exchanger will need to be mounted vertically or inverted such that water will drain out when the lines are purged.
  7. Jun 10, 2013 at 7:17 AM
    #687
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Ill check back a couple pages and see if you mention it, but what size awning is that? I ordered the 79".
    I've only read that the heat exchanger gets hot and the water in it evaporates quickly. The waterlines are the only part that need to actually be drained, and if you have on board air it's easy enough to blow them out after each use so you don't get mildew and crap in them.
    I am new to the on board hot water idea though and have only read a bit on expo about them.
  8. Jun 10, 2013 at 9:31 AM
    #688
    sytfu510
    Alex
    Bay Area
    Honestly I have not tried them yet, I didn't build them until after my last trip. I am using caribiner type clips at the top & bottom so I can remove it easily.
    Guess could always blow it out with air. There's barely ever any water left in there as the way I have it mounted it drains most of it out. Worse case if the unit breaks I'll keep a double barb fitting and just connect both coolant lines together.
    I'm using the 6.5ft Awning. I also recently purchased the mosquito netting for it.
    As far as keeping the lines clear/clean I've been considering different options. Maybe use a tiny bleach mixture and blow it through the lines? May be hard to blow all the water out.
  9. Jun 10, 2013 at 9:34 AM
    #689
    JLink
    Josh
    Ocean, NJ
    Ok cool same one as mine then. Bobby offered me the 55" awning but 79" just seems way more useful. Do you have any pictures of it set up?
  10. Jun 10, 2013 at 9:45 AM
    #690
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    We're doing a 55" and a 99" on mine :eek:
    Go big or go home.
  11. Jun 10, 2013 at 9:45 AM
    #691
    sytfu510
    Alex
    Bay Area
    Not a great angle but:
  12. Jun 10, 2013 at 10:24 AM
    #692
    sytfu510
    Alex
    Bay Area
    lol nice!
    I've done the same, then I got branches and crap stuck in-between. So going to try these out next trail. If not they can serve other uses.
  13. Jun 11, 2013 at 7:34 AM
    #693
    JLink
    Josh
    Ocean, NJ
    Nice. That should be real cool next time it rains on a camping trip
  14. Jun 11, 2013 at 7:39 AM
    #694
    sytfu510
    Alex
    Bay Area
    yup. Doesn't work sometimes depending on the angle of the sun. lol So you may have to position your truck for best results.
  15. Jun 12, 2013 at 6:13 PM
    #695
    JLink
    Josh
    Ocean, NJ
    we usually dont have that problem out here :D
    its usually friday night when we get to camp and a torrential downpour starts. between the awning and an ez up shelter, we should be able to stay much drier and happier.
  16. Jun 12, 2013 at 6:19 PM
    #696
    sytfu510
    Alex
    Bay Area
    nice! I dropped off my annex room to have the zipper replaced. And hopefully get my truck back at the end of this week. It's at the shop getting a leak fixed. Then I can finally set everything up! RTT/Annex & Awning/Mosquito Net
  17. Jun 12, 2013 at 6:29 PM
    #697
    JLink
    Josh
    Ocean, NJ
    what kind of leak?
  18. Jun 12, 2013 at 6:41 PM
    #698
    sytfu510
    Alex
    Bay Area
    Front Diff started leaking over the weekend, and the Brake & ABS light came on. :eek: Didn't even go off road, just freeway.
  19. Jun 14, 2013 at 12:26 PM
    #699
    kalieaire
    Santa Clara County
    dang that sucks, where was the oil coming from?
  20. Jun 14, 2013 at 12:38 PM
    #700
    sytfu510
    Alex
    Bay Area
    Front Axle Seals. That will be fixed today hopefully.
