Long Travel Taco
Discussion in '2nd Gen. Builds (2005-2015)' started by sytfu510, Sep 8, 2011.
  1. Jul 3, 2013 at 6:13 PM
    #781
    RockyMtnTRD
    RockyMtnTRD Wanderlust.
    Noah
    Colorado
    '11 TRD OR
    hack job
    You think the shackles are worth it or no?
  2. Jul 3, 2013 at 6:14 PM
    #782
    sytfu510
    sytfu510 [OP] Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    Not sure, guess the grease-able would be nice since it could eliminate noise.
  3. Jul 6, 2013 at 1:30 PM
    #783
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    Alex could you send me the info on your fender flare guy? I might look into those. Would look sweet against the orange vinyl I ordered.
  4. Jul 6, 2013 at 1:37 PM
    #784
    benbacher
    Anchorage, AK
    Nevermind, found them. RHDesigns.
  5. Jul 6, 2013 at 8:15 PM
    #785
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    Checked the site and they don't list any for us...
    What am I missing here :confused:
  6. Jul 6, 2013 at 8:27 PM
    #786
    sytfu510
    Alex
    Bay Area
    Have to contact them directly, they don't have them on the website.
  7. Jul 6, 2013 at 9:04 PM
    #787
    benbacher
    Anchorage, AK
    Gotcha, I ran into that as well.
  8. Jul 7, 2013 at 7:43 PM
    #788
    RockyMtnTRD
    Noah
    Colorado
    '11 TRD OR
    hack job
    How'd you mount your Resi's in the rear? Cant exactly tell from the pictures.
  9. Jul 7, 2013 at 10:14 PM
    #789
    Justin
    Justin Well-Known Member
    Justin
    Colorado Springs
    2018 4Runner TRD-OR
    285/75/17 on SCS 6's. ADS front & rear w/ adjusters. Relentless front bumper & roof rack. BAMF sliders
    Hey how did you decide on what comm setup to go with?
  10. Jul 8, 2013 at 10:30 AM
    #790
    sytfu510
    Alex
    Bay Area
    I have some curved braces welded onto the frame that the clamps the resi's. You can get these from poly performance.
    Currently I'm just using the most basic CB, eventually I'll get my HAM license. But CB is most common so always need that.
  11. Jul 8, 2013 at 10:41 AM
    #791
    Justin
    Justin
    Colorado Springs
    2018 4Runner TRD-OR
    That's what I was thinking too. But where did you choose to mount it inside? And what made you choose that CB and antenna?
  12. Jul 8, 2013 at 10:46 AM
    #792
    sytfu510
    Alex
    Bay Area
    I mounted the box under the passenger seat, and put the handheld mount on the dash on the passenger side under the vent ( it's a blank removable panel ). Firestik is well known with CB's and have been around forever. Plus their tunable tip makes things a lot easier. Price wise it isn't much more than the cheaper ones so better off getting the Firestik.
  13. Jul 8, 2013 at 10:59 AM
    #793
    Justin
    Justin
    Colorado Springs
    2018 4Runner TRD-OR
    For the blank part on the dash, can you just buy a mouunting bracket from radio shack or something and drill it thru there to mount it? Or is there a more efficient way?
  14. Jul 8, 2013 at 2:49 PM
    #794
    sytfu510
    Alex
    Bay Area
    The bracket comes with the CB, it's just a small clip piece, that the mic can hang on.
  15. Jul 8, 2013 at 4:57 PM
    #795
    kalieaire
    kalieaire i didn't know they stacked sh*t that high.
    Santa Clara County
    '12 TRD Off-Road 4x4 AC V6 6MT
    Adventure Trailers Atlas, Demello Sliders, BAMF Skids, PelfreyBilt Bumpers, SCS Ray 10
    George mounted his in the glove box. His unit is a little bit larger (Bearcat 980 SSB) so it didn't fit in any of the other normal locations you'd try to mount it. I have the same setup, but didn't have the free prefabbed glovebox. :p
    For my install, first is to remove the glovebox completely, remove the plastic panel that goes over the glovebox when closed, mount the radio with some post office box brackets I got from OSH, Once that was done, cut some holes for the antenna, power, and external speaker.
    Wherever you put it, make sure there's space for the antenna cable to come out with a smooth curve. If you have SWR issues, generally it's caused by there being a kink, a right angle, or someplace where the cable has a radius of less than 3". If you have experience soldering, I strongly suggest fabricating your own custom length cable from RG-58A/U cable. 23' and 11" is the length you need to have a nearly perfect full wavelength. Other great choices for cable length are 1/2 that or 1/4 that.
    If you by any chance decide to use RG-8X, please note the velocity factor is probably going to be ~ .75, which equates to 27' and 2.1" for a full wavelength.
  16. Jul 10, 2013 at 1:11 PM
    #796
    Justin
    Justin
    Colorado Springs
    2018 4Runner TRD-OR
    Okay gotcha. And how much coax did you use?
  17. Jul 10, 2013 at 1:59 PM
    #797
    Brock19
    Brock19 Well-Known Member
    brock
    southern utah
    Trail gear bolt-on sliders. BLHM, AUX relayed fuse block, Plastiderp, Diff breather mod, Paracord handles, Trex eyelids, Spacer lift (for now), Magnaflow offroad series cat-back exhaust. sound system, limo tint on all windows excluding windshield. all pro rear bumper with side plates
    what do the cables on the upper part of the bumper that connect to your roof rack do?
  18. Jul 10, 2013 at 2:05 PM
    #798
    MY50cal
    Mojo
    Camden County, NC
    Yep.
  19. Jul 11, 2013 at 11:33 AM
    #799
    Justin
    Justin
    Colorado Springs
    2018 4Runner TRD-OR
    Which size antenna?
  20. Jul 11, 2013 at 1:11 PM
    #800
    MY50cal
    Mojo
    Camden County, NC
    Yep.
