Long Travel Toyota Gallery
Discussion in 'Long Travel Suspension' started by nelson18matt, Jan 17, 2011.
  1. Jul 25, 2011 at 11:57 AM
    #361
    BMiller421
    BMiller421 FMLYHM
    Brandon
    Bakersfield, CA
    05 Pre-runner
    LT, Kings, Fabricated Trucks Worldwide For The Win, K&N and Doug Thorley LT Headers
    35x12.5 tires..17x9 eagle wheels..i dont remember the actual back spacing but I'm pretty sure they are @ 4.5..
  2. Jul 25, 2011 at 11:59 AM
    #362
    BMiller421
    BMiller421 FMLYHM
    Brandon
    Bakersfield, CA
    05 Pre-runner
    Thanks Matt..hoping to have it buttoned up enough to make it up to gorman on saturday for some light to moderate testing..
  3. Jul 25, 2011 at 12:07 PM
    #363
    nelson18matt
    nelson18matt [OP] Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    sweet. i'm planning on be at the gorman run. hope to see ya out there
  4. Jul 31, 2011 at 9:19 PM
    #364
    BMiller421
    BMiller421 FMLYHM
    Brandon
    Bakersfield, CA
    05 Pre-runner
    From the Gorman run on 7/30..
  5. Jul 31, 2011 at 9:26 PM
    #365
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    sweet pics! dam that does sit high
  6. Jul 31, 2011 at 9:44 PM
    #366
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
    That thing is massive!!!!
  7. Jul 31, 2011 at 9:44 PM
    #367
    username
    username Fluffer
    Pendleton, Or
    05 Taco with some crap welded to it
    mostly stock
    Yessir. I still haven't figured out how lift spindles make you go faster yet. I understand most fellers say it's for ground clearance and whatnot, but I always see them in my rearview bucking like a fat chick getting tazed.
  8. Aug 1, 2011 at 7:22 AM
    #368
    BMiller421
    BMiller421 FMLYHM
    Brandon
    Bakersfield, CA
    05 Pre-runner
    Thats what she said..haha ha..
  9. Aug 1, 2011 at 7:27 AM
    #369
    BMiller421
    BMiller421 FMLYHM
    Brandon
    Bakersfield, CA
    05 Pre-runner
    I feel that fabricated spindles are essential to a LT kit..and it actually didn't feel that high on the trail..
    And the only way to go faster is by putting 10,000+ stickers on your rig..
  10. Aug 1, 2011 at 7:30 AM
    #370
    97yota4wd
    Eric
    Mesa, AZ
    well if you get lift spindles on lt you get more uptravel right? which is really good!
    but you want it lower right? i wonder what you could be besides lighter spring rates.
    if you do keep it that tall you should go with some 37s :cool:
  11. Aug 1, 2011 at 8:12 AM
    #371
    BMiller421
    BMiller421 FMLYHM
    Brandon
    Bakersfield, CA
    05 Pre-runner
    Not really getting more up travel..just more clearance in the wheel well on full compression..
    I'm still doing research to see if I can get it a few inches lower rather than getting softer springs..cus the front felt great running thru the bumps and whoops this weekend..
    37's..one day..but the 35's are still brand new..less than 500 miles on them..
  12. Aug 1, 2011 at 8:30 AM
    #372
    Socalrunner
    Socalrunner Toyota Its Like A Jeep Thing Only Better
    Glendora
    2010 TRD Offroad 4x4 DCSB
    Icon Coilovers
    I was told by Solo Motorsports that they could lower my truck by cutting the coilbucket and running a 10 inch coilover with shock hoop. I would like to have the a arms level
  13. Aug 1, 2011 at 9:38 AM
    #373
    BMiller421
    BMiller421 FMLYHM
    Brandon
    Bakersfield, CA
    05 Pre-runner
    Thats what I want to do!!
  14. Aug 1, 2011 at 9:42 AM
    #374
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    you would have to do a lot of cutting in the wheel well to fully utilize all that up-travel with a 10" shock and also a cross brace/shock cage to reinforce. It would be quite a bit of work. If you want to run larger than 8", go at least 12" to utilize dual rate springs.
  15. Aug 1, 2011 at 9:58 AM
    #375
    Socalrunner
    Glendora
    Icon Coilovers
    Im not going to do that. Im going custom. Just got to save up a little money
  16. Aug 1, 2011 at 11:44 AM
    #376
    Bookworm
    Bookworm Well-Known Member
    Rob
    Readin ur threads, learning ur shit
    I always think that watermark says "lol" before I scroll down farther
  17. Aug 1, 2011 at 11:47 AM
    #377
    Unknown
    Unknown He who angers you conquers you
    Brian
    Los Angeles
    Unknown
    Unknown
    It does ;)
  18. Aug 1, 2011 at 11:54 AM
    #378
    username
    username Fluffer
    Pendleton, Or
    mostly stock
    The problem with doing that is that the uniballs bind limiting travel, then steering. Even with vertical uniballs and heim steering the geometry gets fucked up real quick with arms as short as ours are when you start swinging them in such a long arc. The next logical step is to center mount the arms, but then I'd lose 4wd. I understand strong spindles are important, and I gusseted mine appropriatly. The extra ground clearance provided by lift spindles is nice, but it comes at the cost of a higher center of gravity and loss of high speed stability, imho.
  19. Aug 1, 2011 at 12:12 PM
    #379
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    ^You still have a ball joint in your spindle lower or is that replaced on your kit with uniball?
  20. Aug 1, 2011 at 12:22 PM
    #380
    GatorComa
    GatorComa Well-Known Member
    Robby
    St. Augustine, FL
    2011 TRD OR 4x4
    :eek: that's sick!
