Long Travel Vs 4WD
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mart141, Jun 13, 2020.
  1. Jun 14, 2020 at 1:10 AM
    #41
    Mart141
    Mart141 [OP] Member
    Angelo
    1999 Tacoma Prerunner
    Haha, I’ve always been around rock crawling but it’s never peaked my interest as much as LT set ups. The problem is my whole family loves rock crawling and 4x4’s and I don’t want to be stuck at the bottom of a mountain. I used to camp at airport flats near on of the entrances of the Rubicon, so I know there’s some great places for 4x4’s. I’m just not from the mountains and won’t be able to get to places I need to without a 4x4.
  2. Jun 14, 2020 at 1:11 AM
    #42
    Mart141
    Mart141 [OP] Member
    Angelo
    @Nicklovin I’ll definitely check it out! Thanks for the reply!
  3. Jun 14, 2020 at 1:12 AM
    #43
    Nicklovin
    Nicklovin Mall Crawlin Through Life
    Nick
    Huntington Beach, CA
    00 The Tunda - 0̶4̶ P̶r̶e̶r̶u̶n̶n̶e̶r̶ - 0̶1̶ O̶v̶e̶r̶l̶a̶n̶d̶e̶r̶ - 07 FJ Mall Crawler Xtrme
    Tacoless
    Well it sounds like you may need a 4x4 if they are doing extreme rock crawling. Granted keep in mind that with enough skill and a rear locker you can do plenty in a 2wd, especially with LT
    another fun spot for you to check out for go fast stuff is California City
    boston23 likes this.
  4. Jun 14, 2020 at 1:13 AM
    #44
    Mart141
    Mart141 [OP] Member
    Angelo
    To everybody commenting, I appreciate the replies! I’m definitely new to the community and just want to see my options! I just want something special and have no problem investing a lot of time into this project. I don’t expect it to be done anytime soon but once it is, I’ll be sure to show the results!
    otis24 and boston23 like this.
  5. Jun 14, 2020 at 1:15 AM
    #45
    Mart141
    Mart141 [OP] Member
    Angelo
    That’s about an hour away I’ll definitely look into it. With everyone getting older it’s less about rock crawling and more about being able to get to our property up North and having a good time. Everyone has a 4x4 but their mostly for show. They’re not built for extreme crawling anymore which is why I thought I could get away with a LT set up.
  6. Jun 14, 2020 at 1:17 AM
    #46
    Mart141
    Mart141 [OP] Member
    Angelo
    Not sure if you seen some other posts but I’m definitely up for trying to design something and build it myself with family. Hopefully that will make it less of a money pit if I’m not spending 5K+ on a basic LT kit.
  7. Jun 14, 2020 at 9:12 AM
    #47
    wesheppy
    wesheppy Member
    Weston
    1998 Tacoma 4x4 4in Lift
    Spc upper control arms Eibach springs Bilstein shocks Rear shackles
    Go with total Chaos long travel, trd supercharger, 37s, and rear diff lock.
  8. Jun 14, 2020 at 9:37 AM
    #48
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    Also in California.
    I use 4 wheel drive a lot.
    I’ll never own a non 4 wheel drive vehicle while living here.
  9. Jun 14, 2020 at 10:05 AM
    #49
    04taccoo
    04taccoo Well-Known Member
    Cyrus
    San Diego
    2004 Tacoma prerunner 4x4 double cab
    4x4 conversion
  10. Jun 14, 2020 at 10:22 AM
    #50
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Lol... I get it. (just to make sure we're clear, just givin ya a bit of shit earlier).
    As for your delima... it's really not a delima. You seem to think you don't know if you want to go LT and have it make you have problems if you need 4wd... and you don't want to go 4wd and have it cause problems when you're bombing down roads like a "Pre-runner."
    So let me just help you out with that...
    LT is not going to cause any problems for you when crawling, in fact it would probably help... because you have more travel and you can run larger tires.
    4wd is not going to hurt you when you are bombing down the fire roads using your long travel...
    So... the answer is you need both. Especially if you have family/friends that 4wd and you "don't want to be stuck at the bottom of the mountain."
    I was in a very similar situation you're in right now a couple years ago. My truck was a 2wd Prerunner. Like I said in an earlier post. 4wd was last year for me, this year is the big suspension upgrade, next year will be re-gear. I'm more in to the rock crawling/trail blazing and the way I have my truck set up, it would be a HUGE deal to make glass fenders work, so I'm pretty sure I will not do long travel. But that's not because LT is bad for 4wd... it's because I would have to completely rebuild my rack system in the bed, my storage boxes, my rear bumper (possibly)... and I would have to figure out a way to make my snorkle fit into glass fenders (it has been done, but it's a pain in the ass)
    But... in short... you need LT and 4wd... I'd start with 4wd.
    chrslefty, otis24 and Kwikvette like this.
  11. Jun 14, 2020 at 4:11 PM
    #51
    Nicklovin
    Nick
    Tacoless
    Like Matt said above, sounds like you need both. And trust us, long travel is always a money pit.... but it’s oh so good!
  12. Jun 14, 2020 at 4:58 PM
    #52
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
    I was in the same position, go 4wd first and if you end up wanting to do go fast stuff then start down the LT rabbit hole
