Long trip ahead... suggestions encouraged
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tacoman00, Dec 27, 2016.
  1. Dec 27, 2016 at 7:23 PM
    tacoman00
    tacoman00 [OP] Your Average Joe
    Rockville, MD
    2021 TRD Off-Road DCSB
    Toytec BOSS 2.0 lift, 18x9 Fuel Rebels, 32” BFG AT K02.
    Hi all,
    A week from today I will be making a 10 hour round-trip to Snowshoe Ski Resort in West Virginia. I am fully confident that my truck will make the trip no problem, but I want to be proactive considering it's approaching 160k miles. Is there anything in particular that you all would be sure to check, change, maintain prior to making the trip? I'm getting a VA state inspection done tomorrow and plan to tell the mechanic to look it over good, but no peace of mind is like that of your own after you've done your own investigating.
    Suggestions encouraged!
  2. Dec 27, 2016 at 7:44 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Check that all fluids are at appropriate levels and not out of date, brake pads in good condition...
    and a bump for more useful info from others...
  3. Dec 27, 2016 at 7:46 PM
    Pigpen
    Dan
    Northwest Montana
    As long as your scheduled maintenance is up to date and it runs fine... Just have a safe and fun trip.
  4. Dec 27, 2016 at 7:46 PM
    Pigpen
    Dan
    Northwest Montana
    It's only a 10 hour drive. That's a day trip out here.
    Jeffas7 likes this.
  5. Dec 27, 2016 at 7:49 PM
    2015whitetaco
    2015whitetaco Well-Known Member
    Pleasant Hill
    2000 Ford F-250 7.3 powerstroke 96 4runner POS
    yeah as long as it is up to date with maintenance you should be fine
    i am about to do a 9 hour one way drive
    ill probably be stoping half way to do an oil change on the side of the road
  6. Dec 27, 2016 at 7:51 PM
    txmxer
    txmxer Well-Known Member
    California and Texas
    06 dc tacoma
    - Total Chaos 3.5 Long travel kit - Fox 2.5 coilovers w/ resis -Prerunner bumper -Fiberglass front fenders -Fiberwerx tt bedsides - Dmz Sua - fox 2.5x16 triple bypasses
    I regularly made 20 hour trips to school, you'll have no problem. Just make sure scheduled maintenance is up to date, air filter is clean, and most of all your tires. Tires are the biggest thing, making sure lugs are tight, and I have a lot of modifications done on my tacoma so I just made sure everything was torqued down properly. Kept an eye on hub temperature and tight lug nuts when I stopped for gas.
    Wouldn't hurt you to check your belts if you haven't changed them recently. I had my u joints start to go bad in the last 2 hours of my trip once, man that was nerve wrecking haha
  7. Dec 27, 2016 at 7:59 PM
    HawkShot99
    HawkShot99 Well-Known Member
    Kingston, NY
    13' Silver DCLB TRD Sport - Sold
    Your joking right?:der::notsure:
    Pigpen likes this.
  8. Dec 27, 2016 at 8:02 PM
    ThomasMore66
    Dallas/Fort Worth & Durango
    Just did 2 13 hour trips in my 22 year old FZJ80. Proper maintenance and you're good to go. Only your ass will hate you.
  9. Dec 27, 2016 at 8:06 PM
    Clearwater Bill
    Billy
    Largo Florida
    If it's been properly maintained, there's really nothing to do but go.
    I do make a last minute check of fluids under the hood, tire pressures (don't forget the spare).
    You do carry a kit of handtools, right? And an extra qt of oil isn't a bad idea on a longer trip.
    Since it's winter, I'd be carrying at least the basics to survive 24 hours if you find yourself stranded on the side of the road.
  10. Dec 27, 2016 at 8:09 PM
    2015whitetaco
    Pleasant Hill
    no i have odd when it comes to wanting the oil change at exactly 5000 miles ill be hitting that about 2 hours into the trip so i may stop for lunch and do an oil change it only takes 15 minutes
  11. Dec 27, 2016 at 8:11 PM
    Pigpen
    Dan
    Northwest Montana
  12. Dec 27, 2016 at 8:11 PM
    2015whitetaco
    Pleasant Hill
  13. Dec 27, 2016 at 8:13 PM
    ThomasMore66
    Yeah, retardation setting in. 15 mins? Just drain it on the side of the road? In the ditch? Nice.
  14. Dec 27, 2016 at 8:14 PM
    Taco Addiction
    Taco Addiction We found Jimmy
    Houston, TX
    2004 Black TRD Offroad
    Kings, SCS Wheels and other mall crawling crap
    Bill beat me to it.
    If you are traveling through winter weather, would recommend blankets, water, some protein bars, flashlight, batteries, matches/lighter, good GPS, tools. I travel up North a fair bit to my families ranch and pack like this. Small bag, not much room but you never know.
    Also, let others know where and when you will be.
  15. Dec 27, 2016 at 8:14 PM
    Clearwater Bill
    Billy
    Largo Florida
    I think he said 'wow'. And I agree.
    Road miles are easiest on oil there is. Stable operating temps.
    You're already short cycling your OCIs. So just change it when you get back.
    Know you probably won't, but in all honesty, you're wasting your anxiety/OCD over nothing.
  16. Dec 27, 2016 at 8:34 PM
    2015whitetaco
    Pleasant Hill
    its doesn't take long to change the oil once you've done it a few times and if you have the proper tools its easy
    no I wouldn't drain it into a ditch i would put it in an oil catch and dispose of it properly
    yeah no I'm not going to change my oil in the middle of a trip I will do it as well as a few other maintenance things the night before I leave but I'm not going to do it during the trip
    but if I was going to I would do it properly and dispose of old oil
    i just can't help but troll a little
  17. Dec 27, 2016 at 8:38 PM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    As long as your maintenance is up to date, just go. You'll spend more time prepping for the trip and the "what if's" especially since it's winter.
    I've got 173K on my 09 DCSB and no doubts I can pack and go on a 10 hr road trip without any worries.
  18. Dec 27, 2016 at 8:41 PM
    2015whitetaco
    Pleasant Hill
    I'm set up now to where i can go on a week long road trip in less then an hour and not worrie
  19. Dec 28, 2016 at 3:42 AM
    bucktales
    bucktales *Retired* curmudgeon
    Litchfield County Ct.
    2012 TRD Sport AC / 2014 FJC/ 1972 Rally Nova
    Extra jug of washer fluid won't hurt.
    BassAckwards likes this.
  20. Dec 28, 2016 at 3:55 AM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    As said, maintenance up to date, no problems. Pack for problems, extra windshield washer fluid, warm clothes, a shovel, flares. Water and snacks.
