Longer Ball Joint for UCA ?
Discussion in 'Suspension' started by xtremez, Sep 16, 2011.
  1. Sep 16, 2011 at 8:05 PM
    xtremez
    xtremez [OP] Member
    Bangkok, Thailand
    08 Hilux Dbl Cab 4x4 2.7vvti
    MegaSquirted LPG, MSIIv3.57 with MS Extra code, Lifted 3"F/2"R, 100Wx2 Spot Lights
    I want to relief some stress on the stock BJs, and looking for less expensive way other than going with the new UCA from TC, camburg, etc. Does anyone know if there's any vendor out there that makes 'Longer Ball Joint' ? Does MOOG makes any or do they just make standard length?
    Thanks,
  2. Sep 16, 2011 at 8:08 PM
    Superx2
    Superx2 Well-Known Member
    Joey
    Iowa
    im gonna guess no. probably wrong, but have not heard of such a thing. i wouldnt screw around with getting shit "the cheaper route" save your $$ and go the right way!
  3. Sep 16, 2011 at 8:10 PM
    06RadiantRed
    06RadiantRed Well-Known Member
    CA-Bay Area
    2006 Tacoma 4x4 TRD Off Road - RadRed!!
    ICON ext. Travel Coilovers, TC UCAs, Fox 2.0 FJ Rear Shox + 2"AAL rear
    I have never heard of this. Wouldnt the ball joint still be stressed at the same angle? This is why the uniballs are great because they can rotate farther. And a longer one would increase the distance between your UCA and LCA, causing some geometry issues? Altho it probably not very far, just a thought. :(
