Longer brake lines required???
Discussion in '1st Gen. Tacomas (1995-2004)' started by Mainmoe02, Jun 21, 2013.
  1. Jun 21, 2013 at 3:31 PM
    Mainmoe02
    Mainmoe02 [OP] Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    Trying to figure out if I need longer brake lines if I add around 1"-2" rear lift shackles? I ordered the ToyTec adjustable shackles :D so I can adjust the rear ride height to my liking. I have DAKARS that provide around 2.25" of lift. So would going up to about 3.25" - 3.75" of total lift on the rear require longer brake lines? If I do need them, is it a difficult job on a 1st gen?
    I'm a 2001, 2WD (prerunner) TRD SR5 DCSB.
    Thanks
  2. Jun 21, 2013 at 5:24 PM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    Yes. get the longer brake line. You might be fine with the stock one on the road but if you flex the suspension at all it could stretch and pop the brake line. With the lift you have and the longer shackles I would definitely get the longer brake line in the rear.
  3. Jun 23, 2013 at 12:39 AM
    ilove_taco_ma
    ilove_taco_ma Well-Known Member
    fresno, california
    95 tacoma 4wd LX
    nothing, all stock expect got a OE replacement air filter K&N.
    get a steel braided line. you're be at ease knowing you have longer brake lines.
