Longer brake lines ?
Discussion in 'Suspension' started by C4vettrn, Sep 14, 2022.
  1. Sep 14, 2022 at 9:56 AM
    C4vettrn
    C4vettrn [OP] Well-Known Member
    Randy
    Ft. Wayne IN.
    2015 trd 4x4
    17" SR8's
    Putting a Eibachs pro stage 2 suspension on this next week. If I stay under 2" will I need extended brake lines ? Also was thinking about there 1" blocks for the rear. I have never ran blocks and if it were more then an 1" I wouldn't even consider them. The add a leaf is another option but only come in 1.5 " of lift and I don't want that much or a stiffer ride. INPUT!
  2. Sep 14, 2022 at 9:59 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    No to brake lines.
    AAL over a block every time and twice on Sunday.
    drizzoh likes this.
  3. Sep 14, 2022 at 10:05 AM
    Crikeymike
    Crikeymike ExitOffroad.com Vendor
    Jax Beach, Florida
    No brake line change is needed
  4. Sep 14, 2022 at 10:07 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    If you stay under 2" you should not need extended lines.
    As for the AAL vs block discussion it kind of comes down to how you use the truck. The AAL is generally regarded as the superior option over a block, but if you are running with zero weight in the bed of the truck a block might be a better option. An AAL provides lift by virtue of stiffening your existing leaf pack. If you are completely stock an AAL will stiffen your ride noticeably. I prefer to recommend a small block for someone bumbling around town for the most part as they'll generally experience a more comfortable ride. If you were asking about a 2"+ block I would be on team AAL.
    BassAckwards likes this.
  5. Sep 14, 2022 at 10:41 AM
    C4vettrn
    Randy
    Ft. Wayne IN.
    2015 trd 4x4
    17" SR8's
    Kind of what I was thinking. I went ahead and ordered the AAL because I do hull stuff at times. I think on my 2nd gen I used a combo of one leaf from the AAL and kept my overload and it gave me a little more lift and better ride then the AAL pack and removing overload. Can't remember it's been awhile. I only want 1.5" lift in front but if I remember correctly I went a little higher because after alignment and break in period it settled.
  6. Sep 14, 2022 at 2:31 PM
    C4vettrn
    Randy
    Ft. Wayne IN.
    2015 trd 4x4
    17" SR8's
    One more question :). Will the pinion angle change enough with a AAL that I need to look at angle shims ? I forgot what the exceptable angle or degree range is for drivelines.
  7. Sep 15, 2022 at 8:32 AM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Nada, the change is minimal for pinion angle. If you are still running bolt in shocks, you shouldn't need brake lines like said above. One thing I do on some kits I install, is bend the brake line bracket on the axle slightly so the hardline/softline connection isn't pointed towards the ground. Gives the brake lines another inch or two of travel.
  8. Sep 15, 2022 at 1:28 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    As long as you are using OEM or OEM replacement shocks, your suspension travel doesn’t change enough to require extended brake lines. Basically all you are changing is where the suspension sits at rest within the stock range of travel. The max and min points remain the same.
  9. Sep 16, 2022 at 2:08 PM
    C4vettrn
    Randy
    Ft. Wayne IN.
    2015 trd 4x4
    17" SR8's
    Thanks
