Longer Front Wheel Studs 95 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by agrogers, Dec 15, 2009.
  1. Dec 15, 2009 at 1:57 PM
    agrogers
    agrogers [OP] New Member
    Rough Country Suspension Pacer 15" Wheels with 33/12.50 BFG Mud Terrains
    I have the same problem the guy with the 05 Tacoma had; the front wheel studs are not long enough for my wheels and I am having a difficult time finding studs that are a quarter inch longer. Where do I get them I need 12. The rear fits just fine
  2. Dec 15, 2009 at 6:26 PM
    tacoman101
    tacoman101 Well-Known Member
    scott
    vermont
    2001 Tacoma sr5 xtra cab 4wd
    blue led headlights, 285/75/16 grabber AT2's, custom pedals, custom shifter, flowmaster 40 series muffler, bedlinered fender flares, 2.5" lift kit via shackles and spacers, custom exhaust out the back, chrome exhaust tip, and Herculined bed, Weathertech floormats, Cabelas Trail Gear Camo Seat Covers ... Nice thing was I got the truck for $4000
    I'd buy some Spidertrax wheel spacers
  3. Dec 15, 2009 at 7:33 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    I think his wheels need to get CLOSER to the hubs, not farther...
  4. Dec 15, 2009 at 7:35 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    well i think the spacers would work but there must be something different or wrong with the wheels
  5. Dec 15, 2009 at 8:07 PM
    MowTaco
    Kansas
    Maybe I'm misunderstanding here. The studs are too short, not allowing the lug nuts to thread properly, correct? Wouldn't adding a spacer, which moves the wheel even farther out, make the problem worse? :confused:
  6. Dec 15, 2009 at 8:28 PM
    98lowflyingtacoma
    98lowflyingtacoma Well-Known Member
    Phoenix
    1998 Tacoma Prerunner
    if the spacer works, attaches, the studs on the new spacer are longer and would attach to new modern wheels
  7. Dec 16, 2009 at 5:14 AM
    agrogers
    The lug studs up front have to go through the hub and the rotor before going through the wheel, and while the lug nuts thread up and hold the wheel on (6000 miles I retorqued them to about 150 ft lbs after 100 miles) a quarter inch more thread would be desired just to make silly mechanics feel better.
    The spidertrax would work however I am running 33/12.50R15's and I'd like to keep them in the fender wells so I don't have to get those goofy ass fender flares
  8. Dec 16, 2009 at 5:34 AM
    tacoman101
    scott
    vermont
    hmmm seems like you have a real dilema now
  9. Dec 16, 2009 at 2:49 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    Here is a link to longer wheel studs http://www.ezaccessory.com/Wheel_Studs_s/30.htm
    See if they have what you need, I saw 12 X 1.5 in 70 and 74 mm in the splined type Post back if this works or not. I am assuming splined is what you need but they have threaded also. I am going to need longer studs also to allow a shim plate on my wheel hub instead of Spider Trax type of adapter
  10. Dec 16, 2009 at 4:37 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    We have extended thread lug nuts that reach farther into the wheel to get a better bite on the studs. They may work for you.
  11. Dec 16, 2009 at 5:26 PM
    ScottyB
    ScottyB Well-Known Member
    Scott
    Kailua, Hawaii
    01 PreRunner TRD V6
    Bilstein 5100's
  12. Dec 16, 2009 at 5:47 PM
    kevhogaz
    kevhogaz Low Speed, High Drag
    Queen Creek, Arizona
    SR5 PreRunner
    3" lift front & rear, Air Raid Intake System
    150 lb/ft for lug nuts? Holy crap dude, that's a lot!! Toyota suggests about 80 lb/ft for their aluminum wheels. I'd go with red Loctite if you're that worried about it!
  13. Dec 16, 2009 at 8:32 PM
    MowTaco
    Kansas
    Ahh, I thought he was just using a spacer that fit over the studs between the inside of the rim and the hub.
  14. Dec 18, 2009 at 2:05 PM
    kevhogaz
    SR5 PreRunner
    Dan, are those listed on Wheeler's site somewhere, I couldn't find 'em listed?
