Longer rear bumpstops
Discussion in 'Suspension' started by mh.meier, Feb 7, 2012.
  1. Feb 7, 2012 at 4:00 PM
    mh.meier
    mh.meier [OP] PB MIKE Vendor
    MAD MIKE
    Flagstaff AZ
    Truck Norris Silver Unicornimus Prime
    2008 Tacoma DCLB 4X4 SR5 -Pelfreybilt Steel front single-hoop bumper(, color matched -Heretic Studios 20" single row light bar -Rigid Dually D2 Flood pods -KM FABRICATION custom 1/4" steel bumper mounts -Warn ZEON Platinum 12,000lb Winch -Pelfreybilt Rear HI-Clearance bumper with swingout -NATO can carrier -Folding Aluminum table -RIGID SRQ reverse lights -Full Pelfreybilt skids -ARB air compressor under the hood -Custom CO2 Setup -KMFAB Custom ext brake line brackets -KMFAB Bedrack -Camping Lab MANSION RTT -ARB Touring 6' Awning -Litra Torch camping light -CTC Bed Cap, color matched -Toyota OEM bedmat -KMFAB bed reinforcement -AVID Offroad weld on slider -BAMF Bed corner tie down brackets -Custom chopped front fenders -Front custom satoshi gille, color matched -OTTRAW switches -King Ext Travel front CO's -King 700# coils -Total Chaos Uni-ball UCA's -Dirt King stock length lowers (soon to be installed) -Sway-A-Way 2.0 rear ext travel shocks -All-pro Expo LEaf packs w/ custom bumps -35" Goodyear Wrangler MTR's w/ Kevlar -16" SCS SR8's in Black -Custom Retrofits -Smoked Tails -Airflow Snorkel -Cobra 29LX CB with PA and the fixins' -KMFAB CB antenna mounts -Pioneer in dash DVD with Nav -Weathertech mats
    I am getting the All Pro Expedition leaf spring pack and the Billy 5100 RCD which fits with the 4" lift provided by the leafs. The only problem is the Billy's are 27" extended length and I am afraid the shocks will bottom out before the bumpstops hit.Are there any extended bump stops out there or is there anyway to make them? I tried searching but I couldnt find anything specific. Any help would be great. Thanks.
  2. Feb 7, 2012 at 4:07 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    as long as your not hitting high speed trails or overloading the bed you can invert the bumps to hit a shackle flip kit fairly easily. you can also find hydro set ups to do the same.
    here is my set up - very simple
    you could do the same with a longer bump stop from any vendor
  3. Feb 7, 2012 at 4:19 PM
    Supra TT
    Supra TT Solid Axle FTMFW!!
    Eric
    Lafayette, Indiana
    2000 SAS D60 F/R
    SAS.. Need I say more.
    polyperformance, under suspension components, bump stops
  4. Feb 7, 2012 at 4:26 PM
    mh.meier
    MAD MIKE
    Flagstaff AZ
    Thanks alot guys.
  5. Feb 7, 2012 at 4:28 PM
    mh.meier
    MAD MIKE
    Flagstaff AZ
    Any recommendations Supra TT?
