Longer studs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by S_cantrell_, Feb 5, 2016.
  1. Feb 5, 2016 at 2:00 PM
    S_cantrell_
    S_cantrell_ [OP] Well-Known Member
    Derrick Lewis
    Trying to figure out how to replace the studs in the rear on my tacoma. I did the front already but cant figure out how to do the back because the studs i bought are longer than the orginal ones.
  2. Feb 5, 2016 at 2:03 PM
    Rhyno
    Rhyno Well-Known Member
    Shane
    2008 Tacoma DCSB TRD Sport
    You'll need to remove your brake drums, I was able to swap my studs for longer ones without any further dis assembly of my rear brakes.
  3. Feb 5, 2016 at 2:04 PM
    S_cantrell_
    Derrick Lewis
    How much longer are the ones that you installed?
  4. Feb 5, 2016 at 2:08 PM
    Rhyno
    Shane
    I can't remember for sure, was a couple years ago, about 1/2"-3/4" longer I believe.
  5. Feb 5, 2016 at 2:53 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Remove the drum.
    Knock them out.
    Insert the replacement studs.
    Put washers on the studs and use the nuts to pull them up snug.
