Longer than normal cranking
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Mnewman03, Mar 20, 2016.
  1. Mar 20, 2016 at 7:58 PM
    Mnewman03
    Mnewman03 [OP] Well-Known Member
    2016 MGM DCSB TRD OR
    Got in my truck today and hit the start button, it turned over for about 6-8 seconds without firing. Once I realized it wasn't starting, I hit the button again to shut it down. A few seconds went by and it started up just fine. Hasn't happened again, just thought I would share and see if anyone else has had this happen.
  2. Mar 20, 2016 at 11:31 PM
    sndtubes
    sndtubes Active Member
    2016 TRD Off Road 6sp Manual
    I have 6 MT, so no button start. However I have noticied that sometimes I have to crank it 2 or 3 times before it will start. My 2003 Honda Element always starts on the first try
  3. Mar 21, 2016 at 12:40 AM
    Mnewman03
    I found another thread were someone had a similar issue, and it turned out to be a dead cell in the battery. I'll update this thread if it happens again.
  4. Mar 21, 2016 at 1:20 AM
    xTacoma16x
    xTacoma16x Well-Known Member
    TRD sport 2016
    Fuel pump, leaky injectors could cause this issues. Your fuel rail needs to stay fuel primed for fast start, if it's draining back to tank than it takes time to pump fuel to its working pressure. It's also could be bad spark, bad ground to engine, and many other other things that would throw CEL. First thing I would check is battery voltage and fuel pressure
  5. Mar 21, 2016 at 7:00 AM
    Mnewman03
    I'm not checking anything, I paid 34k for this truck, Toyota can spend their time and money.
    crepr12 and smitty99 like this.
