Longer wheel studs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jonny890, May 23, 2020.
  1. May 23, 2020 at 8:12 AM
    Jonny890
    Jonny890 [OP] New Member
    Jonathan
    North Carolina
    08 Red Tacoma SR5 Double Cab
    I have a 08 tacoma with a 2.5 inch leveling kit running on a little bigger than stock size all terrian tires with the stock wheels. Going for the stock look with a little more aggressive stance I guess you can say but my issue is, there's not a lot of room between the control arm and the side of the tire. It's not rubbing or anything but I would like the tires to stick out just a little bit more to go with that aggressive stance I'm looking for. Would a 1/2 inch spacer be a good option or is that a waste of time? Also are longer wheel studs needed?
  2. May 23, 2020 at 8:18 AM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    The spacers bolt onto your existing studs and have studs on them so you don't need longer studs.
    Biscuits likes this.
  3. May 23, 2020 at 8:28 AM
    Dye22
    Dye22 Well-Known Member
    Squamish
    '15 TRDOR ACLB
    JBA UCAs OME 2.5 in lift w/ heavy duty dakars. 33" ko2s tc bed stiffeners firestone airbags w/ ride rites cmc/pinchweld rear flushmount leds amazon ditch lights apex sliders 0 degree w/ kickout Coastal Offroad high clearance front bumper w/ full tubing Coastal Offroad high clearance rear bumper w/ tubing and dual swingout 100 AH LiFePO4 Aux battery blue sea fuse panel for aux battery rear diff mod breather Mountain Hatch tailgate insert Smittybilt x2O 10k winch Anytime Camera Mod Front and Rear GPS locator brick BAMF Hangers w/ custom crossbrace 2lo Mod by up2nogood yakima access cab roof bars thule hyper xl cargo box amazon roof basket ARB 1250 awning WaterPort Meso Dual Color Dome Light Durobump Front Bump stops
    Your gonna want to spend money on brand name spacers (spidertrax or Bora) that are hubcentric. If you cheap out and find them on ebay or somewhere else your are going to regret it especially if it is only advertised as being lugcentric.
    I recommend the spidertrax 1.25" spacers. I have run them for years with no issues and have heard of lots of others as well. they are both lugcentric and hubcentric which is great to keep vibrations away.
    Your also going to hear from some people that wheel spacers are the devil and to avoid them at all costs. take this with a grain of salt. If you install the spacers properly you'll have no issues.
    Biscuits, ImMrCrash and Drainbung like this.
  4. May 23, 2020 at 11:59 AM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    I run spacers on my front hubs so I can clear 285's with my stock wheels. Haven't had an issue, and don't really see how there could be an issue. Feel free to flame me.
    Just always always always check and retorque every 5k (when you rotate tires) and retorque initially after 1000 miles to be safe.
  5. May 24, 2020 at 12:45 PM
    Jonny890
    Jonathan
    North Carolina
    Thank y'all for the help I really appreciate it.
    I seen that Bora has a .75 inch spacer that comes with the studs build in. Looking towards getting those but do y'all think i will have to trim my factory studs for it to work or will it clear for a smooth fit?
  6. May 24, 2020 at 1:30 PM
    Dye22
    Squamish
    '15 TRDOR ACLB
    If you have stock wheels they should clear without having to trim. aftermarket wheels maybe not just depends on the wheel.
  7. May 24, 2020 at 2:18 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    You may need longer studs. You’ll know when you bolt the adapter; the nut should fully engage the stud threads. .75 is about the thinnest to consider to maintain adapter strength. Adapters do stress the wheel bearings a bit more. Not too much a concern for street driven Tacos.
