longest rear shackles without modifying exhaust
Discussion in 'Suspension' started by gsanderson, Dec 4, 2009.
  1. Dec 4, 2009 at 6:47 AM
    gsanderson
    gsanderson [OP] Member
    Nashville, TN
    95.5 Tacoma X-cab 4X4
    What is the maximum length rear shackle that can be installed on a
    first gen 4wd without modifying the exhaust...
    I want an additional inch of lift on the rear and would like to use shackles but do not want to interfere with the exhaust...
    from my review I think I need a 5.5" long rear shackle as the stock is 3.5" long...
  2. Dec 4, 2009 at 6:50 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yep. For every 2" longer the shackle is, you get 1" lift...
  3. Dec 4, 2009 at 11:18 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    thats what I did. got mine from toytec. i like it a lot. I cut my tailpipe though and its not a big deal at all. I havnt noticed any problems with cvutting it.
  4. Dec 4, 2009 at 11:20 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    i think with any shackle you purchase other than stock you'll need to *at a minimum* cut off the tip of the exhaust far enough back so as its out of the way
    you can also reroute it...but it sounds like you dont want to do that...
    its been so long since i cut mine though so i dont recall exactly how close it is to the leaf springs and at what point you'd interfere
  5. Dec 5, 2009 at 1:07 PM
    jlvhrse
    jlvhrse Well-Known Member
    Jen
    SoCal SGV
    2009 TRD Sport 4X4 Long Bed
    LSK front and rear LT and stuff
    With the longer shackles you might want to consider installing taller bumps so you don't negative arch your springs on compression.
