longtube headers and check engine light
Discussion in 'Performance and Tuning' started by jibjab1a7, Dec 12, 2009.
  1. Dec 12, 2009 at 3:07 PM
    jibjab1a7
    jibjab1a7 [OP] New Member
    jay
    valdosta
    09 prerunner
    dt longtube headers, urd y pipe, borla catback, aem intake, airraid throtle body spacer, and camburg LT when i get the money
    after installing dtlong tube headers, urd y pipe and 02 simulator my check engine light and traction control lightcame on i just put them on and im beat so i really didnt do much troubleshooting yet. i was just wondering if anyone had the same problem with the same set up? i was thinking its because the simulator was set up for a stock truck with the only mod being the headers and my intake might be trowing it off. or it might be a simple leak or weak conection with the sim and the ecu. any advise would be helpfull especially if you have the same headers as me
  2. Dec 12, 2009 at 3:12 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    I think with the new headers you need an 02 sim I think urd sells them
  3. Dec 12, 2009 at 3:22 PM
    Untamed_SS
    Untamed_SS Stayed Up Too Late
    Adam
    Haughton, Louisiana
    08 Speedway Blue Access Cab
    Alpine iDA-X200 Deck, Rockford P3, Infinity 1600 A Amp, Black Badges, "KnightRider Mod", Back-up lights. Painted Engine Cover. TRD QuickShifter & Shift Knob. MAF Calibrator. Doug Thorley LT Headers. Custom Y-Pipe. Flowmaster 50 series. Satoshi Grill
    Yeah, just check over your wires again man. If they all look good and it still isn't working, go back over it and check to see if you connected the correct wires.
  4. Dec 14, 2009 at 5:38 PM
    neslerrah
    neslerrah Taco lovin'
    Harrelsen
    Tucson
    5 lug BEAST!
    Secondary air filter removed, elbow mod, BFG T/A KO (31x10.5R15), 15" American Racing Mojaves, BHLM, Dome Light MOD (Blue), Pioneer headunit, Sockmonkey 'TACOMA' Decals, Readylift 5-lug SST, Rear Shocks - Bilstein TRD, Dynomax Super Turbo #17748, DDM Slim Ballast HID Kit H4 Hi/Lo -35W 6000K in headlights, Apexcone Raptor HID Kit H3 - 35W 6000K in Hella 500s, aFe CAI #51-10762, WeatherTech Floorliner, 200W Smart AC Inverter
    Welcome to TW.
  5. Dec 14, 2009 at 8:21 PM
    4low2go
    4low2go Well-Known Member
    Coatesville, PA
    10 RC 4x4 5sp MGM
    Curt hitch, OBX Shift
    Hello, welcome to TW!
  6. Dec 14, 2009 at 8:27 PM
    sachou
    sachou Well-Known Member
    Sam
    Richland, Washington
    2006 TRD Sport Acc Cab 4x4 V6 6spd
    To check an o2 sensor, you stick a multimeter on it when warmed up and check the voltage, I believe it should be between .4 (lean), and .9 (rich). I might have that mixed up but I don't feel like looking it up. Anyways, try checking your o2 simulator with a voltmeter and it should be in that range.
  7. Dec 14, 2009 at 8:36 PM
    06HAOLE
    06HAOLE Well-Known Member
    Fort Worth, TX
    2019 Ford Raptor
    Definitely check your 02 sensors.
    I had my 02 sims wired up and headers on etc and I didnt have the lower 02 sensor plugged in far enough to get a solid connection so I had a CEL.
    Check it all again since it will throw a CEL if everything isnt nice and tight.
  8. Dec 15, 2009 at 8:39 AM
    jibjab1a7
    jay
    valdosta
    09 prerunner
    i got it fixed. one of the wires was loose so i re soldered it and its running great now
