Look at my CV angles! :(
Discussion in 'Suspension' started by skybob, Apr 19, 2011.
  1. Apr 19, 2011 at 3:50 PM
    skybob
    skybob [OP] Well-Known Member
    I put in an OME spring, 3/4 spacer, and a rear aal. I also installed the 1" drop bracket from toytec for the differental. The truck in question is an 2005 acc cab 4x4 trd off road
    I have a vibration that is just annoying the hell out of me. It is more noticable at slow speeds, coming from the front end. I also have the carrier bearing vibration, and I'll address that later, this new one is from the front end. It is making me frustrated and I don't dare buy wheels/tires until I get it fixed. Any ideas? Could it be the cv angles? shocks? ??? It's pretty bad, it almost feels like something is binding up.
    Here are the cv angles... I don't know what is good/bad/ and what not.
  2. Apr 19, 2011 at 3:53 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I'm not super experienced but those dont look bad at all. Keep checking in...there will be lots of people chiming in on this to help you out.:cool:
  3. Apr 19, 2011 at 3:54 PM
    Slodgetto
    Slodgetto Über Posre
    Silas
    I'm not sure about the vibration, but I think those CVs are actually fine. My guess is something else is cuasing the vib. I'm sure someone else can better answer your question though. bbbbbump!
  4. Apr 19, 2011 at 4:00 PM
    jacob_wood
    jacob_wood Well-Known Member
    Jacob
    San Jose, CA (Nor-Cal)
    2010 SSM DCLB
    It's not your CV angles for sure.
  5. Apr 19, 2011 at 5:06 PM
    skybob
    Any other ideas on this vibration? Should I pull the spacer and see if that helps?
  6. Apr 19, 2011 at 5:11 PM
    1700OW
    1700OW Well-Known Member
    PreRunner to be converted to 4x4
    ..I have a list of many things.
    driveshaft shake? add some shims under your leaf pack....
  7. Apr 19, 2011 at 5:18 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    yeah that angle looks fine to me. though here's a bump so some more people will see it.
  8. Apr 19, 2011 at 6:29 PM
    hamNswiss on rye
    hamNswiss on rye ¡Yo Quiero Taco World!
    Nick
    Scottsdale, AZ/Portland, ME
    '07 4x4 Access Cab
    OME 885's and billies all around, allpro apex front bumper, Nfab tire carrier, black magic rallye 1000 driving lights, custom back to the future light rack, KC LED Daylighters, PIAA 510 fogs, bed lights, satoshi, 285/70/17 Duratracs
  9. Apr 19, 2011 at 6:31 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Looks fine to me. You probably need to experiment with axle shims and/or a carrier bearing drop in the rear. That's probably where your vibes are coming from.
  10. Apr 19, 2011 at 6:32 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Maybe some ucas? I think some people have fixed vibes with ucas but I wouldn't just start throwing parts at it. Take care ofthe carrier bearing first and see if that vibe hasn't traveled down your frame to the front end.
  11. Apr 19, 2011 at 6:43 PM
    DriverSound
    DriverSound Señor Member
    SoCaca
    2015 DCSB OR 4x4
    Too few to list.
    Are you sure the vibes are coming from the front end? I would guess the vibes are from the driveshaft from installing an AAL. Get a carrier bearing drop kit, if that doesn't fix it try shims. Lose the diff drop.
  12. Apr 19, 2011 at 11:14 PM
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    If it was my truck, I would be more concerned with all that rust on your struts and the lower strut bolt.
  13. Apr 19, 2011 at 11:16 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    CV angle looks better than mine and I dont have any vibes.
  14. Apr 20, 2011 at 4:49 PM
    skybob
    The camera makes it look a lot worst than it is. Thanks for looking out for my rusty Toyota ;)
    I dropped it off at a reputable shop to have them replace the carrier bearing, and do the carrier drop, so that's eliminated out the equation. I am hoping they can fix it. I don't have the time to mess with it anymore.
  15. Apr 20, 2011 at 4:55 PM
    Sigi
    Sigi Well-Known Member
    Sigi
    Sfv ca
    06 tacoma 4x4 trd offroad
    My truck was shaking bad and i found out it was a u joint. I replaced it a couple days ago and it runs like new. I dought its the spacer/drop kit, because i have the same set up and no problems at all.
  16. Apr 20, 2011 at 4:59 PM
    toyo freak
    toyo freak Another Toyota Enthusiast
    David
    Mobile, Alabama
    2010 V6 D-Cab 4x4
    5100s at 2.5, Wheeler 3 leaf progressive AAL, Weathertech liners, yellow wire mod, toyota OEM bed mat, cup holder mod, afe pro dry s air filter, UWS low pro toolbox, Escort radar detector
    I would look into a beefed cb drop, seems like something you could benefit from.
  17. Apr 20, 2011 at 5:05 PM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Where these pictures taken at the same time on a flat surface ?
  18. Apr 20, 2011 at 5:09 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Having Vibe issues myself. Only getting it between 15 and 25 mph. Toyota replaced the front diff and cv's for the front end growl and that seems fine. I didn't notice the vibe till after the replacement, but that doesn't mean it wasn't already there. I have been considering the carrier bearing drop or the shims to see if that works. I have noticed when I jacked the rear up and put it in gear that the metal plate holding the carrier bearing to the frame flexes alot, and that the shaft as it comes out the CB has some vibration. I would like to hear what your outcome is before I try this. So I'll check in, then when I get it fixed I'll post as well. Good luck.
  19. Apr 20, 2011 at 5:13 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Your CV's look fine to me. They look like mine.
    But your vibe/noise your experiecing is more then likely the front diff outer needle bearing. Like many Tacoma's, including mine, they needed to be changed, bc they were bad.
    Try putting your truck in 4x4 while driving to see if the noise and vibe goes away. If it does then its def. your needle bearing.
    As for the rear, just do the CB drop and maybe some shims....
    Hope that helps ya out.....
  20. Apr 20, 2011 at 5:16 PM
    OZ-T
    Peter North
    British Columbia
    You guys should try the OME CB drop kit , it's like $29 and takes 5 minutes to put on , worth a try for cheap .
    I just installed 885's , Nitrochargers , N182's and Dakars .
    The FK29 ( OME CB kit ) came with my components , we put it on and I have no vibes .
