look at MY cv angles
Discussion in 'Suspension' started by JGJ, Jun 2, 2011.
  1. Jun 2, 2011 at 7:22 AM
    JGJ
    JGJ [OP] Well-Known Member
    what do you think? is the angle getting to be too much?
  2. Jun 2, 2011 at 7:24 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Its hard to tell on the first, but the second looks too much. If you just put them on let them settle for a couple weeks and check again, its not worth it to worry now if its going to sag later
  3. Jun 2, 2011 at 7:37 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    Sorry, that's what came to mind reading your title.
    Yeah, the look a little steep.
  4. Jun 2, 2011 at 7:40 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yep. Those don't look good.
  5. Jun 2, 2011 at 7:49 AM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    what doesnt looks good? is it the actual angle of the axle or the rubbing of the boot fins?
  6. Jun 2, 2011 at 7:50 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    its weird the angle doesnt look bad, but the boots are rubbing??
    am i just tired or does anyone else see that
  7. Jun 2, 2011 at 8:00 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    You dont want the Boot fins touching. this will also make the angle less steep.
  8. Jun 2, 2011 at 8:05 AM
    NetMonkey
    Geogetown, TX
    ok, so the angle of the axle is fine (its in a acceptable operating range), its just that the fins are touching (which is bad) :)
  9. Jun 2, 2011 at 8:09 AM
    Dark Knight
    Jeff
    NC/SC
    The angle it still a bit steeper than I would like to run. All leads to premature wear.
    Plus with the axles at that much angle, there is nearly zero down travel.
  10. Jun 5, 2011 at 9:12 AM
    N3ZAT
    N3ZAT Well-Known Member
    Charlie
    Coatesville,Pa.
    09 tacoma
    saws up front/TC UCA/rear AAL
    ugly
