Look What I Found
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mquibble, Apr 1, 2024.
  1. Apr 1, 2024 at 12:45 PM
    mquibble
    mquibble [OP] Well-Known Member
    Michael
    2021 TacomaTRD Pro
    I installed this catch can as a preventive measure not actually knowing if it would help any. Well, based on what I found today I much rather have this in the can versus passing back into my engine. I got this idea from you all here on the forum. Much thanks!
  2. Apr 1, 2024 at 12:48 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    You found oil?
  3. Apr 1, 2024 at 12:51 PM
    mquibble
    Michael
    2021 TacomaTRD Pro
    lol, you WIN!
    Donniet53, Stevie17 and H6G like this.
  4. Apr 1, 2024 at 12:52 PM
    H6G
    H6G Well-Known Member
    Far from home...
    ‘18 Blk. Pro/ ‘17 GT350
    '22 Pro suspension/ Custom Deaver springs/ ECGS and...
  5. Apr 1, 2024 at 1:03 PM
    H6G
    Far from home...
    Surprised that this oil catch can isn't using a wire mesh... instead of paper.
  6. Apr 1, 2024 at 1:04 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Lovers and haters……….
    Stevie17 likes this.
  7. Apr 1, 2024 at 1:15 PM
    Stevie17
    Stevie17 Well-Known Member
    Stevie
    Crossville, Alabama
    24 Celestial Silver Sr 5 DCSB 4x4
    Black gold, Texas tea ! Dang it now I got the Beverly hillbilly’s song in my head :eek:
    Malvolio, elmontemike and Chew like this.
  8. Apr 1, 2024 at 2:47 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    its just oil?
  9. Apr 1, 2024 at 3:06 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    The catch can isn't intended to be a filter. All it needs is some steel wool or wire mesh with similar density as bugscreen to slow down the vapors and cause the oil to fall out of the suspension. A filter like yours is too restrictive and can blow main seals just like a clogged PCV valve:
    hiPSI likes this.
  10. Apr 1, 2024 at 3:12 PM
    mquibble
    Michael
    2021 TacomaTRD Pro
    The filter just reduces any sloshing around. It doesn’t restrict anything.
  11. Apr 1, 2024 at 3:14 PM
    mquibble
    Michael
    2021 TacomaTRD Pro
    You do know that video is about a diesel engine right?
  12. Apr 1, 2024 at 3:21 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    ^Crankcase pressure comes from piston blowby, doesn't matter if it's diesel. While a turbo will cause more blowby than NA, if there's enough gas to leave residue in a catch can, there's enough to blow seals.
    Show us the whole catch can design? If it's just to reduce sloshing, it's better to use steel wool instead of a paper filter that degrades with time.
    petethemeat likes this.
  13. Apr 1, 2024 at 3:22 PM
    mquibble
    Michael
    2021 TacomaTRD Pro
    Its not so much that its an insert bit rather that catch can is not like the ones we would use on our trucks. Check my last post for more explanation if you’d like.
  14. Apr 1, 2024 at 3:53 PM
    petethemeat
    petethemeat Well-Known Member
    Pete
    Ontario
    2023 TRD OR AC MT
    Interesting. Can we see pics of the whole thing?
  15. Apr 1, 2024 at 3:59 PM
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    keep in mind that often the terminology used in these cans is kind of interchangeable. The term oil catch can and oil separator are often misunderstood. However, the result is to separate the heavier bits that are in the oil vapor. This can be contaminants as well as condensation.
    As far as blowing seals, unless the oil separator is extremely neglected, there will be no rise in pressure from the can itself. In theory, it will not prevent nor will it accelerate seal damage or blowout.
    mquibble[OP] likes this.
  16. Apr 1, 2024 at 4:01 PM
    mquibble
    Michael
    2021 TacomaTRD Pro
    You sure Can.
    3JOH22A, H6G and petethemeat[QUOTED] like this.
  17. Apr 1, 2024 at 4:01 PM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    I have never seen a catch can with an oil filter inside wow
  18. Apr 1, 2024 at 4:02 PM
    mquibble
    Michael
    2021 TacomaTRD Pro
    You are overthinking it.
  19. Apr 1, 2024 at 5:32 PM
    H6G
    Far from home...
    AN Fittings and Braided hoses would definitely make this set up look great…
    mquibble[QUOTED][OP] likes this.
  20. Apr 1, 2024 at 5:34 PM
    mquibble
    Michael
    2021 TacomaTRD Pro
    Ugh- you now know I’m going to consider doing that. Great idea.
    H6G[QUOTED] likes this.
