Looking at 98-04 tacoma 4x4
Discussion in '1st Gen. Tacomas (1995-2004)' started by NinerMiner22, Jan 11, 2017.
  1. Jan 11, 2017 at 4:35 AM
    NinerMiner22
    NinerMiner22 [OP] Active Member
    Grass Valley ca
    2018 tacoma sr5
    Hey guy's, new to this forum. I am looking for a 98-04 tacoma 4x4 I've looking on craigslist for a couple months now but cant pull the trigger yet. Here's my question. What is a realistic price I should expect to pay for a truck ranging from 150 to 225 k miles?? Is the 225k too many miles?? Sorry,but going from a 03 mustang with 100k orginal owner to a truck with that milages has me a bit worried...thanks kn advance.
  2. Jan 11, 2017 at 5:56 AM
    Obsessed2000
    Obsessed2000 Just a big dummy
    NC/VA line
    2000 SR5 4x4 3.4
    Deck plate mod Bilsteins All pro leaf springs All pro greasable shackles Camburg UCA Interior Led conversion Tundra TRD springs Extended SS brake lines Seat covers 33" yokos White herculined exterior
    Depends on what your looking at specifically. TRD will fetch a higher price, while in some areas the 4cyl's are sought out and in mine we all want the V6 so there priced higher. Four door is gold so those will be over 10k with tons of miles regardless of the motor. 4x4 is a big factor.
    Rust is going to be your biggest challenge with these trucks and you will see that well documented on the site. Also ball joint can be a devastating thing to overlook.
    I sold my 2000 Tacoma for close to 13k with 150k miles, but that was with a lot of aftermarket parts. I was lucky to find the right guy who didn't want to install all that himself.
    225k isn't that bad with a Tacoma as long as the owner can show you maintenance records, otherwise your rolling the dice.
    Personally I'd pay around 8k for an ext cab with a V6 and 160k miles non TRD, but 4x4.
    TRD easily throw 2k on that price.
    Reg cab in my area 6500, maybe cheaper if its ugly at about 5k.
    And 2wd I've seen a Reg cab with 200k go for 2k.
    Where are you located, and what is your preference/style your looking at?
    TacoMan89 and Xbeaus like this.
  3. Jan 11, 2017 at 6:08 AM
    NinerMiner22
    Grass Valley ca
    2018 tacoma sr5
    Looking to get a extended cab,4x4 prefer manual trans. Not sure if i want to get the 6 or 4 engine yet,not to picky.would use it as a dd m-f then on some weekends take it too the foothills in Ca and go gold digging/fishing...nothing to major. Trd isn't a huge deal breaker cause i would probably put some bilsteins on in the future...realistically trying to spend between 6500-7500.
  4. Jan 11, 2017 at 6:22 AM
    Obsessed2000
    NC/VA line
    2000 SR5 4x4 3.4
    If your on the fence on the 4 or 6 I would highly recommend going with the V6. That's my preference and plenty of others love there four bangers so take it for what it is. It would probably benefit you to check out one of each and see what you think.
    I'm in NC so CA either values there trucks equal to us, or even on the higher side. If your patient you can find one with 160-180k miles in your price range. She will probably be close to stock or a mild lift leaving you to do with her as you please. My 2000 Taco I bought for 6k, it just needed a lot of work and had 140k miles on it.
    The bilsteins are not the main difference between TRD and not. Its the factory rear locker which I've heard is amazing. Never had one so cant speak from personal experience.
  5. Jan 11, 2017 at 2:33 PM
    libtechman
    libtechman New Member
    Im selling my 2000 Tacoma sr5 v6 4x4 with 138000 miles. Only problem is that I live in Canada. No rust ,bought back in 08 from las vegas with only one owner. Did maintenance myself and never have had a problem. Only reason im selling it is because I need a truck that can hold a car seat and the extended cab doesn't cut it. So i went with a 2017 tacoma instead :)
  6. Jan 12, 2017 at 8:55 PM
    NinerMiner22
    Grass Valley ca
    2018 tacoma sr5
    Do you know if its ca complient with the smog laws?
  7. Jan 12, 2017 at 9:00 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    bought my 00 sr5 4x4 trd with 185k miles for 7500 back in 2013. worth it.
