Looking at a 05 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by amcford, Oct 21, 2012.
  1. Oct 21, 2012 at 7:19 AM
    amcford
    amcford [OP] New Member
    scott
    wildwood pa
    I'm new here, thanks to those who run the place!
    I'm looking at my first Tacoma, a 2005 regular cab 4wd 5 speed 107,000 miles. It looks very clean. I can tell it has new front & rear springs & shocks, as well as what looks like a 1-2" spacer on the front springs.
    Are there any particular trouble areas I should look for on this truck, considering the mileage?? What can I expect to need replacement in the next 75,000 miles?? Thanks!!!
  2. Oct 21, 2012 at 11:36 AM
    Saskamoose
    Saskamoose Active Member
    Christian
    Saskatoon, SK, Canada
    06 trd o/r 4x4 Access 4.0
    Borla Exhaust/Air Filter, Remote Start/Keyless Entry
    Welcome,
    Make sure you get underneath and check the frame for rust. Some surface rust is normal, holes and porous spots should be taken very seriously.
    Good luck with the truck.
  3. Oct 22, 2012 at 2:25 PM
    amcford
    scott
    wildwood pa
    OK, the Tacoma I was looking at was at a local Toyota dealer. It was just traded in, not cleaned up or checked out. I took it for a 10+ mile drive, seemed OK. The salesman said they won't sell it until they go over it completely. The truck has a new Pennsylvania state inspection, done a few weeks ago, & they are pretty strict.
    Anyways, the salesman calls me this afternoon & says they won't sell the truck, their mechanic found a problem with the rear differential, & they won't fix it or sell it to the public, they will wholesale it thru an auction only.
    I'm glad they were honest about it, I couldn't hear any unusual noises from the rear, & there was no leakage.
    So, are rear differential problems common on Tacoma???
  4. Oct 22, 2012 at 3:26 PM
    Gincoma
    Gincoma Special Edition Member
    Salt Lake City UT
    RIPieces 2005 Tacoma, adios 2011 :'(
    Factory Monster Truck Package with reverse gear.
    Seems like more then a rear differential if its going to auction but at least they were good about it...as far as i know there are not problems with the rear differential on this site but im sure there are a few incidents just not common occurences
