Looking at a 2006 DCSB TRD this weekend to purchase
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jpdeuce, Jul 20, 2023.
  1. Jul 20, 2023 at 4:13 AM
    jpdeuce
    jpdeuce [OP] Well-Known Member
    James
    Houston
    2008 DCSB OR-6MT
    Lift, Bumpers, Sliders, Odds and Ends
    Hello TW (first post),
    Been lurking here for a bit while I've been on the hunt for a dual cab manual Tacoma to purchase. Found one I'm going to look at this weekend and curious if anyone has tips on things to look at or check out to make sure I'm making a good purchase. The idea for this truck is I will drive it around for the next couple of years and get it looking cool and then my son will take it over when he starts driving. Hoping for a fun truck for us to wrench on together and for him to learn to drive a standard.
    It's a 2006 DCSB TRD Off-Road 6-sp manual. It's got 220K miles and spent most of its life in Kansas. The Carfax I ran doesn't have many entries in the way of maintenance...so I am hoping the person either did their own maintenance or just took it somewhere that didn't report to whatever databases Carfax pulls from. The interior is in great shape, so I am hoping that means they took care of the rest of it.
    There were two minor accidents on the Carfax. The first was in 2007 and there isn't much info on it, but I figure whatever issues happened from that have been worked out by now. The second was hitting an animal on the front left corner, which I will be look at for any major issues. There is also a recall on the rear springs that maybe hasn't been done? Haven't seen anything about recalls while reading here.
    Anyway, would appreciate any specific Tacoma advice. I will test drive it, but not sure I will tell any clutch issues outside of something obvious. I'm driving to see it, so I can bring whatever tools make sense. If all goes well, hopefully I will be doing an intro post after the weekend.
    Thanks in advance,
    JP
  2. Jul 20, 2023 at 6:49 AM
    John43
    John43 Well-Known Member
    Dallas
    07 PreRunner
    That year had head gasket issues.
  3. Jul 20, 2023 at 6:55 AM
    jpdeuce
    James
    Houston
    2008 DCSB OR-6MT
    Thanks for the heads up. Is there a way I could see this when I look at it? I'd hope at 200K+ miles if it had the issue it would have been addressed by now. Maybe a false hope?
  4. Jul 20, 2023 at 6:55 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    I thought the 2005’s had the gasket issue
  5. Jul 20, 2023 at 6:59 AM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    They both do
  6. Jul 20, 2023 at 8:54 AM
    MA_TACO
    MA_TACO Well-Known Member
    Wesley Chapel, FL
    I believe later model 2006 1GRFE's had the gasket issue resolved. Mine is a 2006 built in 08/06 with 230,000 miles and supercharged (7psi) with no issues.
    10thMTNgrunt and sparkystaco like this.
  7. Jul 20, 2023 at 9:04 AM
    jpdeuce
    James
    Houston
    2008 DCSB OR-6MT
    It appears this one was an 05/2006 model...that is the first entry on the Carfax.
    Is there anyway to tell if it is having that issue without pulling the head and inspecting/replacing the gasket?
  8. Jul 20, 2023 at 9:05 AM
    Oreo Cat
    At some point in late 06 they are supposed to be a different material head gasket but I do also see a few 07 head gasket threads every now and then
  9. Jul 20, 2023 at 9:07 AM
    Oreo Cat
    Water noise in the dash, overheating, coolant reservoir overflowing, I had put new clean white spark plugs into my engine with a blown head gasket and a few hundred miles later took them all out. Most were still white while one was bright pink
  10. Jul 20, 2023 at 9:08 AM
    MA_TACO
    Wesley Chapel, FL
    Opening the radiator cap and check for milky residue or pull the dipstick and check that it doesn't look like chocolate pudding. Right way to check is a leakdown test.
    kidthatsirish likes this.
  11. Jul 20, 2023 at 9:47 AM
    jpdeuce
    James
    Houston
    2008 DCSB OR-6MT
    Much appreciated.
    Any other tips? Long time Jeep guy here, but this will be my first Toyota truck.
  12. Jul 20, 2023 at 9:50 AM
    TacoTuesday1
    FL
    I’d think if it made it to 220k and runs well that HG is not blown.
    carfax is useless. They don’t report everything. I’ve inspected a truck I was looking at that had sketchy looking stuff despite clean carfax and passed on it.
  13. Jul 20, 2023 at 11:24 AM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Don't forget to look for rust on the frame, leaks, damage, etc.
    If it's 4wd make sure that works.
    True TRD OffRoads will have a rear electronic locking differential, if that's not present it isn't a TRD OffRoad.
  14. Jul 20, 2023 at 1:48 PM
    jpdeuce
    James
    Houston
    2008 DCSB OR-6MT
    That's a good tip about actually trying the 4WD. I assume it's similar to other 4X4 vehicles - put it in neutral, shift the Transfer Case, then drive? Any other relevant buttons? Without jacking up the rear pumpkin and turning the rear wheels and seeing if they turn together, any way to know for sure the rear locker is working? I guess I could try to get off-camber enough where one wheel is in the air and make sure the one with traction gets power? Not sure what the seller is going to allow by way of testing like that.
    Dm93[QUOTED] likes this.
  15. Jul 20, 2023 at 2:34 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    2H-4H-2H shift can be made at any time as long as your under 55 mph, to get in and out of 4L you must be under 3 MPH and have the clutch fully depressed. If conditions are not correct for a shift the system will beep and you will have to return the switch to the previous position and try again.
    The locker only works in 4L so you have to be in 4L to engage it.
  16. Jul 20, 2023 at 2:44 PM
    jpdeuce
    James
    Houston
    2008 DCSB OR-6MT
    :cheers:
  17. Jul 20, 2023 at 3:28 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    That year also had motor mount issues.
  18. Jul 20, 2023 at 5:56 PM
    sparkystaco
    sparkystaco Well-Known Member
    Sparky
    SE Wi
    06 4x4 dc trd ofrd
    3" lift? A.R.E cap 285/70/17 moto metal 955 17x9
    Look inside the frame by the cats that's where the rust is bad,
    at 220k I wouldn't worry about the HG, they usually blow by 100k'
    spring recall is for replacing the three leaf with a four leaf,
    while there check for spiral cable recall,
    on gravel 4H to 4L once engaged push the locker button when lite flashes turn steering wheel one way and move forward until it locks, once verified unlock it so you don't tear it up.
    Dm93 likes this.
  19. Jul 20, 2023 at 6:06 PM
    DG92071
    DG92071 Well-Known Member
    The head gasket issue is grossly exaggerated on the internet. The problem exists, but it's not near as bad as the internet claims it is. Somewhere on TW there's a thread asking 2005 and 2006 owners if they had head gasket issues. I don't recall the exact percentage, but I believe it was less than 15% that had a head gasket problem. The issue was resolved by Toyota in November 2005.
    Technically the 2005 and 2006 didn't have engine mount issues, it had frame issues where the engine mount brackets were welded to the frame, the frame is known to collapse in that area. It's another grossly exaggerated issue on the internet. The issue was resolved by Toyota in November 2005.
    A much more common issue is frame rust, it affects all years, and comments above posted by other members describe it well.
    SWPA Tacoma, gptoy and sparkystaco like this.
  20. Jul 20, 2023 at 7:36 PM
    tyjoja
    tyjoja Well-Known Member
    Oregon
    2008 off road trd, Rugged Trail
    lift
    to get it in 4-lo you have to be stopped and in neutral with the clutch fully engaged, I believe.
