Looking at a 2007 SR5 with 176k miles
Discussion in '4Runners' started by Tacowin1013, Sep 24, 2021.
  1. Sep 24, 2021 at 6:44 AM
    Tacowin1013
    Tacowin1013 [OP] Well-Known Member
    2017 OR DCSB 6MT MGM
    I'll be looking at a 2007 today for my nephew who is turning 16, its priced at $6500, one owner, based off talking with him he seems meticulous, did his own maintenance (or none at all) but for the price its hard to ignore.
    I saw a small 3500lb-ish RV in the back and I have a sneaking suspicion he used the 4runner to tow it, would anyone be concerned about the trans if so? Other than sagging springs, shocks, any way to tell if it was abused significantly for towing?
    Any other things i should look out for? He did mention to me the 4x4 button is "sticking" is that a pretty simple swap?
    Thanks all--I'm coming from a 3rd gen tacoma so im used to the maintenance and thos types but never had a 4th gen 4runner
  2. Sep 24, 2021 at 6:52 AM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    check for leaks
    have owner start cold engine ............watch for smoke out exhaust
    trans should enter any gear smoothly...............then take for a nominal ride
    should still shift & engage from a stop smoothly
    check color of trans fluid on dipstick...............some have dipstik some dont
    sticky 4x4 button could just need contact cleaner................yet easily replaced if necessary
    take at least $1k off top to cover any rehab/repairs
    towing does not equate to abuse if done right
  3. Sep 24, 2021 at 7:06 AM
    Roody
    Roody Well-Known Member
    Ross
    SW CT
    GX460
    Try 4WD, engage it and drive in a tight circle to see if it does anything odd.
    Check for rust!
    How many miles? V6 or V8?
    Tacowin1013[OP] likes this.
  4. Sep 24, 2021 at 7:07 AM
    Tacowin1013
    v6 176k
  5. Sep 24, 2021 at 7:08 AM
    Roody
    Ross
    SW CT
    GX460
    Price seems decent. Check the usual stuff, tires/brakes/etc. Would try to negotiate it down a bit.
  6. Sep 24, 2021 at 7:11 AM
    Tacowin1013
    Definitely bringing ramps to drive it up to inspect the carriage.
  7. Sep 24, 2021 at 7:20 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Bring: Ramps, flashlight, inspection mirror or boroscope and a scan tool.
    -Check all fluids for level, colour, and smell ("burned" oil = bad)
    -Look for any leaks/drips
    -Corrosion on frame & critical components
    -Check 4WD Hi/Lo engagement and release
    -Check the cabin air filter (is it clean, dirty, wet, mouldy)
    -Raise front wheels, check for ball joint, tie-rod, and U/LCA wear & damage
    -Check CV boots
    -Examine wiring harnesses, cavities and under engine cover for signs of furry friends.
    -Use the scan tool to check for codes, and then on test drive: Monitor fuel trims, cam & crank correlation, MAF, TPS, and evap systems. Make sure you get the system into closed loop and do a good 5-10 mile drive
    Above all, take your time, and if anything looks suspect, simply walk away. When I go with someone to look at a used vehicle, it typically takes me about 90 minutes to do an inspection and test drive.
  8. Sep 24, 2021 at 7:24 AM
    Tacowin1013
    Great suggestion on the scan tool, is there one you recommend? Plan to pick one up before i head out
  9. Sep 24, 2021 at 7:31 AM
    Roody
    Ross
    SW CT
    GX460
    Also if it has XREAS check the canister if possible and look at the closely suspension if somehow it's original to see if it still has the fluid
  10. Sep 24, 2021 at 7:35 AM
    tirediron
    I would buy the best one you can afford. The key things to ensure are that it has live-data and freeze-frame capabilities. One with bidirectional controls is handy, but not maybe not critical. Launch and Autel are the main players in the 'shade-tree mechanic' line.
  11. Sep 24, 2021 at 7:42 AM
    Tacowin1013
    It's a sport, so yes it has Xreas, is there a way to check fluid in the canister? or only check for leaks
  12. Sep 24, 2021 at 7:49 AM
    Roody
    Ross
    SW CT
    GX460
    Basically check for leaks, make sure the lines still run into the shocks and have the hydraulic fluid lines threaded into the tubes themselves. If it's still there and doesn't bounce around like crazy then it's probably functional and will inevitably need to be replaced.
