looking at a first gen
Discussion in '1st Gen. Tacomas (1995-2004)' started by amilton, Sep 22, 2019.
  1. Sep 22, 2019 at 2:32 PM
    amilton
    amilton [OP] New Member
    I'm considering buying a 2004 with 175K on it. The seller says the timing belt and water pump were done at 150K. Should I be concerned that this was done 60K miles after the recommendation?
  2. Sep 22, 2019 at 2:32 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    No.
    GQ7227 likes this.
  3. Sep 22, 2019 at 2:37 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Nothing to be concerned about. But if you have a weird feeling just take it to a mechanic or dealer for a pre-purchase inspection.
  4. Sep 22, 2019 at 2:54 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    ^^^ Agree. Where has the truck spent its life? There may be other things to be concerned about outside of the water pump and timing belt.
    RedManRocket likes this.
  5. Sep 22, 2019 at 3:20 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Rust is the only thing to be concerned with
    Maximo_23, CS_AR and Sgt.Tee like this.
  6. Sep 22, 2019 at 3:30 PM
    amilton
    So Cal for 10 years and Colorado for 5.
    CS_AR[QUOTED] likes this.
  7. Sep 22, 2019 at 3:36 PM
    1&3-TACOMA
    1&3-TACOMA Well-Known Member
    TX
    1998 & 2019 TACO
    1998 stock 4x4 2019 trd off road: Trd wheels TRD Pro grille Led headlights, reverse, license and interior
    I got over 250,000 and have not had it done to mine. The only thing that has gone out is the brake booster about 2 months ago. Discontinued part so I got to get it used, remanufactured, or generic parts store part.
    CS_AR likes this.
  8. Sep 22, 2019 at 4:19 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome aboard
    GQ7227 and CS_AR like this.
  9. Sep 22, 2019 at 5:06 PM
    Stitz
    Stitz Well-Known Member
    South Jersey
    2024 TRD OR Supersonic
    if the belts are still good, there no reason to replace at some predetermined mileage. All you need to know is they have been replaced and that's one less item to check off for pre-sale inspection. Frame rust should be the top consideration, then work from there.
  10. Sep 22, 2019 at 5:35 PM
    1997tacomav6
    Denver
    X2 no
  11. Sep 22, 2019 at 5:36 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Buy it.
    1997tacomav6 likes this.
  12. Sep 23, 2019 at 7:31 AM
    pwgarcia
    pwgarcia Well-Known Member
    Pete
    2004 Toyota Tacoma 4x4 Double Cab
    Just curious, how much are they asking for it?
