Looking at aftermarket rims for my 4x4 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JBockman40, Nov 8, 2015.
  1. Nov 8, 2015 at 5:35 AM
    JBockman40
    JBockman40 [OP] Well-Known Member
    Hermitage TN
    2016 Double Cab 4X4 TRD OR 6MT
    What is the correct size 17x8 , 17 x 8.5 , 17x9?? and what type of offset I've seen 0 , 11??
    Thanks
  2. Nov 8, 2015 at 5:36 AM
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    "Correct" size for a TRD Off Road is 16"
  3. Nov 8, 2015 at 5:39 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Depends on what you specifically need and your tire size. A pretty common size would be 17x8. If you have a wheel with 0 offset it will stick out further than a wheel with positive offset. Again, this depends on your setup. An example would be I went with a 16x8 wheel with 0 offset and went with a 265/75-16 tire. Has a wider stance. The factory trd wheels have around +30mm offset.
  4. Nov 8, 2015 at 11:53 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I'm running 17x7.5 +6 offset with 265/70/R17s. You can see the stance in the page 2 of the Baja link in my sig. This puts the tires right at the edge of the flare. 17x8 with 0 offset will push the tire out 1/2" further.
    I wouldn't go any wider than an 8" wheel. There is no reason for wheels that wide and some tires won't mount within spec on wider wheels. Also narrower wheels do a better job of holding a bead when airing your tires down for off road use.
