Looking at buying an AR-15. Help needed.
Discussion in 'Guns & Hunting' started by Addicted, Dec 27, 2008.
  1. Dec 27, 2008 at 6:21 AM
    Addicted
    Addicted [OP] Well-Known Member
    Greenville, SC
    07 DC 4x4 - TRD Off Road - Black
    Ok, my wife will not be happy about this purchase, but I really want to get an AR-15, apperantly like every other American right now. I have figured most of it out I think, but am looking for some insight and guidance from people that know much better than me. Here is what I am looking at so far:
    Upper receiver: http://www.bravocompanyusa.com/BCM-16-Mid-Length-Upper-Receiver-Group-p/bcm-urg-mid-16.htm
    - Question: What is the difference between this receiver called "Mid-Lenght" and there other one called "Carbine" when both have 16 inch barrels?
    Lower receiver: http://dynamicarmament.com/items/ar...tcompletelowerstandardstocktrigger-detail.htm
    - Want to make sure this is ready to attach to upper receiver and it is ready to shoot? (I know gun needs hand guards, etc... but anything else needed on the lower?)
    I would replace the stock with: http://www.magpul.com/catalog/index.php?main_page=product_info&cPath=70_72&products_id=187
    Handguard: http://www.bravocompanyusa.com/LaRue-Tactical-9-0-Handguard-LT15-9-p/larue tactical lt15-9.htm
    I'm still researching optics, sights, etc... and I think I will have plenty of time to research from all the "out of stock" signs everywhere.
    I would love to get some feedback on the above and also hear your experiences with AR-15s.
  2. Dec 27, 2008 at 1:58 PM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    To be honest I have not dealt with those two companies, in most cases I have used R.R. or Bushmaster.
    Free float is the way to go, the one you showed has set up points for everything.
    I have built a few of them from the lower up, one tactical entry, and two long range versions. Check out R.B. Precision online, they have a number of custom uppers, and you can ask for what you want.
    Here is a pic of my latest, I got the photo off their web site, since I no longer have a copy. Also for parts check out Midway, or Brownell's.
  3. Dec 27, 2008 at 2:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    "Mid Lenghth" and "Carbine" refer to the length of the gas tube. A mid length system is timed better, IMHO.
  4. Dec 27, 2008 at 4:41 PM
    Addicted
    Greenville, SC
    That's a great looking gun longbow. Thanks for the info, I'll check them out.
    Thanks Chris. I knew it had to be something simple. I am looking at the mid length.
  5. Dec 27, 2008 at 5:02 PM
    ZonKs
    ZonKs Can speak french in Russian.
    Glendale, CA
    =p
    I built mine. Its really pretty easy. Its a CMMG 20" Med-con upper, chrome lined barrel, 1:7 twist Oh yeah i had CMMG free float the barrel too. As one of the other guys said this is VERY IMPORTANT for accuracy.
    http://cmmginc.secure-mall.com/shop/?cart=1424066&cat=27&
    also an LCW lower. RRA parts kit w/ NM two stage trigger (accurized).
    i cant remember if Bravo Co. was the one with issues (ie. crappy fitting parts) or not. Do some research. Again I highly recommend CMMG as do ALOT of other people. if you want to go really fancy, say maby a future match stick, go with White Oak Precision. Good luck. I might buy a carbine upper from CMMG in the near future. I have a second LCW lower sitting around somewhere.
    Research barrel twist as well. Depending on the gr. of the bullet you are planning to use.
  6. Dec 27, 2008 at 5:07 PM
    vtragweed
    vtragweed Beef Slut
    Willie
    VA
    08 2.7 SR5 Debadged
    afe pro-dry s filter, LCE headers, painted black steelies,color matched grill surround, URD short shifter, UWS black tool box
    i have 4, 3 are bushmasters, 1 rock river. my rock river out shoots all 3 bushmasters. but then again my rock river is set up for predators and has glass bedding custom shop work done to it
  7. Dec 28, 2008 at 1:30 PM
    Addicted
    Greenville, SC
  8. Dec 28, 2008 at 2:57 PM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    Most lowers are made by just a few companies, sold, and then stamped by the 'manufacturer' of the rifle. One lower is usually as good as another.
  9. Dec 28, 2008 at 4:01 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What He said^^^^^^^
    Check out www.AR15.com for some good info on these rifles.
  10. Dec 28, 2008 at 4:30 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Breaks, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    I still think some of mine are better for long distance. I posted earlier, I do need glasses but.... a Mauser, a M1, and an Endfield ...well what can you say...
  11. Dec 28, 2008 at 4:34 PM
    Monkeysuncle
    Kevin
    Florida
    My endfield with iron sights is dead on....I do want an AR though. I sold my mini 14 to get new tires. Bad decision.
  12. Dec 28, 2008 at 4:56 PM
    Addicted
    Greenville, SC
    Thanks Chris... I've been lurking on that site for a week now. Great info and bad for the wallet.
  13. Dec 28, 2008 at 5:14 PM
    kristopherl
    kristopherl AKA: Jake the Wolf
    Cincinnati, Ohio
    08 Tacoma DC 4x4 Sport LB. Foglight
    Cup holder LEDs, Black Max Tonau, BHL Mod, N-Fab side steps
    so I ordered a complete upper about 3 weeks ago and still waiting for it to get in stock. Can't buy/find a complete lower to save my life.. Looking at a RockRiverArms Lower. from what I have heard they are one of the better makes
  14. Dec 28, 2008 at 5:16 PM
    Packman73
    2007 TRD Off Road
    That site is full of dicks. Lots of info though. Try XDTalk.com; they have a great AR subforum.
  15. Dec 28, 2008 at 5:37 PM
    Addicted
    Greenville, SC
    http://www.ar15.com/forums/forum.html?b=7&f=21
    There are a lot complete lowers on here. Just have to be fairly quick to pull the trigger, b/c lot of people are buying them up. Who did you order the Upper from?
    Thanks Packerfan! I'll check it out.
  16. Dec 28, 2008 at 5:40 PM
    kristopherl
    Cincinnati, Ohio
  17. Dec 28, 2008 at 5:42 PM
    Packman73
    2007 TRD Off Road
    No sweat. BTW, very friendly crowd over there. It's VERY similar to this board. :)
  18. Dec 28, 2008 at 6:00 PM
    Addicted
    Greenville, SC
    I notice you are a long time contributor over there. I almost thought it was your site ;)
    Looks like a great site! :)
  19. Dec 28, 2008 at 6:03 PM
    Packman73
    2007 TRD Off Road
    Haha, yeah, it's my second home now. ;)
  20. Dec 30, 2008 at 12:16 AM
    ERdept
    ERdept Well-Known Member
    All I know is that I have read nothing but great about the gas system from LWRC.
    I have that as my upper.
    An ERGO grip.
    Surefire
    Yankee Hill BUIS
    EOtech
    Magpull butt
    Single point sling from Tactical Tailor
