Looking at this 3/2 lift, opinions?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by gcsrellis, Sep 11, 2020.
  1. Sep 11, 2020 at 4:11 AM
    gcsrellis
    gcsrellis [OP] Well-Known Member
    2016 White Tacoma Limited 4x4
    So I've been looking around for a 3/2 lift. I'm wanting to run 275/70/17 falkens a/t3's and I'm thinking about these wheels https://www.amazon.com/gp/product/B07ZTTTBPT/ref=ox_sc_act_title_1?smid=A23ID4AZTDBV78&psc=1 The most all around'ish lift I can find that would be decent is the https://skyjacker.com/shop/toyota/t...-struts-and-rear-blocks-and-black-max-shocks/ skyjacker one. Comes with what seems to be a decent setup with Shocks all around, UCA's and the drop brackets. Does this look like a good setup? Picks of the wheels for you.
  2. Sep 12, 2020 at 9:39 PM
    TacoPharm
    TacoPharm Follower of Jibbers Crabst
    Phil
    San Diego
    MGM 2017 Tacoma TRD Off Road 4x4
    SPC Light Racing UCA Eibach Pro-Truck Lift System Deaver Stage 1 Leafs Wheelers Superbumps x4 Wheelers U-bolt Flip Kit SCS Ray10 16x8 Gun Metal 285/75/r16 BFG A/T KO2 CMC by @Speed Freek 4.88 Gears CBI Alu Full Skids Sliders by @Shmellmopwho SOS Concepts Streamline Bumper Warn Xeon 10-S winch Factor 55 Flatlink E recovery shackle Optima Red Top 35 @Coupe “TRD” Batt. Hold down Baja Designs Squadron SAE Fogs Caliraised Ditch lights Hypertech Speedometer corrector Fend-X inner fender guards ARE Z-Series Topper DYI sleeping platform
    My experience with 285s and a no longer installed 3/1 spacer lift would have me recommend a Cab Mount Chop, pinch weld hammered and you may have to trim the inner fender wells if you plan on doing any moderate off-roading. They rub with articulation of the suspension.
    A three inch front lift will cause your CV angles will be increased, and can lead to premature CV joint wear, and be less robust in right radius turns. Also the needle bearing that supports the driver side front axel inside the diff may start to vibrate, as the increased CV angles, plus the increased unsprung weight due to the 285 tires, puts loads on the bearing it was not designed to mitigate. Most people, including myself, opt for installing the ECGS bushing to replace the needle bearing.
    Edit: I just noticed the kit includes a ‘diff drop’ as did my 3/1 kit. Just know it only drops the front of the diff, and changes the pinion angle of the front driveshaft. I didn’t notice any additional vibrations, but raising the front 3 inches and dropping the diff 1 inch, would still net you the same clearance as just a 2 inch lift.
    I’m not a fan of the rear block lift. I didn’t like the way it made the rear of the truck handle, but I was on stock shocks when I was using them. A much better option are the add-a-leaf kits out there, like this one from Headstrong, there are other manufacturers too, or a full leaf pack if you have deeper pockets. I love my Deavers! At 2 inch rear lift, you are beginning to look at possibly getting longer rear break lines, depending on how much droop this set up has.
    Most of the people I’ve talked to recommend not going over 2 inches of front lift, to avoid the above issues.
    If you are going for a certain “look,” plan on being on pavement most of the time, and don’t mind a little tire rubbing every so often when entering steep driveways. The kit you linked would be a great low cost option.
    The wheels have the correct offset, but check the center hole diameter, you may need a spacer if it is larger than the Toyota hub diameter, which I don’t remember off the top of my head.
    Happy Modding :bananadance:
    RustedRon! and 71tattooguy like this.
  3. Sep 13, 2020 at 5:48 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Imo eibach , Bilstein 5100’s , Bilstein 6112’s great kits Imo. All kits will get 2” to 2.5” of lift give or take. AAL or 3 leaf or full leaf pack on your needs. I run deaver aal no complaints. Great for everyday and light off-roading.
    Good luck OP.
