Looking for 16'' wheels that won't hit calipers
Discussion in 'Wheels & Tires' started by Tnibley, Nov 28, 2013.
  1. Nov 28, 2013 at 2:13 PM
    Tnibley
    Tnibley [OP] New Member
    Tanner
    So I have a 2009 TRD off road, and I recently bought a set of 16'' steel wheels but they hit the calipers. I have read some post about this and it is my understanding that most 16'' wheel have this problem with the TRD package due to the increase in break system size. So I am hoping to find some 16'' wheels that you guys have used that fit without rubbing the calipers on the TRD package.
    The Wheels I recently bought had a backspacing of 4 which I wanted to help with when I put a lift in later, but this didn't even seem to help with the rubbing. That being said I could use wheel spacers but I did some measurement and I would need about an inch spacer. Combine that inch with the 4 inch backspacing and I dont want the tires to stick out that far.
    So I am just looking for wheels that will clear the calipers and that have a backspacing of 4.5 to 4
  2. Nov 28, 2013 at 3:10 PM
    gunhound
    gunhound Gunhound
    CO
    2013 DCLB Sport
    5/15 tint, NFab step bars, Viper SST, Weathertech floor liners, Toyo A/T IIs on 17x9 XD Menace wheels. Lift - SPC LR UCAs, Wheelers 3 pc AAL, OME N140s, N182 and 885 w/ TP spacers.
    You didn't specify:
    1) How much lift
    2) Tire size you will be using
    There are multitudes of 16" wheels that will work w/o spacers and clear calipers.
    I run (17x9) 5" BS w 0 offset, 265/70/17 and have a nice stance w/ no rubbing on a 2.5" lift.
    Anything from Discount tire listed on website for your truck is guaranteed to fit.
    Look at other builds and wheel size to determine your needs/wants.
    Way too many choices out there....
  3. Nov 28, 2013 at 3:15 PM
    FrostyPower
    FrostyPower Well-Known Member
    Calgary, AB, Canada
    2014 DCLB Blue Ribbon
    Lift Kit - Toytec 3" Billstein full suspension lift Tires - 285/70R17 Goodyear Duratrac Rims - 17" 015 Black American Eagle Rims Nerf Bars - N-Fab Black nerf bars Painted Fender Flares - Bushwacker flares OEM skid plate
    I'm confused here, but tire size and lift make a difference with rims clearing calipers?
  4. Nov 29, 2013 at 5:43 AM
    shawnster88
    shawnster88 Well-Known Member
    Shawn
    Defuniak Springs, FL
    96 Tacoma Reg cab 2.7 5 speed
    OME 881 coil springs, OME nitrocharger sport shocks front and rear. Nitro 4:56 gears. ARB rear locker. Shrockworks front bumper with Warn M8000S winch. 17x9 SCS Ray 10 wheels w/ 285/70/17 Toyo Open Country RT Trail tires. Corbeau Trailcat bucket seats. Go Rhino roll bar w/ KC Daymaker lights. GMRS Radio. Ham Radio.
    I have Dick Cepek dc2 16x8 with 4.06" bs. No problems here. I got a 06 trd or.
  5. Nov 29, 2013 at 2:37 PM
    SCSPerformance
    SCSPerformance Stealth Custom Series™ Vendor
    Vin
    Bay Area, CA
    2005 Tacoma
    Camburg LT kit DMZ SUA kit SCS wheels Destroyer Gray
  6. Jan 20, 2014 at 11:47 AM
    NEFLmudder
    NEFLmudder Well-Known Member
    Jacksonville
    2013 DCSB TRD
    6" Zone lift kit, 20" Tracker Level 8 (20x9 0 offset) with Firestone Destination AT 275/65/20, Debadged, double din touchscreen pioneer dvd, 10" kicker cxr in a taco tunes box and a 600.1 kicker amp. Custom made surf racks utilizing the track system.
    If you want a good wheel. I ran the Ivan Stewarts on my 2005 TRD with the billstein 5100 adjusted all the up and a 275/65/16 wrangler mud tire. They cleared the calipers although it was close enough the stick on wheel weights grapped them. So what ever wheel you get keep an eye on that. I picked up my Ivan stewarts brand new from the dealership for 180 each. That will work with you on pricing they did me (originally 250).
  7. Jan 20, 2014 at 11:56 AM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    The level 8 wheels I have are 16s, and they clear the caliper. Backspacing is 4.5 if I remember correctly.
  8. Feb 6, 2014 at 9:12 PM
    Slizzy
    Slizzy Well-Known Member
    BC Canada
    '09 MGM TRD Offroad
    Bilstein 5100's @ 1.75" front & 5100 rear, Pro Comp 7089 16x8 4.5"BS, 265/75/16 Duratracs, color matched grille, black emblem
    I have a 2009 trd Offroad and 16" pro comp 7089 with zero issues. 4.5" bs
