looking for 2002 Toyota Tacoma owners manual..please help me...
Discussion in '1st Gen. Tacomas (1995-2004)' started by Fishingpro77, Sep 27, 2007.
  1. Sep 27, 2007 at 10:58 AM
    Fishingpro77
    Fishingpro77 [OP] Member
    Los Cabos, Mexico
    TRD off-road
    SET OF 2.5" SWAY-A-WAY RACE-RUNNER OFF-ROAD COIL-OVERS,STLL MORE TO COME...
    Hello Guys, i was wondering if somebody knows where can i find some info or download tacomas owner manual (not FSM, i allready got it), because i want to learn a few things about my 2002 - 4X4 - V6 Taco.
    I really appreciate your help about this...
    Thank you...Have a Nice Day....
  2. Sep 27, 2007 at 3:10 PM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    Check E-bay, I have my manual....you can't have it, but I can answer q's.
  3. Sep 28, 2007 at 10:05 AM
    Fishingpro77
    Los Cabos, Mexico
    TRD off-road
    hello my friend, i really appreciate your kind for help me with my questions, So, let me start with some of them.....
    -What is ECT button?
    -What is the procedure for press the Rear diff lock button? i mean, Can I press this button without set the automatic transmision in Neutral position? What is first? please explain to me if i'm wrong with this.
    -When i use 4X4 option, i set the transm. in neutral position, then, i press the 4WD. button wich is located on the 4X4 shift,.... Is this correct?
    Thank you for your attention, i' ll be online waiting for your comments...
    Have a Nice Day!!!!!
  4. Sep 29, 2007 at 8:47 AM
    coloradoclimber
    coloradoclimber Active Member
    Denver,Co
    04 SR5 Extra Cab TRD
    ill take a stab...
    ECT gives you a little more power. for passing other vehicles, etc.
    You need to be in 4 low to use the rear diff. So you would have your foot on the brake, shift to nuetral, then push the 4x4 button and put the 4x4 gear shift into low. once you are in low, and stopped, you can push the diff lock button, but you dont want to be moving when you push it, also i think you dont want to go faster then 5 or 10 mph with the lock engaged.
    4 high can be shift on the fly, i think below 60mph or so. Just push the button and pull the gear shift down into 4 high.
    to get out of 4 low or turn off the rear lockers, youll need to stop again, put into nuetral, then push the rear lock button. Then move the gear shift from 4 low to 4 high or back to rear wheel drive, then shift back to drive and push the 4x4 button.
    make sense?
  5. Oct 1, 2007 at 6:22 AM
    jrallan26
    jrallan26 Well-Known Member
    Iowa
    2004 White D-Cab TRD
    Somewhere on this site or cutomtacos.com there is a link for the full service manual. I downloaded it and it works great. I think its in .pdf file. Found it!!
