Looking for 6" lift for my 5 lug, 2wd, 2013
Discussion in '5 Lug' started by MissElainious, Apr 6, 2016.
  1. Apr 7, 2016 at 11:53 AM
    zth25
    zth25 Well-Known Member
    Zach
    Atlantic County x Philly
    2005 DCSB TRD OR 4X4
    887 1.5 AAL JBA UCA's 285/70/17 Trail Graps 17x9 Fuel Hostage Custom Headlights
    Get a 6 inch body lift
    JustRob and defythemall like this.
  2. Apr 7, 2016 at 11:53 AM
    zth25
    Zach
    You can just buy two 3" kits and combine them
  3. Apr 7, 2016 at 12:03 PM
    murderedtaco23
    murderedtaco23 Well-Known Member
    Jesse
    Campton NH
    09 dbl cab trd sport
    OME 3 inch lift all the way around, 285 75 16s, fog light any time, HID, Rock sliders, 30 inch bumbper LED, LED pod ditch lights
    Take your lump sum, trade in your 5 lug and get a 6 lug... do it right on the right vehicle. Really, you aren't going to be happy with your results. Theres a reason the 5 lugs are low and there are no big lifts made for them, because the truck is not designed for it.
    BETTER YET: Take your lump sum, go on craigslist, pick up a 1st gen thats lifted and done right, then you have two rigs..
    Rolis12 likes this.
  4. Apr 7, 2016 at 12:14 PM
    eon_blue
    Azusa, CA
    ^^This.
    Keep the 5 lug stock as your commuter/daily driver, use the lump sum to pick up an older Toyota pickup or Tacoma with 4x4 to use as a trail rig/weekend warrior.
    Sounds like the 5 lug will never quite be what you want it to, and all that money spent on trying to make it so could make you so much happier with a truck that was designed for it (4x4 or Prerunner)
    You can pick up a used early 90's 4x4 Toyota pickup or 4runner that runs well for 4 or 5 grand around here, less if you're willing to take a bigger risk on it.
    my .2 cents anyhow, welcome to TW!
    Rolis12 and 5 Lug Fury like this.
  5. Apr 7, 2016 at 1:26 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Even better yet, buy a beater jeep for trail use.
  6. Apr 7, 2016 at 1:51 PM
    HackD
    HackD Marching to the Beat of a Different Drum
    William
    Hamilton, Ontario, Canada, eh?
    2010 Base 4x2, 2.7L, 5 speed manual 5-lug Slug
    Gone over the Top for a 5-lug..
    ^^ This guy ain't helping. Ignore him.
  7. Apr 7, 2016 at 2:36 PM
    MissElainious
    MissElainious [OP] Member
    Elaina
    2013 Tacoma 2wd
    Black 2013 Toyota Tacoma, 2 wheel drive, 4 cylinder (I4) 2.7L engine, 5 lug
    Obviously I don't know a lot about the technical aspect of cars, but a friend suggested I combine a body lift, with a suspension lift to get the height I want.
    Is that even possible?
  8. Apr 7, 2016 at 2:41 PM
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Or go mid travel and put a little preload on your shocks and just be suspension lift not body lift. All you pretty much need is total chaos uca and some 2.0-2.5 shocks like saw's, kings, or fox
    HackD likes this.
  9. Apr 7, 2016 at 2:41 PM
    HackD
    William
    #1 - you'll have lots of ugly frame revealed in a body-lift to eyeball.
    #2 - you'll have to extend wiring looms, steering shafts, fuel-fill hose, shift linkages etc.
    #3 - there is no benefit with a body-lift in this application. None. The suspension is still at a 2.75" maximal level lift. All you'll accomplish in doing so, is undersirably raising your centre of gravity.
    Rolis12 likes this.
  10. Apr 7, 2016 at 2:43 PM
    Hunters Taco
    Hunters Taco Member
    SC
    2005 White Tacoma
    The smart thing would be ready lift, new total chaos control arms, new icon front shocks and a 1" body lift. It won't hurt it that much
    HackD likes this.
  11. Apr 7, 2016 at 2:54 PM
    5 Lug Fury
    Kenny
    Knoxville, TN
    Hunters Taco likes this.
  12. Apr 7, 2016 at 2:55 PM
    HackD
    William
    1" body lift may be necessary for clearance of 33" tires. That's all i would personally consider.
    Not sure how much you have as a 'lump sum' .. but look into the cost of a new third member (plus locker) if a manual transmission, or the cost of regearing your stock third member (plus locker) if automatic transmission.. that may give pause to reconsider the 33" tire option, right there.
  13. Apr 7, 2016 at 2:57 PM
    Mtnflyer
    Mtnflyer I'm big in Japan
    Las Vegas
    @ryanjboutin
    I think he's lifted and lowered a 5-lugger a couple times.
    ChadsPride likes this.
  14. Apr 7, 2016 at 3:49 PM
    BohlaaH
    BohlaaH Loading...
    ALEX
    Thunder Bay, Ontario
    2015 TRD Sport DCLB
    Rigid Industries Grille and 20' fitted LED bar 6" BDS Lift w/ FOX 2.5 (front) FOX 2.0 (rear) 35x12.5 TOYO M/T Open Country Tires Fuel Assault 18" Wheels OPT 7 LED 9003 Headlight Cut Cab Mount & Pinch Weld Trimmed Fender Flares 4.88 Yukon Gears ARB air locker Front & Rear Dent in Driver door... Relentless Fab CB antenna hood mounts Rigid Industries Dually "Amber" spot lights Adventure Offroad Fabrication Overhead Console OTTRAW Switch Mod
    Look up procomp, fabtech, BDS, or maybe you can go with a 3" which I wish I did. And if you want 35s you'll need to to do some :sawzall: anyways. Welcome to TW! Have fun with an empty wallet! And you will need to regear unless you want a gutless beast! I have a BDS 6" but it's a 6 lug 4x4
  15. Apr 7, 2016 at 3:50 PM
    #35
    T4RFTMFW
    T4RFTMFW Well-Known Member
    I got a ban for saying pretty much the exact same thing once.
    Don't be a douche.
  16. Apr 7, 2016 at 4:35 PM
    #36
    zth25
    Zach
    Sorry op, I figured you would get my sarcasm, didn't intend to hurt anyone's feelings.
    In all seriousness, its not worth trying to turn a 5 lug into an offroad capable vehicle in my opinion.
  17. Apr 7, 2016 at 4:43 PM
    #37
    MissElainious
    Elaina
    2013 Tacoma 2wd
    Not trying to turn it into an off-road truck, I just like how it looks.
  18. Apr 7, 2016 at 5:16 PM
    #38
    5 Lug Fury
    Kenny
    Knoxville, TN
    HackD likes this.
  19. Apr 8, 2016 at 8:45 PM
    #39
    Sequoia
    Sequoia Well-Known Member
    Visalia, CA
    06' TRD Off Road 4x4 DCSB
    Brute Force Rock Sliders, Lift, All Terrain Tires, Hi-Lift Jack, LED headlights.
    Get out
  20. Apr 8, 2016 at 8:50 PM
    #40
    DustStorm4x4
    U S A
    04 Jeep LJ
    SleazyPetey and Sequoia[QUOTED] like this.
