Looking for a 3 to 4 inch lift
Discussion in 'Suspension' started by bamaboy6, Sep 6, 2011.
  1. Sep 6, 2011 at 6:32 PM
    bamaboy6
    bamaboy6 [OP] New Member
    clint
    Killen, AL
    05 TRD 4x4 white dbl cab
    ultra motorsports chrome wheels, memphis door speakers and pioneer 10'' sub
    Im wanting a 3 to 4 inch suspension lift kit for my truck. its an 05 trd off road 4x4. im pretty sure you can keep stock suspension until like 4 inches but im not sure. i got it about a month ago and want to deck it out. but for a lift i didnt want to spend but about at the most a little over 400 dollars and was gonna ask for some help on what kind of lifts yall have for that price or if you know of any good ones that you can direct me to. just kinda help me out please cause im new to this stuff. appreciate it
  2. Sep 6, 2011 at 6:34 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    5100's with a toytec top plate spacer will get you 3" up front. then you will just need to get an aal from toytec, wheelers, icon.
  3. Sep 6, 2011 at 6:37 PM
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    3" is feasible but you ride the line of needing aftermarket UCA's which will run you between $450-$675 alone. There is a 4.5" lift kit but it's a bracket type kit and that is way out of your price limit.
    Cheapest lift will be a spacer lift with aal or blocks:)() in the rear.
  4. Sep 6, 2011 at 7:20 PM
    bamaboy6
    clint
    Killen, AL
    how much would all that cost me? sounds to me like alot
  5. Sep 6, 2011 at 7:25 PM
    08pretaco
    az
    300 for the front and rear shocks from downsouthmotorsports.
    60 for the top plate spacer from toytec. toytec add a leafs 80.
    Then you will need some sort of Upper control arms for alignment, light racing is the least expensive. ~450
  6. Sep 8, 2011 at 12:56 AM
    TacomaMtnMan
    TacomaMtnMan those who seek fear shall be followed by fear
    Chuck
    Broomfield
    Fox Shox lifted DC 4x4
    3" lift using Fox Shocks Coilover, Total Chaos UCA's. Running: Duratrac 285/70/17 Rear suspension just a 1" block for now. Will have custom rear springs no block. Fox w/ Resi.
    Some people decide not to use a UCA like Total Chaos UA or Light Racing. But its highly recommended to keep your alignment. You will need one after a front end lift anyways.
    Alignment usually runs between 60-100 bucks depending where you live.
    But plan on it being minimum $1000+ depending on what parts you go with.
  7. Sep 8, 2011 at 12:58 AM
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
  8. Sep 11, 2011 at 1:13 PM
    sanga700
    sanga700 Well-Known Member
    San Diego, CA
    09 Red Tacoma SR5 4x4 V6 6sp
    TRD intake Airbox,4 corners 5100 front set @ 2.5".Rear TSB,1.5" Toytec AAL,skid plate.running board, EGR in channel sun visors,Valetine one radar detector, 17x8.5 Black MB Wheels. 265/70/17 Handkook Dynapro ATM
    bamaboy . over $400 you can do 4 corners 5100s ($ 300 which is 2.5" max lift) + $ 60 aligment +$69 2" AAL + $100 labor and your good to go .
  9. Sep 11, 2011 at 1:43 PM
    oneBIGroom
    oneBIGroom SSS
    SSS
    SSS
    SSS
    SSS
    Do they make allied spindles for the 1st gens? And if so does anyone know where i can find some? i searched for "02 tacoma allied spindles" but got 0 shopping results.
