Looking for a .308
Discussion in 'Guns & Hunting' started by 02sr5trd, Mar 6, 2012.
  1. Mar 6, 2012 at 8:38 AM
    02sr5trd
    02sr5trd [OP] Well-Known Member
    Donnie
    Ohio
    02 SR5 TRD 4x4
    Deckplate Mod, AFE Pro Dry filter, Xcelerator 14'' muffler, AAL, 5100's @2.5, Kenwood DD HU, Alpine speakers.
    I am looking to get a .308 could anyone give some recommendation. I am looking at the ruger gunsite scout, the Remington 700 spa tactical, or the savage. Any input would help. Thanks Donnie.
  2. Mar 6, 2012 at 8:39 AM
    02sr5trd
    Donnie
    Ohio
    02 SR5 TRD 4x4
    Mainly just target shooting. Might hunt with it later.
  3. Mar 6, 2012 at 8:42 AM
    Larson7.62
    Larson7.62 Active Member
    Yuma, AZ
    I have a Remington 700 PSS in .308. It's a great rifle, I would definitely recommend. Doesn't get much better in terms of aftermarket parts as well
  4. Mar 6, 2012 at 8:43 AM
    barlowrs
    barlowrs Well-Known Member
    Robert
    So Cal
    06 Toyota Tacoma Sport 4x4
    Build Thread: http://www.tacomaworld.com/forum/builds/74926-barlowrs-06-taco-expo-build-thread.html OME Lift, FJ SE Wheels, 255/85 KM2, Allpro Plate Bumper, 8K Winch, Synthetic Line, Yaesu FT-8800R, Custom Sliders Sockmonkey bedside decals, BHLM, base model grille, TRD offroad (black) trim
    Depends on what you want to do with it. I highly suggest Rem 700, but what verison depends on what your plans are. Do you want to use it for a build? or keep it stock to shoot with? What ranges you want to go to? 500 yards or 1500 yards?
  5. Mar 6, 2012 at 8:58 AM
    KColoTaco
    KColoTaco Well-Known Member
    Kevin
    N. Colorado
    08 TRD O/R DC
    3 inch OME complete lift, Light racing UCA's, Bed comp. locks.
    I am very familur with the Remington 700 and due to it's huge following it will be the to get parts for, not saying it will require them. I really don't think you can go really wrong with any Remington 700. If your looking for just a target gun I would consider a savage model 12, it will probably out shoot anything else in it's price range.
    I would pass on the ruger gunsite scout due to the short barrel, it probably won't keep up with the longer barreled bolt guns.
    I guess I don't know what type of range you expect, other wise I may have more of an idea.
  6. Mar 6, 2012 at 9:45 AM
    02sr5trd
    Donnie
    Ohio
    02 SR5 TRD 4x4
    I'm new to the whole shooting thing. The range that is close to me is only 100 yards but there are a few that are a couple hours away that are a mile. I just want a decent maybe 1000 yard gun under a grand.
  7. Mar 6, 2012 at 10:01 AM
    barlowrs
    Robert
    So Cal
    if you are trying to push 1000 yards accurately, you will need to do some custom work on your gun. This is where it gets tricky, if you want to build a custom, start out with a cheap 700, such as a youth or SPS varmint (you ate just buying it for the action and barrel). From there you can upgrade stock/chassis, trigger, etc (though the new xmark trigger is not too bad on the 700, but for 1000 yards you will probably want something new). The problem here is the barrel twist on this version is 1 in 12, which is not ideal for throwing long ranges. However, this can be overcome with developing nice handloads. My current build will reach out to 1400 yards or beyond with a 1 in 12 twist with 175 SMK on top of some varget with CCI primers.
    Nice thing about the tactical and varmint is that they have a very heavy barrel. This is bad for hunting, but good for long range/target shooting (barrel dissipates heat better…heat will affect your shots). The tactical is a shorter barrel though, which means less muzzle velocity. To get a 308 out to 1000 yards you need either a HOT 155 gr (scenar for example), or a pretty hot 175 grain (SMK for example). The shorter barrel will make these rounds go subsonic sooner and tumble, limiting your range.
    If you want one out of the box wiht minimal changes, that may get you to 1000 yards, I suggest the AAC-SD. Ideally you would want to change the Houge stock out, but if you keep it, you will need to at least bed the action and free float the barrel, but she should reach out to 800-100 yards.
    Also there is the 700P wich is basically an upgraded Varmint, same twist, barrel, etc, but a MUCH better stock (you coudl keep the original stock on and reach out pretty far)
    The other choice for an out of the box 1000 yard reacher, would be the milpec 5-R…this is a 1 in 11” twist which is more ideal to 1000 yards.
    My suggestion is to pick up an SPS varmint and upgrade the stock, it will end up being cheaper in the long run. (this is what I did)
    All that being said, if you are new to long range shooting, I suggest you start with a .22 or other smaller caliber to get the basics down, wind doping, range finding, etc. you will burn through a LOT of match grade (exp) ammo if you start out with a 308 and try to reach out that far.
    Long range precision shooting is very meticulous and is an art…takes a LOT of practice and still. Much better to get the practice on a cheap round like a 22 than a dollar a shot like a 308.
    And be careful, shooting is very expensive. The gun is the cheapest part of the bunch. Ammo gest very expensive. I started reloading thinking "this will save me money" but it doesn’t, it costs the same amount, I can just shoot more..haha, if you are serious about going for 1000 yards, you will want to start reloading yourself. Equipment to reload for 1000 yards will run you over a grand. Scales, metplat trimmers, case trimmers, neck trimmers, etc. The goal is to be consistent.
    Also, you are forgetting glass...this is the most important part of the equation. You can have a $5,000 custom GAP rifle, but if you throw on a $500 scope, you will not hit anything.
    My rifle (not counting the chassis, etc) cost me like $500 bucks....the glass is $2500 bucks. For long range you NEED good glass, you will be looking at $1500 minimum (that’s for low end high quality glass such as Luepold MK 4). you want really good stuff, which if you are serious about long range, you will, you'll end up with USO, S&B, Vortex Razor, etc. all $2500+
    Check out Snipershide.com for all the info you could ever want on precision long range shooting. There are also a lot of very good builds for sale there in the classifieds (hint hint)
  8. Mar 6, 2012 at 10:10 AM
    DirtyDawg
    DirtyDawg Well-Known Member
    Oklahoma
    2013 TRD Sport DC Long Bed
    TRD Supercharger, URD CAT Back delete with headers and stainless exhaust
    The drop on a 308 bullet at 1000 yards is appx 38' with the Federal 168 grain BTHP match bullet. If you're planning on being accurate at 1,000 yards.....invest the money on the front end and by a Surgeon or GA Precision. However, it will be very rare that you would ever need/have the opportunity to shoot at 1,000 yards. A slight crosswind at 1,000 yards makes it even more difficult to stay on target. A .308 is not efficient for shots longer than say 600 or 700 yards.
  9. Mar 6, 2012 at 10:33 AM
    barlowrs
    Robert
    So Cal
    do not attempt 1000 yards with 168 gr....run either hot 155 gr (palma style) or 175 SMK......DitryDawg is right, drop is VERY large on a 308....this is one of the reasons good glass is needed, you need a LOT of adjustment to make it out that far.
    I am dialing in almost 10 mil at 1,000 yards (with 175 gr), so you need to make sure your glass has the range.
    However, saying a 308 is not efficient beyond 700 yards is incorrect. I regularly maintain 8" groups at 1000 and have reached out to 1500 before. I know others that hit a mile with their 308....a 168 gr is NOT efficient past 600 yards though.
  10. Mar 6, 2012 at 7:54 PM
    02sr5trd
    Donnie
    Ohio
    02 SR5 TRD 4x4
    thanks everyone for the info.. after doing a little more research i think i have decided on the Remington 700 sps tactical but in a .223 and not a .308 because of the cost of the ammunition. will i regret going for the .223 over the .308??
  11. Mar 6, 2012 at 8:02 PM
    drgonzo
    drgonzo Well-Known Member
    Caleb
    Gadsden AL
    07 Tacoma double cab 4X4
    ARB front bumper Toytec ultimate lift boxed UCA's Chase Rack Tiregate Dom Sliders weld on 4 Hellas
    If you ever want to hunt with it your answer is yes
  12. Mar 6, 2012 at 8:07 PM
    6dirty9
    6dirty9 Active Member
    jason
    covington, virginia
    2011 mag grey off road
    Toy tech ultimate 3 inch lift, large tires, wet okle seat covers, sunroof, green led interior lights, tonneau cover, spare tire flip and full size spare, billet grill(customized),ccfl halo headlights, 2 rockford fosgate 12 inch subs behind seat, rockford 6x9 in front door and infighting 6.5 in rear door pushing 100 rms, pioneer 130 double din head unit with factory camera intergrated into head unit. During hunting season have a light bar with 2 go lights mounted on top. want list is Sliders, sock monkey decals.
    Remington 700 vbs has the triangle barrel. I have one in digital camo and out of tbe box can't be beat. Guy bought it off of bought it for shooting 1000 yrds. Just never got to shit it but i have and i love it. I bought all tbe calibers the made in tbat version.
  13. Mar 6, 2012 at 10:11 PM
    barlowrs
    Robert
    So Cal
    If you are still thinking of trying for 1000 yards it is a big push for a .223....it is possible with 75 or 77 gr bullets behind a VERY hot load >max load so you will burn through brass quickly) with a longer barrel to get the velocity. The problem is the tactical is a short barrel, so basically, you wont be effectively reaching 1000 yards with a 223 out of a tactical.
    as i mentioned before, shooting is a very pricy sport, if you are just getting into it, I suggest you build yourself a bench rest 22 (assuming you are not hunting)...then you can start diving into reloading and playing with bigger calibers. I still LOVE taking my 22s out, i can shoot ALL day driving tacks putting round after round through a single hole at 100 yards for the price of one 20 rd box of larger caliber stuff.
    If you are looking for 500 yards or so, a 223 in a tactical will be fine (can probably push out to 600-800 with good match grade ammo, which will cost a bit). I would actually suggest getting it chambered in 5.56, this will allow you to use bulk mil surplus ammo or match grade .223 (you can shoot 5.56 out of .223 chamber, but the other way around is not suggested).
    The nice thing about a 308 is that it is actually a very common round as well. If you are chambered in .308, you can shoot 7.62 (again allows you to shoot bulk mil surplus for short range plinking) then you can shoot good match grade 308 for long range stuff
  14. Mar 7, 2012 at 8:43 AM
    KColoTaco
    Kevin
    N. Colorado
    08 TRD O/R DC
    I like all the recomendations! Shooting is indeed an expensive hobby... I just thought of one more good piece of advise. Firearms are one of the few things in the world that don't lose value a whole lot. Therefore, I would go with one of the .22 caliber catriges. As long as you buy a gun that wont drop its value you can get your feet wet and sell it down the road if you decide you want something different.
    Since your starting out I would go with one of the factory tack drivers. If you want a detachable magazine CZ makes a few that are pretty nice and will resale for good money.
    Do you want to stay with a millitary caliber?
  15. Mar 7, 2012 at 8:55 AM
    AzogSS
    AzogSS Well-Known Member
    Andy
    Soda City, SC
    2008 Pick-em-up-truck
    Ultimate Tailgate Machine
    I have a 700 PSS and IMO it is too heavy for stand hunting (I've tried) but is a real tack driver for bench and proned shooting. Like the above posts it's an amazing gun though. I am currently building an M24 in .308 and having a barrel custom made to mil spec.
  16. Mar 7, 2012 at 10:54 AM
    nomad_archer
    nomad_archer Well-Known Member
    Trevor
    Brickerville (Lititz), PA
    08 DC Tacoma V6 SR5
    wow lots of big green lovers here. If anything at least look at some of the savages they have the out of the box accuracy thats pretty hard to beat right now and a price you cant argue with. If anything take a look. I looked at rugers, rems and savage last year when I was shopping for my 300 win mag. I went with the savage and couldnt be happier with the function and accuracy of the gun plus if you get an accu-trigger you wont regret it.
  17. Mar 7, 2012 at 11:25 AM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    Agree, I'd take my chances with a Savage or Tikka/Sako before Remington.
  18. Mar 7, 2012 at 12:01 PM
    nomad_archer
    Trevor
    08 DC Tacoma V6 SR5
    I went with savage but I am limited a little being a lefty so alot of brands where out. I looked a Tikka/Sako just enough to find out the dont make a lefty bolt gun.
  19. Mar 7, 2012 at 10:59 PM
    redes
    redes Well-Known Member
    Central Texas
    4x4 TRD Offroad
    double car seat mod
    I do not own either the Remington or the Ruger, but I was shopping for a short .308 bolt action not long ago and looked real hard at the Ruger. I saw a lot of vids and read a lot of reviews where the bolt could bind up while closing. It is not a critical fault, but I have handled a number of bolt actions that were smooth as butter and cheap as dirt. Did not see why I would settle on that little piece of tacticool.
    I think there may be some legality problems with using the .223 for deer hunting (depends on where you are). There are definitely some ethical problems. The .223 would be hard pressed to make consistent one shot kills.
  20. Mar 8, 2012 at 7:47 AM
    KColoTaco
    Kevin
    N. Colorado
    08 TRD O/R DC
    Definitly the case that most states require .243 caliber and up to hunt deer. The .223 does a great job with varmits (coyotes are one of the more fun things to hunt in my opinion). If it is okay to use .22 caliber in your state to hunt deer you really need to make sure your using the right bullet like the nosler partition for instance. The other thing i the smaller the caliber is the better shot you have to be to make a human kill.
    I don't think think you'll regret the purchase, buy a scope that would span the gap in the two calibers. Shoot it bone stock and see what you think. If you decide you want something different go that route.
    Welcome to the shooting/hunting sport. Have a blast, pun intended.
