Looking for a best tire fit on 08 TRD with 3" lift
Discussion in 'Wheels & Tires' started by tacom ma, Nov 16, 2010.
  1. Nov 16, 2010 at 9:15 PM
    tacom ma
    tacom ma [OP] Member
    Rafa
    Boston
    08 Tacoma TRD Off-Road
    3" Suspension Lift, 1.5" wheel spacers, 285/75/16 BF Goodrich AT, Body color Grill, iPod, iPhone interface to OEM radio. All Pro off-road rear bumper integrated w/ tow receiver
    Hello all,
    I am trying to fit my 08 TRD off-road with 3" suspension lift with tires that will fit best, increase in size and be great off road as well as on road. The wheel size is the OEM 16" that I am keeping. I would appreciate your recommendations. Thank you.
  2. Nov 16, 2010 at 9:42 PM
    Jm1hawk
    Jm1hawk Well-Known Member
    Jamie
    Irvine
    05 4x4 black
    OME885s MT 17 inch powdercoated rims BHLM 20% tint Alpine headunit Hifonics 1600 W mono amp 2 10" alpine type R subwoofers
    go with 285/75/16. These are good size tire for 3 inch lift. you might have to do some minor trimming but you should be good
  3. Nov 17, 2010 at 6:41 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    x2.
    Be aware that some people also have to chop the cab mount when running this setup.
  4. Nov 17, 2010 at 7:12 AM
    CityTRD
    CityTRD Active Member
    E
    Southern CT
    TRD Offroad
    2.5 Lift, Tint, De-badge, Bed Cover, Leather, Spidertrax, Extra D Rings, Weathertech...
    KPT, do you need to chop the cab mount if you are staying on road mostly? I was thinking about running this setup, but the cab mount chop seems like a lot of work.
  5. Nov 17, 2010 at 7:16 AM
    rhion82
    rhion82 El Duderino
    Mitchell
    TN/GA
    16 Taco
    Yeah I was wondering the same thing. I'm bout to get a 3'' lift soon.
  6. Nov 17, 2010 at 7:40 AM
    LEX
    LEX --- --- --- - ----
    Houston, Texas
    100 Series LC
    With a 3" lift and OEM wheels, I'd go with a 265/75. Plenty wheel travel when wheelin' and more than likely zero trimming.
  7. Nov 17, 2010 at 7:47 AM
    CityTRD
    E
    Southern CT
    TRD Offroad
    265/75/16 is what he has now, that should be stock on the TRD offroad...at least I think it is.
  8. Nov 17, 2010 at 8:15 AM
    LEX
    Houston, Texas
    100 Series LC
    265/70 is stock
  9. Nov 17, 2010 at 8:48 AM
    KPT
    09 Prerunner
    Has nothing do with going off road. It can rub when the wheels are at full lock.
    Also, if you want to fit that size on stock wheels, you will need 1.25" wheel spacers for the front.
  10. Nov 17, 2010 at 9:43 AM
    tacom ma
    Rafa
    Boston
    Thanks a lot for the replys, this is very helpful
  11. Nov 17, 2010 at 10:00 AM
    Hugebergen
    Hugebergen Crash and burn live and learn
    Saskatoon Sask
    3"Toytec ULK, box mat, angle brackets in box corners for tie downs, anytime fog lights, bhlm, black grill and lip, trimed front flaps, 7089 procomp rims with 285/75/16 Toyo M/T tires, black badges with trd badges added,anytime foglights, lamin-x yellow fogs, illuminated 4x4 switch, colour match satoshi, Camburg ball joint UCAS.
    I have a 08 taco with a 3" lift. Just put rims with 4.5 backspacing with 285/75/16 and had to do some minor tirming. nothing to difficult or extreme. Looks good now.
  12. Nov 18, 2010 at 9:21 AM
    CityTRD
    E
    Southern CT
    TRD Offroad
    Good to know. Tried to order the Spidertrax but they are back ordered until December. With the spacer, will that solve the body mount issue or I still may need to cut?
  13. Nov 19, 2010 at 6:11 AM
    KPT
    09 Prerunner
    Without the wheel spacers, the 285's will be un-usable. They will rub on the UCA badly.
    With spacers, you may still have to chop the cab mount.
  14. Nov 19, 2010 at 6:45 AM
    gusher
    gusher SUPERCHARGED!!!
    Greg
    Hudson NH
    08 Tacoma Double Cab 4x4 long bed, TRD Sport
    '08 Indigo Double Cab TRD Sport 4x4 Long Bed, Grillcraft grill, Pioneer AVH-P3200BT head unit, XM receiver, Boyo backup camera, Custom devil horns Toyota logo, Black headlight mod, Fog lights on anytime mod, Maglight mount, Weathertech floor liners, Debadged, Trex color-matched eyelids, Access tonneau cover, Toyota bed divider, Sno-way 7'4" snow plow, Auxiliary backup lights, Rear spring TSB, Removed front mud flaps, 2.5" Hell Bent Steel front lift, 285/70-17 Goodyear Wrangler Duratracs, Satin black MB TKO wheels, Black Go Rhino Dominator II nerf steps, custom HomeLink install, CompuStar remote starter, Redline Tuning QuickLift Elite hood struts, Toyota bed mat, Custom short Taco antenna, TRD cold air intake, TRD exhaust, TRD supercharger
    I'm not sure whether the TRD Off Road wheels have the same specs as my TRD Sport wheels but I'm very happy with my 285/70-17 tires with Spidertrax wheel spacers. I had to do a considerable amount of trimming of my inner-fender (about 1/3) but do not have any clearance issues with my UCAs. Depending on where you're at in Mass, you could get a look at my setup if you'd like.
  15. Nov 19, 2010 at 9:13 AM
    CityTRD
    E
    Southern CT
    TRD Offroad
    So the long of the short is get them on with the spacers and see what I need to do. Thanks for the info KPT.
  16. Nov 19, 2010 at 10:12 AM
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    265/75/16's are about an inch taller than stock. you could run those without any rubbing. If you go with the 285's and you want to keep the stock wheels. You will rub pretty bad and will need wheel spacers.
  17. Nov 19, 2010 at 10:41 AM
    WestCoasTaco
    WestCoasTaco This ain't eHarmony Bro!!!!
    Greg
    Vancouver
    08 TRD OffRoad
    stock, but not for long!
    If you put new rims and tires on, does the tire pressure warning light stay on?
  18. Nov 19, 2010 at 11:08 AM
    KPT
    09 Prerunner
    If you don't put the tpms in the new rims, the light will blink over and over and over again.
  19. Nov 19, 2010 at 2:12 PM
    Hugebergen
    Saskatoon Sask
    my minor triming was cutting the plastic from the front of the front wheel well. A 2 min job.
  20. Nov 19, 2010 at 4:07 PM
    tacom ma
    Rafa
    Boston
    Your Truck looks great, very nice combination and great color, hahaha. I have the TRD off-road so the wheels are 16" and the tire would be 285/75/16. You mentioned that you used 1.5 wheel spacers, it was also recommended to use 1.25 wheel spacers. Is the difference because you run the 17" wheels? I am also planing to paint my wheels black, did you do it your self? or you had it done by a shop? Thanks for replying and your input.
