Looking for a Bike Rack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by badel1129, Jan 12, 2014.
  1. Jul 9, 2015 at 5:39 PM
    Blackfoot 7
    Blackfoot 7 Active Member
    2009 Black Tacoma DCSB 4x4
    Vehicle was purchased used with running boards, 3" lift, 17" Moto Metal wheels, BF Goodrich All-Terrain T/A KO tires, bed liner, tow package, and bike hooks. Mods Added (ongoing): Hood w/ Scoop (inbound)...
    I purchased my Tacoma with those bike mounts installed by the original owner. At least it looks very similar. I'll try to get some pictures up later.
  2. Jul 9, 2015 at 5:50 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
  3. Jul 10, 2015 at 11:23 AM
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    OK hear me out everyone, I dont use any kind of mount and haul my MTB in the simplest and easiest way. just like a dirt bike, you put two tie downs on the handlebars and hook em to your tie down cleats (that you put at the front of the bed). I dont put the hooks on my bars, that would scratch them, but instead i loop the strap around my bars so that both hooks are on the cleats. Better yet, to get the bike out you just lift the back of the bike up and the straps loosen up to slide right off the bars. When you come back to load up again, just put the straps around the bars and you're good to go!
    No wheel removal, and costs nothing because you probably already have tie downs. Seems like people way overthink bike loading
    Heres a very basic pic from the internet, i can take actual photos of my method if anyone cares.
  4. Jul 10, 2015 at 12:03 PM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Seems like that would be more cumbersome and time consuming than just popping the front wheel off and putting the fork in a mount, and not as secure, and easier to steal.
    It takes literally 10 seconds to pop the wheel off, and another 15 seconds to put it back on.
  5. Jul 10, 2015 at 12:28 PM
    ranger098
    Brian
    Minnesota
    It may be about the same amount of time, i leave the straps on the cleats and once set you dont have to adjust them, so you just put the straps on the bars and you're done.
    Id say its just as easy to steal too because you can just unthread the fork mount and away you go, my method you just pop the straps off and away you go. Both methods allow a lock easily though.
    Also, my bike is a Downhill bike and uses a 20mm Through Axle so normal fork mounts dont work on my bike.
    If i didnt use my method, i would for sure use a fork mount like you're saying.
  6. Jul 13, 2015 at 1:40 PM
    Brian_
    Brian_ Member
    2015 Red Tacoma Sport DCLB
    KB VooDoo Side Rail Caps KB VooDoo Tailgate Cap Access Lorado Cover Pop-n-Lock power Lund Nerf Bars Tailgate Security Bed Rail Yakima Bike Rack Bed Rail Yakima Fishing Rod Rack
    I already had the yakima cross bars and rail grabber from the highlander, so I threw this together. I'm not real happy with it yet, but it will get there. The price is right when everything is already sitting in the garage. image.jpg
  7. Jul 13, 2015 at 2:39 PM
    Moser
    Moser Member
    2015 Tacoma TRD Sport
  8. Jul 13, 2015 at 2:42 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    I've looked at Thule for bike racks but then considered I don't really carry bikes that much, I went HF for around $30.
  9. Jul 13, 2015 at 5:47 PM
    Brian_
    Brian_ Member
    Next step is T slot nuts, and that will hopefully allow me to use the inner hole as you've suggested. Long-term I hope to mount rails on the bed rails and use the control towers and landing pads I have. I'd like to add a tonneau, and can't with what I have now.
  10. Jul 13, 2015 at 6:00 PM
    Bentrodder
    Bentrodder PeeRunner Fanboy
    Peter
    Cotati, CA.
    2015 DCLBFTMFW TRD Sport
    Kings and a TW DECAL!!!
    I love my Thule insta-gater! Works great and is super easy to take in and out. May not work if you have a DCSB. My 29er just fits in my DCLB straight.
  11. Jul 13, 2015 at 6:58 PM
    rodcad
    rodcad New Member
    Rod
    2014 double cab TRD offroad
    For a hitch mounted rack I highly recommend 1up. All metal and folds down with bike(s) still on perfectly allowing you to put down tailgate.
  12. Jul 13, 2015 at 7:00 PM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Definitely. A friend of mine has one of them and it is incredibly built.
  13. Jul 13, 2015 at 7:08 PM
    bayrak
    bayrak Well-Known Member
    Vancouver Island
    White 2008 DCLB TRD Sport
    Coastal Offroad Armour, Flippac, Ion Alloy Ion Rims , 285 BFG Ko2, Next Level Audio System, Uniball UCA, FOX 2.5 CO's
    Rat Racks Out of Alberta Canada - with the american doller so high you can probably get them pretty cheap now - full customization ( up to like 5 or 6 bikes i think?), super beefy. I run two sometimes and bike stay put. Swings down to allow easy access into bed too.
    Moser likes this.
  14. May 9, 2016 at 11:46 PM
    jasontylers
    jasontylers Well-Known Member
    JT
    2016 Tacoma TRD Off Road
    None.
    I have a thru axel too and just use a converter. The only downside is that it doesn't technically lock the bike in now because the Rocky Mount now locks just the converter in. Thule makes them for thru axel bikes.
  15. May 9, 2016 at 11:50 PM
    #35
    techride
    techride Weekend Warrior
    Stuart
    British Columbia
    2014 DCLB v6 4x4
    Bilstein/Icon 2" suspension lift with wheelers 5 leaf springs, 7-pin relocate through bumper, bfg KO2s, redline hood struts, immryo mirror relocation, stubby antenna, dipped emblem, heated mirrors, Jason trek cap, led fogs, debadged
    As fat as hitch racks go, the swagman g10 is the best rack around when you look at price, build quality and overall versatility. I'm liking the creative bed solutions you guys are coming up with...
  16. May 10, 2016 at 8:39 AM
    #36
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    I think for the cheapest route, just buying a quick release and mounting it to your bedrail is the way to go.
    To mount two quick releases probably cost me $22.
  17. Jun 12, 2017 at 12:44 PM
    #37
    mmrocek
    mmrocek Name is Bill Burke, and this was an exercise.
    William
    2016 Taco Offroad TuRD
    icons, 4.88’s, winch, sliders, skids and some dinky little 285’s
    Does anyone know of any company that makes outboard bike racks like these? They only seem to make them for their bed racks, but I already have a good, custom made one. The above design would fit me great.
