Looking for a camper shell
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dads Taco, Jan 28, 2024.
  1. Jan 28, 2024 at 6:22 PM
    Dads Taco
    Dads Taco [OP] New Member
    I'm looking for a camper shell. I have a 1999 Tacoma extended cab, does anyone know if a a 2004 Tacoma extended cab camper shell will fit mine?
  2. Jan 28, 2024 at 8:40 PM
    Pbfender15
    Pbfender15 Well-Known Member
    multiple 1st gens
    First gens all the same bed size. But extra cab and single cab can't be switched because of the curve on the rear of cab. But your extended to extended should work. good luck --
  3. Jan 28, 2024 at 10:33 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    What's your location? What color are you looking for?
  4. Jan 29, 2024 at 3:50 AM
    Dads Taco
    Thanks for the information. I live in East Texas color doesn't mater.
  5. Jan 29, 2024 at 7:51 AM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    2001-2004 Double cabs have a 5’ bed whereas the regular cabs and Xtracabs have 6’. FYI.
    vorabora99 likes this.
