Looking for a carrier bearing drop kit/bracket
Discussion in '1st Gen. Tacomas (1995-2004)' started by Sreppep, Jan 8, 2017.
  1. Jan 8, 2017 at 2:38 PM
    Sreppep
    Sreppep [OP] Well-Known Member
    Philip
    Fort Worth, TX
    2001 SR5 4x4 V6 5spd 264k - 2005 T4R V8 4x4 139k
    5100/Toytec, F5s/w KO2 285s, ARB, 4x skids/sliders
    I recently lifted my 2001 4x4 front 3"/1.5" rear, and I'm getting some vibrations. Was looking to get a carrier bearing drop kit and only one I could seem to find was Beefed tacos custom bracket.. Are there any other type of brackets or drop kits out there??
  2. Jan 8, 2017 at 2:44 PM
    jjsul
    jjsul Well-Known Member
    James
    New Hampshire
    95.5 OME
    Lots of people use stacks of washers to determine how much to drop their carrier bearing. They'll either leave the washers or go get a small piece of flat stock the same width as the washers.
    ChillyBear, CodeSeven and bowyer2002 like this.
  3. Jan 8, 2017 at 2:47 PM
    carofchoice
    carofchoice Well-Known Member
    Jeff
    Newton, IL
    2003 DC 4X4 TRD, 2012 X-Runner
    I did what jjsul said, used washers and zero problems so far.
  4. Jan 8, 2017 at 2:53 PM
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    The local hardware stores here sell steel sleeves in different lengths and I.d's. Might be eaiser than a fat stack of washers.
    wilcam47 likes this.
  5. Jan 8, 2017 at 6:21 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    By dropping the carrier bearing, all you're doing is reducing the angle on the rear u joint (which is what is causing the vibration), and increasing the angle on the u joint at the transfer case. The best way to eliminate unequal angles in your driveline is to rotate the axle so the pinion is at the correct angle for the driveline geometry. You can do this fairly simply with angled shims under your leaf springs, or cut the spring perches off and weld them at the right angle.
    Sreppep[QUOTED][OP] and Adude like this.
  6. Jan 8, 2017 at 9:06 PM
    Sreppep
    Philip
    Fort Worth, TX
    Thanks for this! I'll look into it more sometime tomorrow, but with a quick search just now it looks like a 3 degree shim should work?
  7. Jan 8, 2017 at 9:23 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    That's probably a good approximation for a ~3" lift. You can measure all the driveline angles with an inclinometer (I use one like this with a magnetic base), then figure out exactly what angle you need. You can have 4crawler make you a custom one to match your driveline geometry. They also have a lot of info about how to measure your driveline correctly, and how to adjust it.
    Adude likes this.
  8. Jan 8, 2017 at 10:00 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Old man emu FK29 is the kit number i belive to there carrier bearing drop kit. I ordered it at my local 4wheelparts for 8.99 free shipping
  9. Jan 8, 2017 at 10:34 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
  10. Jan 9, 2017 at 1:09 AM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    OP, i too would shim the axle and fix the problem instead of changing an angle elsewhere to help the issue...
  11. Jan 10, 2017 at 3:55 PM
    jjsul
    James
    New Hampshire
    95.5 OME
    The pinion should be pointing directly at the rear driveshaft, yes?
  12. Jan 11, 2017 at 1:35 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    With a double cardan driveshaft the rear pinion should be pointing just below the carrier bearing (maybe 0.5*). This ensures that when accelerating from a stop, which causes the springs to wrap a little bit and the pinion raises, you won't get slow speed vibes.
    jjsul[QUOTED] likes this.
  13. Jan 12, 2017 at 5:53 PM
    Sreppep
    Philip
    Fort Worth, TX
    Ordered 2 degree shims, will updated once I install them Monday.
  14. Jan 13, 2017 at 12:23 PM
    tahco_02
    tahco_02 Well-Known Member
    SoCal
    2002 Black TRD PreRunner Access Cab 2WD
    Stage 1 Lift, 16x8 SCS SR8, 285/75-16 Dick Cepek Extreme Country, Ethan's Skid, Driving Lights Mod
    With my 1.5 inch rear lift I too was getting vibrations. I got and installed 2 degree shims (rule of thumb is 1 degree per inch lift) from HeadStrong Offroad. This cured it. Smooooth once again. I was considering shimming the carrier bearing as well . . . there's no need.
    Sreppep[QUOTED][OP] likes this.
  15. Jan 25, 2017 at 10:51 AM
    Sreppep
    Philip
    Fort Worth, TX
    I installed my 2 degree shims and it fixed about 70% of the vibrations. Still a little annoying but it's better than it was before.
    JayTac08 likes this.
