Looking for a Chassis Lubrication Diagram
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OffroadToy, Oct 4, 2009.
  1. Oct 4, 2009 at 4:17 PM
    OffroadToy
    OffroadToy [OP] pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    I want to do my own lubrication of the zerk fittings on my 07 4x4 Offroad but am unsure of the terminology used in the manual. It refers to lubrication of the front drive shaft thrust bushings and the propeller shaft spiders and slide yokes. Is there a diagram that shows each of these areas and names them that someone could post? It looks like I have 5 zerks...are the 2 zerks forward of the transfer case the front drive shaft thrust bushings? Thanks in advance for any help you can share.
  2. Oct 5, 2009 at 6:37 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    All the diagrams you need should be found in here: They should be identical to 07 and should give you plenty of info to help find what you're looking for.
  3. Oct 5, 2009 at 6:45 AM
    testedone
    testedone Speak English..it's America
    Rick
    U.S.A.
    2010 Tacoma TRD Sport
    Weathertec Mats, Pioneer AVIC-X930BT, Pioneer GEX-P920XM (SAT), Pioneer Premier TS-D602P 6.2, Blaupunkt THb 200A Sub, Trimmed Mud Flaps, BF Goodrich AT/KO 285/70/17 ... Toytec Ultimate Lift, Tuffy Bed Box, A.R.E. Cover, Pop-n-Lock, TRD Exhaust
    wow, nice link..thanks!
