Looking for a decent pair of Crimpers
Discussion in 'Audio & Video' started by brutalguyracing, Feb 11, 2014.
  1. Mar 7, 2014 at 5:42 AM
    Large
    Large Red
    well he is a DB
  2. Mar 7, 2014 at 5:45 AM
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    good point.... :eek:
  3. Mar 7, 2014 at 6:13 AM
    Coppertone
    Coppertone Well-Known Member
    South Louisiana
    2021 Tacoma DCLB TRD OR
  4. Mar 7, 2014 at 9:11 AM
    looking4vr
    looking4vr Well-Known Member
    Brad
    Lusby, MD
    17 DCSB TRD OffRoad 6MT
    Bone Stock, for now
    http://www.amazon.com/gp/product/B00776SJJO/ref=oh_details_o07_s00_i00?ie=UTF8&psc=1
    (Used to have one red handle and one black - now they are both black)
    Was a mobile electronics professional for many years in the 90's-early 00's...still do installs to this day and I've only ever bought one crimper. I prefer this style as it does both 8-12g and 14-22g crimps in one tool. When the blade is sharp it will strip pretty well too if you know how to use them properly.
  5. Mar 7, 2014 at 9:18 AM
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    The 9.5" crimpers shown by multiple folks above work very well. On insulated terminals they will often break through the insulation. Recommend using a piece of heatshrink over the insulated portion after the crimp to maintain electrical insulation. Heatshrink with glue inside is best to seal out water, acid and prevent corrosion. If the heatshrink covers the barrel, as well as part of the wire, then you seal off that connection and minimize any copper showing when the wire is bent right at the connector.
    Ratcheting style crimpers make professional grade crimps, but are expensive. Depends on the AWG wire you need to crimp. For sizes larger than 12AWG, Burndy and T&B make lugs, and for these you do need a ratcheting crimper.
    The ratcheting style wire strippers are overkill, but many folks like them, as you don't need to know what AWG wire you are working with to get it right. The simple style shown with different cutting faces for different AWG work reliably over the long term, and are simple.
  6. Mar 7, 2014 at 9:22 AM
    looking4vr
    Brad
    Lusby, MD
    Bone Stock, for now
    This /\ - Use ratcheting style crimpers for the DOD work I do now for MIL spec stuff...but way too pricey to put in my own toolbox :) My wife already loathes the SnapOn man as it is...:D
  7. Mar 7, 2014 at 9:29 AM
    MedicMutt
    MedicMutt Purveyor of Useless Information
    Josh
    Baton Rouge, LA
    '03 DC PreRunner TRD OR; '06 Mercury Grand Marquis GS
    OME suspension, Whiteline bushings, Line-X'd Jason topper, GoRhino "Grille Guard", many more...
    I used to outfit Emergency vehicles for a living.
    Crimpers:
    http://www.amazon.com/Klein-Tools-Insulated-Non-Insulated-Terminals/dp/B0006M6Y5M
    Strippers:
    http://www.amazon.com/Greenlee-1935-Terminators-Automatic-Stripper/dp/B001HW925Y
    The crimp tool isn't the best, I know, but it worked very well for me. The wire stripper was fantastic, but it will require a little maintenance from time to time (clean, oil, adjust the blades, etc..)
  8. Mar 7, 2014 at 9:33 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    you're wasting your money, scott. just use your teeth like i do :rolleyes:
  9. Mar 7, 2014 at 9:36 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    I use these :)
  10. Mar 7, 2014 at 9:55 AM
    XXXX
    sKiP
    05 Prius
