Looking for a frame
Discussion in '1st Gen. Tacomas (1995-2004)' started by AllTerrain919, Aug 29, 2022.
  1. Aug 29, 2022 at 1:00 PM
    AllTerrain919
    AllTerrain919 [OP] New Member
    Aaron
    1995 Tacoma SX 4x4 auto 60" bed standard cab
    none
    Hi all, new member here. Just purchased a 1995 Tacoma SX, standard cab, 60" bed, 4x4, 4cyl, automatic. Great little truck, only 93K miles. Interior needs a refresh but the body, engine and drivetrain are in fantastic shape.
    I/we purchased the truck for my son, now 12 but will be driving before i know it. Project for us to work on over the next few years.
    Surprise, the truck is out of Pennsylvania and never had the frame recall done, terrible frame under it.
    Not sure i have enough metal left to patch with repair kits and really want to run to ground a frame replacement option. OEM is a discontinued story. Have not had any luck with aftermarket replacement frame builders (budbuilt and throttledownkustoms). Currently on Copart looking for salvage trucks to pull from, both frame and manual trans. I would also like to pull the auto trans and set a manual in the truck.
    I live in Maryland.
    Question: Ideas on salvage frames or aftermarket frames, where to find them? When looking on Copart, what year frames are compatible with 1995 trucks? If i buy a frame with an auto trans set up can i easily convert to manual?
    Thank you.
  2. Aug 29, 2022 at 1:21 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I can't answer the compatibility questions, but I doubt there is any difference in frames between a manual and auto, maybe other than cross bars for transmissions mounts. They don't change much during a generation other than cosmetic stuff, so anything from that generation would likely work. It looks like they changed to longer leaf springs in 1997, but you could use the ones from the donor (you probably would want to anyway).
    Finding a donor vehicle of the same configuration but with a manual transmission that's lived its life in the southwest would likely be your best bet, have it shipped up. Anything close to you likely has a similar frame unless it was replaced.
  3. Aug 29, 2022 at 1:23 PM
    Clearwater Bill
    Billy
    Largo Florida
  4. Aug 29, 2022 at 1:51 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    1995-2000 trucks never had their frames replaced. They were bought back by Toyota at 5% more than KBB value, then crushed and scrapped.
    Your only recourse if you want a new frame is to buy one on the west coast, well used, and ship it to your location. You can also buy a 2001-2004 frame and modify all the mounts. Leaf spring perches, transmission and engine mounts, etc. will all be different.
    Depending on how bad your frame is (pictures will help) you can use products like Saf-t-Cap to rectify the rust issues.
    For frame, you must match engine, transmission, and cab type to get the best fit.
  5. Aug 29, 2022 at 2:38 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    How much is in the budget ?? I hope this was a very low cost purchase.
    How much fabrication work can you do?? A few years ago the last job I bid was$3500.00 plus assorted new parts .
    The shipping out of the Southwest USA is going to be very expensive.
    Please take some pictures !
    See just what your dealing with.
    Have you checked with any local Fab shops to build or splice a new frame
    It might be real close cost wise to a used frame from the South west USA
    Best of Luck!
  6. Aug 29, 2022 at 4:50 PM
    6P4
    6P4 Well-Known Member
    Colorado Springs
    98/2.7L/Regular Cab/4x4/5spd/Open diff
    You sure about this? I know the 95-97 use different (shorter) leaf springs, but I thought they were still spring-over.
    @AllTerrain919 if you do end up with a later-model frame, I think you can just switch to the newer leaf spring size. That might even make your life easier, as the later-model spring is more commonly available. @Tour991 or @Speedytech7 will probably know more.
    Standard cabs were less common than extended cabs. Are you up for shortening an extended cab frame to fit your needs?
    Frames pop up every now and then here in Colorado:
    Tour991 likes this.
  7. Aug 29, 2022 at 6:00 PM
    Tour991
    Tour991 Supplier of used parts
    James
    South Reno/Tahoe
    97 2/4wd, 2014 DCLB 4x4, 99 T4R Limited (sold) 2024 4runner TRD Pro
    So any 4x4 or prerunner regular cab frame from 95.5 to 2004 will work.
    Ideally you want a frame from 95 to 97 with the same engine and transmission. If they are different you will have to move the motor mounts and or the transmission crosmember.
    If you get a 98 to 2000 the leaf springs are longer (no big deal use longer leafs) and the frame horns are 2 inches longer. You can fix that with a grinder. transmission mounts may need to be moved. Motor mounts will be the same because there is no v6 past 1997.
    2001 to 2004 same thing as 98 to 2000 except the frame horns are shorter like the 95.5 to 97
    6P4 likes this.
  8. Aug 29, 2022 at 6:09 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    You’re right I’m mixed with the SUA 5-lugs.
    6P4[QUOTED] and Tour991 like this.
  9. Aug 29, 2022 at 6:12 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Doofus
  10. Sep 3, 2022 at 3:21 PM
    Duke_962
    Duke_962 Well-Known Member
    Nwnj
    02 trd Tacoma, 22 tundra sr5
    Headers with full borla system.
    I have a 02 v6 4x4 5 speed extra cab. with a good frame. Once I can get enough post to sell things on here I will part the truck. If you can use the frame I would gladly sell it you for a decent price to keep yours on the road.
  11. Sep 3, 2022 at 6:29 PM
    Bivouac
    It would be so nice to know where you are??
  12. Sep 3, 2022 at 6:34 PM
    Anton338
    Anton338 Ill-Known Member
    Anton
    New Jersey
    2018 TRD Off-Road DCSB
    Mostly electrical shit that nobody cares about.
    This is a lot of work just to give to a new driver... five years from now. I see no way this will be worth it.
    Source:
    My bro just spent the past month patching the frame on our New Jersey 1st gen and it's still not exactly complete. We pulled the bed but there's still a ton of questionable areas under the cab that we couldn't get into.
  13. Sep 3, 2022 at 6:39 PM
    Bivouac
    Any way to lift the cab?? If your going to rebuild the frame as best you can!.
    Worth is in the eye of the beholder. I would rather dump $10,000 into my 2000 then have another Truck Payment.
    Stonemountainm and Seagull233 like this.
  14. Sep 3, 2022 at 6:41 PM
    Anton338
    Anton
    New Jersey
    What I mean is there's a good chance the 17 year old will put it through a retaining wall like I did when I was 17.
    Would be a shame after dumping 10k into an old truck and still having another payment when the kid needs a replacement.
    Bivouac[QUOTED] likes this.
  15. Sep 3, 2022 at 6:43 PM
    Bivouac
    Now I understand I thought you were saying fixing the truck was not worth doing.
  16. Sep 3, 2022 at 8:12 PM
    Duke_962
    Nwnj
    07827
  17. Sep 4, 2022 at 4:14 PM
    det107
    det107 Well-Known Member
    I have read of a source called sschassisworxs dot com. Just give them your dimensions & they'll make a basic frame (you might have to fab your own mounts/ladder racks). Another thing is they don't like to ship & prefer pick-up, plan a road trip.
  18. Sep 5, 2022 at 11:58 AM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Deep South is also an option, since he is on the East coast. I salvaged several pieces of sheet metal in central Florida that were rust free, bolts came free easily. Frame was pristine, but I didn't need it.
  19. Sep 5, 2022 at 1:19 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    That works too! Just hear of people snatching them up here more often. Florida could work too
    Seagull233[QUOTED] likes this.
