looking for a little inside help
Discussion in 'Suspension' started by Guerod69, May 26, 2016.
  1. May 26, 2016 at 8:44 AM
    Guerod69
    Guerod69 [OP] Member
    Marshall
    2015 Silver Toyota Tacoma 4 dr long bed
    side bars and bed cap, Deciding on a 3inch lift or a 6 not sure just yet.
    I'm looking into lifting my 2015 taco and don't want to put just anything in there would like something that might last a little while. I don't do much off roading, mostly a grocery getter with looks lol, but want to put her up so she will look nice. I was looking at Toytec 3" lift kit with Bilstein 5100 Front Coilovers from toytec lifts for around $950.00. I'm pretty handy with tools and think I could handle the job and if not will call in a friend be looking for a taco owner willing to lend a hand on the Wisconsin Illinois border. But first I need to see what lift to install I have read a lot on here and thanks for all the info guys and gals. it is much appreciated. So anyone with more info your help is welcomed. Thanks in advanced.
  2. May 26, 2016 at 8:49 AM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Even if he doesn't OffRoad?
    moe2o4 and scottalot[QUOTED] like this.
  3. May 26, 2016 at 8:52 AM
    DustStorm4x4
    U S A
    04 Jeep LJ
    Didn't know it gave a little better ride + better handling loading capacity.
    And DAMN where was I when that GB was going on?
  4. May 26, 2016 at 8:54 AM
    Guerod69
    Marshall
    Thanks will give them a call, always nice to pick someones brain with the know how. Thanks Scottalot
    scottalot likes this.
  5. May 26, 2016 at 9:07 AM
    Cornfed
    Cornfed Active Member
    DFW Area
    05 TRD Sport
    Another vote for the full OME kit! I just replaced the worn out stock suspension on mine about a month ago and is a night and day difference. This is the suspension the Tacomas should have come with from the factory.
    Marty65 and scottalot like this.
  6. May 26, 2016 at 9:25 AM
    Guerod69
    Marshall
    How hard is it to install on your own?
  7. May 26, 2016 at 9:38 AM
    TacoJova
    TacoJova Well-Known Member
    Central Oregon
    21 Ram TRX Sold 2015 White DCSB Offroad
    Supercharger Hybrid audio stage 3 and stage 2 rear with 2 image Dynamics IDQ10's and alpine amps Bilstein 5100 with OME 887 Dakars and Icon 2.0 in the rear URD SPEC U Headers URD Y Pipe Borla muffler 18" Magnaflow Resonator Morimoto fogs
    Even then there is a really good YouTube video on how to do it without spring compressors using the LCA
    scottalot[QUOTED] likes this.
  8. May 26, 2016 at 9:39 AM
    crashngiggles
    crashngiggles Tacomaworld's Resident Psych Dr.
    Jared
    Wilbraham, Massachusetts
    2013 MGM TRD 4x4 DCLB Trail Limo
    Have the coil overs assembled at headstrong and they have numerous youtube videos to walk you through both the fronts and the rear leafs.
  9. May 26, 2016 at 9:39 AM
    Guerod69
    Marshall
    Sounds good.
  10. May 26, 2016 at 9:41 AM
    Cornfed
    DFW Area
    05 TRD Sport
    Send the sway bar to the Happy Hunting Grounds...
    crashngiggles likes this.
  11. May 26, 2016 at 9:41 AM
    TacoJova
    Central Oregon
    I guess yeah I still trust it better than spring compressors though but if it's your first time just get pre-assembled
  12. May 26, 2016 at 9:45 AM
    TacoJova
    Central Oregon
    Whatever you do don't go to O'Reillys and get those shitty ass spring compressors they rent you could get seriously hurt by using that shit
  13. May 26, 2016 at 10:36 AM
    Guerod69
    Marshall
    That is an awesome video I have seen it before that what makes me think I should be able to handle it.
  14. May 26, 2016 at 11:17 AM
    Guerod69
    Marshall
    Hey what about this one? Coil/Bilstein 5100 Kit w/ Dakars (HS05BK-1-Dakar) reason I ask is thee bilsteins are aluminum and the ome are steel they might rust oout faster here in Chicago. Are they pretty much the same?
  15. May 26, 2016 at 11:28 AM
    Guerod69
    Marshall
    No frame rust had her under coated. But I see what you mean about the adjustments, just off the phone with headstrong and they recommended them 2 for me. that's why I asked.
  16. May 26, 2016 at 11:33 AM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
    I love my OME kit. I thought I would be ok with an AAL, but after 2 years, the OEM pack is pretty much flat. I don't tow, and only load the bed up when I go camping.
    Get the front shocks assembled and it'll make it MUCH easier to install. And it's safer for you too. The rear leaf pack is a fairly simple swap. Just make sure to extend the rear brake lines while you're back there.
  17. May 26, 2016 at 12:01 PM
    Guerod69
    Marshall
    Her advice was the one you mentioned and then the one I asked you guys about, so now I have 2 to work with that sound really good to me.
    What is AAL?
  18. May 26, 2016 at 6:54 PM
    crashngiggles
    Jared
    AAL= Add a Leaf. It is not a full new leaf pack to replace your oem leafs, it is anot her set of 1 to 3 metal pieces that you add to your own leaf pack. You take yours apart and add to it. Most people find AAL's better and less aggressive then a new leaf pack but like @greeneggsnspam said, your original leafs can wear out and go limp. With a full new leaf pack you start fresh. Make sure if you do go with a full leaf pack you get a good coresponding rear shock to go with it that fits it.
    greeneggsnspam likes this.
