Looking for a manual hub swap writeup
Discussion in '1st Gen. Tacomas (1995-2004)' started by WVTaco12, Mar 12, 2019.
  1. Mar 12, 2019 at 7:09 AM
    WVTaco12
    WVTaco12 [OP] Well-Known Member
    Cody
    West Virginia
    2002 4x4 Double Cab TRD Off-Road
    Please please forgive me if my search functions have failed me, but I am having trouble finding someone that’s done a good writeup on swapping out their ADD system and putting back in the good ol’ Aisin manual hubs. Does anyone have anything bookmarked that they can point me towards?
    I’m wanting to do the manual hub swap with J-shifter and then hopefully follow it with a 5-speed swap into my ‘02 double cab TRD O/R.
    Greatly appreciate any help!
  2. Mar 12, 2019 at 7:17 AM
    DW85
    DW85 Dude.....
    Daniel
    Kentucky
    2001 XtraCab Tacoma TRD 4x4/2004 SR5 V6 4Runner
    Tacoma: Badlands basher front bumper Trail gear rear bumper Trail gear sliders OME Dakar’s OME 883 Coils Bilstein 5100s front Bilstein 5125s rear Wheeler’s Extended brake lines ProComp 51 Series 15x8 3.5” BS 32x11.50x15 BFG KO2’s Honda CR-V windshield washer nozzles Hella 500FF fog lights Energy Suspension power steering rack bushings 4Runner: Hankook DynaPro ATM RF10 265/70r17’s TPMS Bypass mod
  3. Mar 12, 2019 at 8:19 AM
    Fuergrissa
    Fuergrissa Well-Known Member
    Devin
    San Jose
    2000 Cinco speed 4x4
  4. Mar 12, 2019 at 8:31 AM
    jeg0005
    jeg0005 Well-Known Member
    Jon
    BHM, AL
    2001 Tacoma SR5 double cab
    None (yet)
    There's literally one on the first page of the forum right now
  5. Mar 12, 2019 at 9:06 AM
    WVTaco12
    Cody
    West Virginia
  6. Mar 13, 2019 at 11:07 AM
    Mulepadre
    Mulepadre Mulepadre
    Central Iowa
    2003 Std Cab 2.7L 4x4
    Bilstein 5100s, Deaver Leaf Springs, JBA UCAs
    I considered the conversion way back when to improve gas mileage by freeing the front axle
    The overall cost seemed to outweigh the savings from gas mileage.
    With 200k I now wish I had done it.
    WVTaco12 [OP] likes this.
  7. Mar 13, 2019 at 10:22 PM
    License2Ill
    License2Ill Shitiful
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Something to consider. The CV's in a manual hub set up are substantially weaker, and snap off road fairly easily. And can cause a lot of damage in replacement parts when they go exploding. Thought I'd throw it out there.
  8. Mar 14, 2019 at 9:10 PM
    Timmah!
    Timmah! Well-Known Member
    TIM
    Is this fact or your opinion? I've rebooted both ADD axles and Manual hub axles and there's no difference in the size of the shafts that I remember. The main difference is how the CV interfaces with the hub. The ADD axles are locked in place into the hub with the large 35mm nut which also works to preload the bearing. With the Manual Hub CVs, the shaft slides into the hub and is held in place with a snap ring and back-up bolt.
    I've never heard that manual hub CV axles are weaker than ADD CV axles. Care to elaborate where the weakness is with the Manual Hub axles and take it one step further by throwing out some further facts and information to back up your claim. I've been running manual hubs on my 3rd Gen 4runner for around a year now and have done several wheeling trips with no issues.
  9. Mar 15, 2019 at 8:05 AM
    WVTaco12
    Cody
    West Virginia
    So, who’s got some parts for a manual hub conversion just sitting around that they want to unload?!?!?
  10. Mar 16, 2019 at 8:08 AM
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    That's pure internet mechanic hearsay. Tacoma CV axles, whether for manual hubs or ADD, are both 28 mm thick. For comparison, Dana 44 axle shafts are 30 mm thick. Driving habits more than anything else will affect how long your CV axles live. But with manual hubs you're not putting any wear on your CV axles the 90% of the time you're not in 4WD.
    If you break an outer CV axle, the potential for damage is the same with either system. But if you break an inner CV axle you're much better off with manual hubs. You can unlock the hubs so the CV's won't spin and continue driving in 2WD. With ADD the CV axle is splined to the front wheel bearing and locked in place with a 35 mm nut. It's a do-able trail repair to partially disassemble the front suspension and yank the broken CV axle out, but it's a lot easier to just turn a dial.
  11. Mar 16, 2019 at 1:30 PM
    License2Ill
    Ian
    Negative. The birfield shafts are nearly 1/4 thinner on a manual hub cv vs an ADD birf. And that's the place they shatter. Not the axle shafts. They're identical.
  12. Mar 16, 2019 at 1:33 PM
    License2Ill
    Ian
    I've converted three pairs of ADD axles to manual hub axles and the only difference is the birf.
    @Dirty Pool , can you set these guys straight?
    Taco_Sam_96 likes this.
  13. Mar 16, 2019 at 3:30 PM
    Dirty Pool
    Dirty Pool GET CHARLIE OFF THE MTA
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    Absolutely Sir, I'll take your light work.
    Thought you would never ask.;)
    The "main shaft" is indeed 28mm and is the same part between ADD and Man hubs with the exception of some 4Runners.
    Comparison of (OE) Taco and at least some T4R shafts (necked down).
    The man hub deficiency and reduced diameter as mentioned, is the stub shaft living in the man hub. When it goes it can take the hub/hub parts with it. No turn the dial and go home.
    Specs from the late Cretaceous. Man hub around 20% thinner.
    Further searches on the older forums will come up the same.
    Give it time to load.
    https://www.ttora.com/forum/2-early...fferences-add-vs-manual-hubs.html#post1079103
    How common is this? I would say when a man hub CV fails it's about a 50/50 chance it will be in the hub. Of course that's among folks that are proficient at breaking CVs.
    Few pics from deep in the Dirty Pool.
    Just for equal time this one broke at/in the diff. Of course it was an aftermarket "new" shaft (China)
    This would not be fun on the trail or at home in the shop for that matter.
  14. Mar 16, 2019 at 4:12 PM
    License2Ill
    Ian
    ^Ah one of those looks familiar. ;)
    Taco_Sam_96 and Dirty Pool like this.
  15. Mar 16, 2019 at 4:31 PM
    Dirty Pool
    99 XCAB V6 MT TRD
  16. Mar 16, 2019 at 5:09 PM
    License2Ill
    Ian
    Yes. ORS, the original supplier of the 1st gen ADD to manual hub kit offered to to sell me birfs and shafts but were out of stock upon my inquiry.
    I bought a few off @Sideline Hero, who uses the 1st Gen manual hub birfields in his 2nd gen manual hub conversion kits. Which I'm very happy with. He works/worked for a Toyota parts Dept. And uses all OEM Toyota parts...
    And I bought a few broken manual CV's to scavenge the birfs, which was a poor choice.
  17. Mar 16, 2019 at 9:09 PM
    DJB1
    Dave
    SLC, UT
    Well, I’ll admit when I’m wrong but I don’t think manual hubs are ticking time bombs. CV axle failures are pretty rare if they’re OEM. Lower ball joints are another story, though...
    Timmah! likes this.
  18. Mar 17, 2019 at 12:33 PM
    Timmah!
    TIM
    I agree with you. Even though there's some proof that the manual hub CV axle birfield shafts are thinner than the ADD shafts, I don't know if this qualifies @License2Ill statement that they are "Substantially Weaker". When I hear a statement like that, it sounds like if you hit a pebble in the trail your CV shafts are going to snap. However, knowing that a birfield shaft failure could cause damage to the free wheel hub, I carry an extra Aisin Free Wheel Hub with me along with a spare CV shaft when I'm wheeling.
    I really like the benefits of this mod and wouldn't let the worry of a CV axle failure sway me to not do it.
    DJB1 likes this.
  19. Mar 17, 2019 at 1:56 PM
    License2Ill
    Ian
    Substantially weaker is semi-close to an opinion. I snapped three oem manual CV's and not a single ADD. None of the roads where breakage occurred were especially difficult. So that's enough for me to be up my own ass and call them substantially weaker.
    If I knew I'd be through this many CV's before I converted to manual hubs I might have made a different decision.
    I converted six years ago before it was a popular thing to do. And before all the info that's out now making it popular. I'm adding to the conversation for people thinking about doing the mod to make an informed decision
    the fact being the manual hub CVs are thinner and therefore weaker.
    But on the plus side. :D
    I get 3/10ths better mpg with the hubs unlocked. Free 2 LO. Oh and if I snap a CV in the hub like they seem to like to do, I can just drive home unlike ADD trucks where the birf stub holds the bearings together.
  20. Mar 17, 2019 at 2:01 PM
    License2Ill
    Ian
    If you're going through the troubles of carrying a spare CV and hub dial, you're going to want to carry both inner and outer bronze bushings, the hub needle bearing and a blind-hole puller to pull those damaged parts out of your hub. Because when the birf stub goes all those parts probably will go with it.
    Reh5108 likes this.
