Looking for a new suspension, I just have no clue about any of it.
Discussion in '1st Gen. Tacomas (1995-2004)' started by wildmanmarck, Sep 20, 2023.
  1. Sep 20, 2023 at 3:29 PM
    wildmanmarck
    wildmanmarck [OP] Well-Known Member
    Reno
    The ultimate adventure taco
    I have the old man emu cookie cutter 2” lift kit, with an added leaf in the rear. I’d like to do something a little meatier so I can do more crawling ish. I would like to get 35s on her.
    My thought would be to replace the old man with a full size truck suspension.
    Any help would be great, trying to do junk yard finds and be a cheap SOB here…..
  2. Sep 20, 2023 at 5:03 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    Good luck 35s without a body lift means tubbing the firewall. 33s with some basic upgrades will walk all over most jeeps with a good driver.
    toku58 likes this.
  3. Sep 20, 2023 at 10:37 PM
    wildmanmarck
    Reno
    Ohhh. That makes sense. Would spacers help, or they kind of a no no
  4. Sep 20, 2023 at 11:02 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Experience will get you further (and farther) than "full size truck suspension"
    I say this because lifts do not attribute to clearance for larger tires, suspension lifts that is
    Nothing wrong with OME, but if you are going to upgrade suspension, do so because you want specific valving and the ability to service said shocks
    For 35's you will need to tub plenty
  5. Sep 21, 2023 at 8:20 AM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    For the most part these IFS can be adjusted in so many configurations that it's really hard to give you the perfect answer.
    Wheel offset, alignment specs, etc.... all make a difference on how your tires clear the body and frame.
    I agree 33" would be a great option. If you can set up/dial in your suspension to clearance the tires at full stuff and lock to lock then you're golden!
    Remember the higher you go the more down travel you lose in articulation before wheel lift off.
    I have a few links in my sig that can get you on the right track to understanding lifts.
    Good Luck!
  6. Sep 25, 2023 at 6:53 PM
    tacoman2001$
    Hopefully this weekend I'll show a setup of my 33s. Full uniball upper and lower and heim inner and outer tierod. It will be cool to see how much travel you can get out of stock-length arms. CV axles will probably start to bind and I'm not sure the coilovers have the length to fully cycle it.
