Looking for a tonneau hard tri fold that will Not interfere with rails
Discussion in 'Tonneau Covers, Caps and Shells' started by Allthumbs, Jul 3, 2017.
  1. Jul 3, 2017 at 4:25 PM
    Allthumbs
    Allthumbs [OP] Well-Known Member
    Ken
    Florida
    SR5 Acess cab 2017
    Have a 2017 access cab would like to cover the bed without compromiseing the bed rail system. Preferably secure,dent and fade resistant any and all input on this would be appreciated.I have never had a tonneau cover before.
  2. Jul 3, 2017 at 6:10 PM
    Bucci611
    Bucci611 Member
    2017 Cement TRD Pro
    I called bak industries, was told the mx4 flip back will still allow the use of the time downs. Ordered it today hopefully putting it on this weekend
  3. Jul 3, 2017 at 7:23 PM
    Allthumbs
    Ken
    Florida
    SR5 Acess cab 2017
    Post after you get it installed. I'm curious to see if you uninstall factory slide rails then use Bak rails,and end up with unused factory rails.
  4. Jul 3, 2017 at 7:45 PM
    Bucci611
    Bucci611 Member
    2017 Cement TRD Pro
    If that's the case it's going back...I don't want to rip apart a brand new truck. Realtruck has a few instal videos I forget which one used a new Tacoma and the clamps slid in the rails. It was a high gloss cover and I was looking for matte
  5. Jul 4, 2017 at 11:18 AM
    Allthumbs
    Ken
    Florida
    SR5 Acess cab 2017
    This is what I was able to find out. The factory sliding tiedown track comes off. MX4 hardware goes on. The factory track mounts back onto the MX4 hardware. This makes the track slightly lower but fully functional. This relieves all my concerns hope it helps yours.
  6. Jul 5, 2017 at 1:28 AM
    Rackness
    Rackness Well-Known Member
    Maryland
    17' Tacoma
    Working on it.
    I am using an extant trifold 2.0 and it allows for rail utilization. I was having leaking issues when it was first installed but after taking the time to ensure it is properly aligned it has worked very well with no/minimal leaking. I have not experienced any leaking but no tonneau is leak proof in all circumstances. Also the warmer weather helped by softening the gaskets and allowing them to create a better seal.
  7. Jul 8, 2017 at 8:04 PM
    jim3456
    jim3456 Member
    Charlottesville, VA
    2013 Toyota Tacoma TRD Off-Road
  8. Jul 14, 2017 at 8:46 PM
    FHC
    FHC Well-Known Member
    I have the Elite G4 by Foldacover and it utilizes the rail, but you still have access to it for the tie downs but it does limit it some.
