Looking for a used camper trailer for 2008 4 cylinder rear wheel drive
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jasonc424, Oct 5, 2017.
What is a comfortable camper trailer weight for a 2008 4 cylinder, rear wheel drive Tacoma?
  1. 2000 pounds is a good cutoff
    0 vote(s)
    0.0%
  2. It can pull more comfortably
    100.0%
  3. May I suggest staying under 1600 pounds dry
    0 vote(s)
    0.0%
  1. Oct 5, 2017 at 10:44 AM
    jasonc424
    jasonc424 [OP] New Member
    Central Ohio
    2008 Red Tacoma Access Cab 4 cyl RWD
    None
    Hi group,
    I was wondering if anyone would like to share their experience pulling a trailer behind their Taco. We're looking to buy a camper trailer to pull from Ohio to the southwest for the winter. We don't want to buy something that's hard on the truck, especially in the mountains, so we have been looking for the lightest trailers with a wet bath. For example, a Scamp 16', a Casita 16', a Riverside Retro 150 or 155XL. These all weigh just under 2000 pounds dry. Could we go a little bigger? Something that's 2500 pounds and still pull comfortably? The rating is 3500 pounds, but that seems like a lot to us behind a 4 cylinder. Thanks for any feedback!
  2. Oct 5, 2017 at 5:41 PM
    potstech
    potstech Well-Known Member
    Midlothian, Va
    2013 DCLB
    What is the tow rating for your 4 cylinder? Have tried to tow a camper with a small engine and will never do it again. Also with those types of campers you have to think of "sail area" which is causing problems due to the wind hitting the front of the trailer.
  3. Oct 5, 2017 at 6:34 PM
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    I think the aerodynamics of a camper will kill you more than the weight. I have no doubt you could pull a 3,000 pound camper across the country, but it will take a lot of patience and determination.
  4. Oct 6, 2017 at 6:43 AM
    jasonc424
    Central Ohio
    None
    Thanks for the responses. If wind hitting the front of the camper is a bigger concern than the weight, would it make more sense to get a Tab 320 or Tab Max Teardrop or a pop-up or HiLo camper or maybe a Taxa Cricket? How much weight is too much to tow comfortably if I'm pulling one of these? I will be living in the trailer for up to three months this winter, and likely using it for other camping trips in the coming years.
  5. Oct 6, 2017 at 6:46 AM
    knottyrope
    knottyrope Well-Known Member
    Knotty
    Bahstun
    09 Taco CCLB 4x4 SR5 4.0
    Pads, rotors, ujoints, 5900K Super White Xenon HID Halogen Bulb Fog Light
    my 99 taco 2.7 std 4x4 pulled a Trail Manor 25-18 with out issue in the New Hampshire mountains.
