Looking for a Vacuum solenoid switch
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cornflake, Dec 29, 2018.
  1. Jan 1, 2019 at 11:28 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yeas this one bumps your idle up for the AC. The screw adjusts the amount it bumps up.
  2. Jan 1, 2019 at 11:32 AM
    Cornflake
    Cornflake [OP] 95.5 Tacoma 2.7 4x4
    Jeremy
    West Georgia
    Tan 1995.5 Toyota Tacoma 2.7 4x4
    Clear Blinker lens 15x8 black American Racing wheels 31x10.50r15 Ironman all country
    Do you know how to go about adjusting it?
  3. Jan 1, 2019 at 11:35 AM
    Speedytech7
    It is ground side switched and Normally closed. You can unplug it and put jumpers directly to the battery to open it up (while the engine is warmed up idling) and twist the screw to get the idle to sit around 900rpm (or 1100 if you're in a super hot climate). Use a good fitting screw driver cause there is some silicone holding it from the factory adjusted position. Doing this little activity will probably set the check engine light cause it isn't expecting you to mess with the idle just a heads up. It'll go away after you're done and plug the vsv back in.
