looking for advice - front springs
Discussion in 'Suspension' started by jamess, Oct 22, 2012.
  1. Oct 22, 2012 at 7:29 AM
    jamess
    jamess [OP] Member
    James
    Tulsa, OK
    SWB Sport
    front: 5100 @ 0.85 and stock coils rear: 5100 and Alcan 8 leaf pack
    Good morning all!
    I have recently purchased some front and rear 5100ss and I have a set of Alcan springs being shipped. The Alcans are supposed to give me 1.5" of lift over stock. I am replacing my rear leafs since they are flatter than flat, and I only wanted a little bit of lift. I plan on using the stock front coils and adjusting the 5100s so that i am close to level once the rear leafs are installed.
    Would you all keep the stock coils or should I look for something else. I have about 97k on the 2006 TRD sport.
    Thanks.
  2. Oct 22, 2012 at 7:33 AM
    GEORGE STRAIT
    GEORGE STRAIT (Not the real George Strait)
    Da Magic City, AL
    Smart Fortwo '10 Hybrid
    I use the stock coils on mine. You should be fine, it just depends on how much $$ you wanna spend.
  3. Oct 22, 2012 at 7:34 AM
    acdronin
    acdronin Well-Known Member
    If you set the fronts to level it out you will preload the stock coils and your ride quality suffers greatly, i have stock coils with the billies set at .85 and it's stiff, great for corners, not so great for absorbing bumps. I would recommend going with aftermarket coils and setting the billies at zero.
  4. Oct 22, 2012 at 7:39 AM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    Your spring-rate doesn't magically change when you preload the springs unless you have TRD Off Road springs, or you pre-load them to the point of spring-bind.
  5. Oct 22, 2012 at 7:47 AM
    acdronin
    Mine are Sport springs and the ride quality like this is not great, or more like not as good as it could be, that's why i would recommend better springs if he wants to lift it.
