Looking for alignment numbers (Fox susp.)
Discussion in 'Suspension' started by Firebird, Mar 7, 2017.
  1. Mar 7, 2017 at 7:13 AM
    Firebird
    Firebird [OP] Notorious Member
    Phoenix
    Lewisberry, PA
    1993 FZJ80
    I have Fox extended travel 2.5" C/Os up front at about 2" of lift with Total Chaos uniball uppers. I'm running poly bushings on stock lowers.
    My current alignment numbers are as follows:
    Caster Left: 2.5°
    Caster Right: 2.5°
    Camber Left: 1.1°
    Camber Right: 0.0°
    Toe Left: 0.0°
    Toe Right: 0.0°
    This is the closest alignment my truck has had since the lift, but it still wanders like crazy on the road. If my wheel is moved a bit left it will stay there and drift left and the same with the right. It seems like the wheels don't want to go in a straight line.
    Any suggestions on what I could do to fix this and numbers that would work better on the road?
    I've had around 5-6 alignments so far.
  2. Mar 7, 2017 at 7:44 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
  3. Mar 7, 2017 at 10:45 AM
    Firebird
    Phoenix
    Lewisberry, PA
    1993 FZJ80
    Redsyota likes this.
  4. Mar 27, 2017 at 9:38 AM
    Firebird
    Phoenix
    Lewisberry, PA
    1993 FZJ80
  5. Mar 27, 2017 at 12:38 PM
    Justinlhc
    Justinlhc Not looking for a relationship
    You could start by fixing that 1.1° camber o_O
    Do they have big road crown where you drive? If so, you need to adjust caster on drivers side to compensate so it doesn't pull.
  6. Mar 27, 2017 at 12:47 PM
    pseudomike
    pseudomike Well-Known Member
    Michael LaValley
    2012 DCLB TRD Sport
    Your camber shouldn't be 1.1 on one side and 0.0 on the other. Your cross camber should be maybe 0.1 or 0.2 max ideally 0.0. I would question the alignment tech that did this. I also want to note that it is pretty rare you will ever see 0.0 for any measurement especially on toe. 0.0 is ideal but rarely achievable. As far as your caster goes it looks good. 2.5 is not bad although I would probably argue 3+ is better on these trucks even though that is out of "factory" spec. I am running something like 3.9 on mine. As Justinlhc said you can adjust cross caster for road crown. I try to leave mine at zero because I drive the left lane a lot on the freeway which tends to have the opposite effect on secondary roads.
    Firebird[OP] likes this.
  7. Mar 27, 2017 at 12:55 PM
    Clearwater Bill
    Billy
    Largo Florida
    My thoughts would be max caster, as long as both sides match (as they do now) letting this be the 'control'.
    0 camber or just a pinch negative, and same on both sides.
    Toe should be in a bit (a low number), same on both sides. Toe will flare out when the suspension compresses.
    0 toe or toe out will cause trammeling on the road, but faster turning ability. But these aren't sports cars.
    Slight toe in will create more stability on the road.
    Caster is what lets the steering wheel center. If all your roads have heavy crowns, a good tech will adjust caster on one side to compensate.
    Someone will be along to straighten me out if I'm off base here. :D
    pseudomike likes this.
  8. Mar 27, 2017 at 1:04 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Bent spindle?
  9. Mar 27, 2017 at 1:04 PM
    anthony250f
    Anthony
    San Diego, CA
    I'm having alignment hell with the same suspension set up
  10. Mar 27, 2017 at 1:07 PM
    pseudomike
    Michael LaValley
    2012 DCLB TRD Sport
    If they cannot get your camber closer to zero with adjusters something is bent or out of spec. Are your adjustment cams moving freely? I would tell them to max the caster them adjust the the camber to spec 0.0 or very slightly negative.
    Clearwater Bill likes this.
  11. Apr 10, 2017 at 7:09 PM
    Firebird
    Phoenix
    Lewisberry, PA
    1993 FZJ80
    Good to know. Not sure why it took me this long to see your post.
