Looking for an opinion
Discussion in '1st Gen. Tacomas (1995-2004)' started by lindorffellery, Mar 13, 2017.
  1. Mar 13, 2017 at 2:45 PM
    lindorffellery
    lindorffellery [OP] Well-Known Member
    Evan Lindorff-Ellery
    Vermont
    1999 Tacoma Prerunner RWD
    Hey,
    I am about to purchase my first truck, after owning a Camry for 6 years, and being brought up on Toyotas. I'll be using it for work and play. Multifunctional.
    I am looking at a 1999 V6 Prerunner with extended cab, with hitch, timing belt replaced about 50K ago, 151,000 miles now, for $6,500.
    Do you all think it's worth it? Fairly low mileage, right? Does the timing belt need to be replaced now?
    Good deal?
    DustStorm4x4 likes this.
  2. Mar 13, 2017 at 2:46 PM
    mtbjohn42
    mtbjohn42 Well-Known Member
    Laporte, CO
    2005 Toyota Sequoia
    If you want it for play I would avoid the pre-runner
  3. Mar 13, 2017 at 2:48 PM
    lindorffellery
    Vermont
    When I meant play, I meant just taking it camping and on road trips and so forth. Maybe sleeping in the back with a good canopy, things like that. Does that seem reasonable?
  4. Mar 13, 2017 at 2:50 PM
    mtbjohn42
    Laporte, CO
    2005 Toyota Sequoia
    If you think you can have fun in a 2wd vehicle then go for it
  5. Mar 13, 2017 at 2:51 PM
    lindorffellery
    Vermont
    I mean, I had fun in car for 6 years, I think I can have fun in a truck, too. I'm not into off-roading or whatever, I just want something to carry my shit around.
  6. Mar 13, 2017 at 2:52 PM
    eccracer104
    eccracer104 O.G. Member
    San Diego, CA
    2016 Tundra 4x4
    Timing belt service is every 90k, so you should be good for another ~40k.
    Important things to check for:
    Frame rust
    Really search for any rust on ti anywhere
    Any oil leaks from the motor, transmission...
    If there are any vibrations while driving
    If the motor and transmission all feel smooth.
    That's a great truck and appears to be a great deal from the info provided.
    2wd is capable to get you to some cool fun places, but it certainly has its limitations (2wd owner :wave:)
  7. Mar 13, 2017 at 2:52 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    I suggest a quick glance here:
    https://www.tacomaworld.com/threads/1st-gen-tacoma-buyers-guide.156943/
    The biggest thing is to get underneath the truck with a hammer and a screwdriver and check for frame rust.
    I know they're more expensive, but these trucks really shine in 4wd. For off-road and in hectic weather conditions. These trucks have a really light ass end.
    The timing belt/water pump should be replaced every 90k miles or so. But can go for much longer. I have almost double the mileage and never replaced mine. I wouldn't worry about it for a while.
    Welcome to TW :)
  8. Mar 13, 2017 at 2:52 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
    What's the frame look like?
  9. Mar 13, 2017 at 2:52 PM
    Beer:30
    Beer:30 There's always money in the banana stand
    Kevin
    Somewhere North of Denver
    2016 DCSB OR V6 4X4
    Timing belts on the 3.4 have 60K change intervals, so you're getting close with that one.
    Edit: After I posted I saw the post above saying 90K interval, so I started second guessing myself and did some quick research. My '98 definitely had a 60K interval, but it appears that Toyota upped it to 90K shortly thereafter, maybe in '99. Of course, they will last quite a while past the change-by date, but you never know how far you can go before one does break and if it does, you've then got a real problem on your hands.
  10. Mar 13, 2017 at 2:56 PM
    lindorffellery
    Vermont
    Hey everyone,
    Thanks for all the responses.
    The truck is here, sorry, should have posted earlier:
    https://portland.craigslist.org/clk/cto/6035167592.html
    eccracer104, thanks for the advice. I'll definitely look for those things. And thanks for the encouraging words about the 2WD! As I said, I'm not into serious truck fun, just something utilitarian with a little power that can carry my tools when I work, and pull something reasonable, and carry my gear when I get out camping and hiking.
    And also, thanks DustStorm!
  11. Mar 13, 2017 at 3:16 PM
    eccracer104
    San Diego, CA
    2016 Tundra 4x4
    Left of the steering wheel, right of the little round knob, that looks to be the "rear differential locker" switch. Please someone correct me if I'm mistaken.
    ^ picture from the ad. below is a picture of the switch found on google. Looks very similar!
  12. Mar 13, 2017 at 3:19 PM
    lindorffellery
    Vermont
    That's seems to be a lesser version of 4WD, right?
  13. Mar 13, 2017 at 3:21 PM
    mtbjohn42
    Laporte, CO
    2005 Toyota Sequoia
    It just locks your differential so if one of your back wheels gets off the ground, you will still be able to move
  14. Mar 13, 2017 at 3:42 PM
    Aquatic Tacoma
    Aquatic Tacoma Well-Known Member
    Odessa, Fl.
    2019 Tacoma TRD Sport 4x4 Dbcb , 2004 Tacoma S-Runner
    Both are Stock - built correct from the start.
    lindoffellery,
    With your very general info that doesn't sound like a bad starting point. As said, look for that rust. Being that old it probably has been in accidents. You can run your choice of internet choice of check: Carfax, Autocheck, etc. Many times even all these together won't show true history.
    This forum is biased toward 4X4's. A TRD is more than capable for most "work and play". I ran an office at a company which had 37 4x4 Tacomas. We worked offroad, everyday. My personal truck was a 4x4. In 10 years of owning it, I never put it in 4wd for personal "work or play". I now drive a TRD 2wd double cab because I found the rear locker(TRD) was all I ever needed. I guess wheelin' at work made me keep it clean when off the clock.
  15. Mar 13, 2017 at 9:38 PM
    Obsessed2000
    Obsessed2000 Just a big dummy
    NC/VA line
    2000 SR5 4x4 3.4
    Deck plate mod Bilsteins All pro leaf springs All pro greasable shackles Camburg UCA Interior Led conversion Tundra TRD springs Extended SS brake lines Seat covers 33" yokos White herculined exterior
    I would buy a 4wd. That way if you ever need it you'll have it. Then you wont have to go through the process of selling this one later down the road and having to search out a new one. And probably taking a loss. Just my 2 cents and is what i tell everyone looking for a truck.
  16. Mar 14, 2017 at 4:39 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Those trucks with clean interiors scare me also the washed ones with every thing bright and shiny
    Open the hood and find a big mess and lots of spiders
  17. Mar 14, 2017 at 6:10 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    they got some good pics of the truck. locker in pic 12, timing belt in pic 14. since they have maintenance records that is a plus.
    as others said, check for frame rust otherwise that's a pretty decent looker
