Looking for bed cover for 2012 Taco 4dr,short bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by flyfsh65, Oct 14, 2012.
  1. Oct 14, 2012 at 1:07 PM
    flyfsh65
    flyfsh65 [OP] Member
    Harry
    Long Island,NY
    I am looking for a bed cover for my 2012 Taco 4dr, short bed. It has cargo rails and I wanted a cover that works with them. Any suggestions?
  2. Oct 14, 2012 at 2:40 PM
    ewkplymi
    ewkplymi Member
    Plymouth, MI
    2012 Tacoma Regular Cab
    I recently purchased a 2012 Tacoma 4 x 4 Regular Bed and installed a BakFlip VP cover from http://www.bakfliptonneaucover.com/. The installation was easy, the fit is right on, the profile is very low, the strength of the cover is excellent, and it looks great. The BakFlip uses the existing rail system for mounting.
    http://www.tacomaworld.com/gallery/showphoto.php/photo/281678
    http://www.tacomaworld.com/gallery/showphoto.php/photo/281677
    http://www.tacomaworld.com/gallery/showphoto.php/photo/281676
  3. Oct 14, 2012 at 5:02 PM
    charles leandro
    charles leandro Well-Known Member
    north alabama
    08 perrunner dc sr5
    none
    tuxado lo pro uses tocoma trac system works good elect gate lock
  4. Oct 14, 2012 at 5:13 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
  5. Oct 19, 2012 at 3:37 PM
    Divot
    Divot Member
    Charleston, SC
    12 Prerunner V6 SR5 DC
    BakFlip VP Tonneau, Pop and Lock Power Lock
    ewkplymi,
    I also have a 2012 Tacoma short bed and purchased the BakFlip VP. I really like the vinyl look and low profile. I get a lot of compliments on it. I've had just two issues that I wonder if you've come across.
    1. I'd really like the cover to be about 1/4" more forward, toward the cab. However the mounting knobs are as far forward in the mounting bracket slots as they can go. The cover's frames are as far forward as they can go as well.
    2. I have to slam the last section down pretty firmly to get it to latch. The screws on the underside of the cover where it meets the top of the tailgate are damaging the plastic rail cap on the tailgate.
    I installed the power Pop & Lock on the tailgate. Other than those two issues, all works great.
  6. Oct 19, 2012 at 3:39 PM
    Divot
    Divot Member
    Charleston, SC
    ewkplymi,
    Just realized you have the long bed. You may, or may not, have the same issues.
  7. Oct 19, 2012 at 7:45 PM
    tacomaconvert
    tacomaconvert Well-Known Member
    NY
    '12 White SR5 DC 4X4
    Factory roof rack, bed extender Extang Full Tilt Tonneau
    I just picked up extang full tilt for my '12 short bed SR5, I'll let you know tomorrow how install goes.
  8. Oct 20, 2012 at 6:19 AM
    ewkplymi
    ewkplymi Member
    Plymouth, MI
    Divot, I noticed the same two items that you mentioned. I feel that the cover is about 1/2" too long for a truly proper fit. When I line up the cover for a proper fit because the length is slightly longer than it should be when I fold the cover up it hits the back window frame at the bottom and not the top. I am going to contact BakFlip to give them feedback on their new product. I will include this forum link in the email. Also, they should move the threaded nuts that are used to secure the cover back at least 1" so that the knob isn't so tight against the bed, it is very difficult to tighten the knob down. I would also like to see a rubber pad adhered to the top of the slotted mounting brackets to better secure the cover, the rubber washer under the knob does not have enough surface area to keep the cover from moving. I will post any feedback from them. I still think that it is a great product and with a few modifications it could be even better.
  9. Oct 20, 2012 at 6:34 AM
    Chad7088
    Chad7088 Old Newbie
    Chad
    19th state
    ‘20 Tacoma Off Road DCSB 4x4 MT
    Lots to come
    I have a G4 fold-a-cover. I love it!
  10. Oct 20, 2012 at 8:36 AM
    tacomaconvert
    NY
    Just finished install on extang full tilt, easy and intuitive install, cam be adjusted a few different ways to fine tune install and fit. Its close, but cleats in bed rail system function fine. Getting bed extender in next few days, will see how that fits. If interested, I'll post pics later.
  11. Oct 20, 2012 at 9:50 AM
    sandjunkie
    sandjunkie Well-Known Member
    Aaron
    OC
  12. Oct 20, 2012 at 10:15 AM
    2006KJ
    2006KJ Well-Known Member
    Front Royal VA
    I bought the Truxport Truxedo and I love it... soft roll up tonneau with velco on the sides.. mounts above the rails so you can still use all the bed rail tie downs.. only $250.. and keeps all the water out. Plus it's pretty secure unless you cut the cover (i have a pop&lock too). I like it more then a trifold because i dont have to store it anywhere if want to use the whole bed... just roll it to the front. all the cross supports are attached to, and roll up with the cover.
    truxedo truxport-
    http://youtu.be/iWoiVD3hLsw
    on an unlimited budget i would buy this cover
    http://youtu.be/qDFth7D92QQ
    roll-x hard rolling tonneau cover. but you lose use of the bed rails.
    which brings me to the next best option.. keep the use of the bed rails.. very very secure.. and can be removed in less then a min.
    http://extang.com/docs/solidfold.html
    http://youtu.be/g1E_iiw0qwQ
    extang solid fold. would be very nice if $ isnt much of an issue. but you still have to remove and store it if you want to use the entire bed
  13. Oct 20, 2012 at 10:26 AM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    Not all Access, as far as I know the Limited and I cant say for sure, but I think the Lite Rider are the ones that work. I bought a used Loredo in which I was told worked with the rails by the owner. Not on mine. :( Apparently there are 2 sizes of cleats. His were smaller which he gave me and they still don't really work on mine. :confused: They will to some extent but are a pita and wont tighten down tight enough for anything heavy.
    I've been looking at the thread about items that work with the rails and plan to try to get some I bolts to work with mine. Also was thinking about adding D rings up front.
    Aside from the cleats not working on mine, I love the Access covers.
  14. Oct 20, 2012 at 2:36 PM
    TXPROMAN
    TXPROMAN Well-Known Member
    Martin
    NY
    2012 TX PRO TACOMA
    Bakflip HD
  15. Oct 20, 2012 at 3:23 PM
    sandjunkie
    Aaron
    OC
    cargo rails don't work with that setup
  16. Oct 20, 2012 at 7:37 PM
    tacomaconvert
    NY
    Extang full tilt works fine with factory extender. Great cover, very versatile. Can unsnap and roll up easily, or the whole cover detaches and removes in less than a minute.
  17. Oct 21, 2012 at 4:11 AM
    krob32
    krob32 Well-Known Member
    Kelly
    Sierra Vista, AZ / Asheville, NC
    2012 MGM TRD Sport DCLB
    WeatherTec Digi Liners, AVS Bugflector II, TRD FJ SE Anthracite Rims, BF Goodrich AT KO2 265/75/16, AVS In-Channel Wind Deflectors, Extang Solid Fold, Pop & Lock, Color Match Grill Emblem (Anthracite), Plasti Dip Emblems, Tacoma Bed Mat, Tacoma Door Sill Protectors, ToyTec Ultimate Lift Kit, ICON UCAs, Wheeler's Progressive AAL, Wet Okoles, Sockmonkey 3rd Brake Light Cover, LED Hood/Bed Lighting w/ OTRATTW Switches, Famous Fabrication Sliders, Sockmonkey TRD Bed Decal, Proven Design 4x4 Mudflaps, BenWA's Rear Power Sliding Window, Jasper Off Road 6" Reverse LED Pod, ImMrYo Rear View Mirror Bracket, GrillCraft w/ Black Mesh and color matched Land Cruiser Emblem, LED Tail Lights, Badge Removal and Vinyl TRD/Tacoma Stickers, Bullaculla Trailer Harness Relocation.
    Depends on whether you want security or just cover your gear. The G4 Elite allows you to use the rails and is very secure with its own locks. If coupled with a pop & lock, it is secure. It is a little more difficult if you want to completely remove for big loads. Extang Solid Fold is secure if coupled with a pop & lock and is easily removed if you have a big load. It does hook onto the rails, so it does not allow total usage of the rails. Many of the other solid tonneaus can be easily accessed with a wire hangar leaving your gear and the cover unsecure.
  18. Oct 21, 2012 at 11:08 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    X3 Love my G4 Elite :thumbsup:
  19. Oct 21, 2012 at 11:29 AM
    NEAScott
    NEAScott Well-Known Member
    Scott
    Toledo, Oh
    2014 Chevrolet Impala Limited
    OP, you didn't tell us if you are looking for a soft cover, or a hard cover? Do you have a particular budget?
    My suggestions for the soft covers will be the Extang Trifecta or Access Limited. Hard covers have a few more options, but some can be tricky with the rails.
    Feel free to give me a call and we can discuss your options.
