Looking for bed racks that fit with bed cover still on?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Gremlijarret124, Dec 7, 2021.
  1. Dec 7, 2021 at 8:30 PM
    Gremlijarret124
    Gremlijarret124 [OP] New Member
    Jarret
    2018 Cement Toyota Tacoma TRD Sport 5ft bed Four Door
    Hi guys, was hoping if anyone knew some good racks that fit over a bed cover. Going camping next year and was hoping to purchase bed racks while still keeping the bed cover on for security. It’s a trifold Bakflip hard cover, on a 5ft bed.
  2. Dec 9, 2021 at 6:14 AM
    KB Voodoo
    KB Voodoo Well-Known Member
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    All Max Modular bed racks work with tonneau covers.
    https://www.max-modular.com/shop-max-modular
    If your factory accessory rails are relocated, you need these brackets along with the rack: https://www.max-modular.com/shop-max-modular/tonneau-brackets-bakflip
    mdrnsamurai and TacoManOne like this.
  3. Dec 9, 2021 at 6:24 AM
    BrysonHart
    BrysonHart Active Member
    Bryson
    2020 cement taco
    From what I understand, KB voodoo bars will rust and paint chip when scratched, these billiebars are aluminum rails, so they won’t rust and they hold more weight!
    https://billiebars.com/products/bed-bars-for-tacoma-trucks
    A couple vids on YouTube explaining, here’s a good one…
    https://youtu.be/F3UtnyZuZBM
  4. Dec 9, 2021 at 6:29 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    Their uprights are made from steel and can rust just as easily as anything made from steel.
    We also offer an aluminum version: https://www.kbvoodoo.com/shop/toyota-tacoma-aluminum-hi-rise-crossbars-for-use-with-tonneau-covers
  5. Dec 9, 2021 at 6:35 AM
    BrysonHart
    Bryson
    2020 cement taco
    Nobody has complained about your bars rusting at the uprights, no metal on metal rub.
    Just on the bars where crossbars slide across
  6. Dec 9, 2021 at 6:41 AM
    Terraj66
    Terraj66 Well-Known Member
    las vegas
    2016 DCSB 4x4 sport. super white
    Get a retrax xr and a uptop mid rack. You will be able to actually open your tonneau cover while the rack is still on to access items in the back. This combo served me well before I bought my cap
  7. Dec 9, 2021 at 6:42 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    I also have the KB Voodoo rack and it works well for what we need it for. Holds our RTT no problem and that's 160 lbs empty.
  8. Dec 9, 2021 at 10:26 AM
    WoodsGhost
    WoodsGhost Well-Known Member
    PA
    2017 DCSB OR:2016 4Runner
    I used a KB Voodoo rack with my encore bed cover. I used the set up with an RTT. Worked great and I would highly recommend going with them for your bed rack needs. Very durable and fantastic customer service.
    I ended up purchasing a travel trailer and sold the rack and tent.
    TacoManOne and KB Voodoo like this.
  9. Dec 10, 2021 at 2:37 AM
    Josh41
    Josh41 Well-Known Member
    Josh
    Massachusetts
    2021 Black Taco 4D6' TRD Off-Road
    I have a the Max Modular TacoMax, this adapter give good clearance. I can roll back my Truxedo soft cover to access the bed. The Tacomax is all aluminum so, no rust. I have hundreds of miles off road with bikes and accessories on it with no issues.
  10. Dec 10, 2021 at 3:27 AM
    Ryeguy
    Ryeguy Well-Known Member
    43* North
    2021 TRD Off Road 4X4 Blackout
    OEM Bed Extension, Bed Mat, Lomax Bed Cover, Auto lock tailgate (OEM)
    I’m not certain how any of those would work with a trifold hard cover. You’d have to remove the cross bars (and everything attached to them) to open the cover and get access to the bed. Seems like a major PITA to me.
    To work with a trifold cover I’d think you’d need the vertical supports to rise nearly to the height of the cab. The crossbars would be at the height of the cab roof. The supports would also have to stay on the outer edge of the bed so the cover could be flipped open.
  11. Dec 10, 2021 at 4:43 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    We actually make a rack that allows a trifold cover to open:
    https://www.max-modular.com/shop-max-modular/utility-rack-for-tonneau-covers
  12. Dec 10, 2021 at 5:21 AM
    Johnny balls
    Johnny balls STILL NOT AN ADULT
    Jay
    CT
    2016 inferno dcsb
    Big sticker guy Lots of wasted money
    10 /10 never had an issue with my voodoo bars, no chips, no bends and no movement of the cargo, I love em!
    WoodsGhost and KB Voodoo like this.
  13. Dec 10, 2021 at 5:55 AM
    Old&fat
    Old&fat Well-Known Member
    21 TRD offroad
    I have the same bed cover. There's a few options (posted above) that allow you to attach the rack with a cover, but I havent been able to find one that also allows the cover to be opened.
    DetroitZoran likes this.
  14. Dec 10, 2021 at 6:17 AM
    KB Voodoo
    Chad
    Glenwood, NY
    www.kbvoodoo.com
    If your accessory rails are relocated (as they most likely are), there is no option that will allow you to open the cover with a rack installed.
    You could always switch to a retractable cover like the RetraxONE XR, then you would be able to fully open the cover:
    https://www.max-modular.com/shop-max-modular/retraxone-xr-brackets
